Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 01-15-2009, 09:30 PM   #1
OB2
Member#: 51500
1999 impreza rs-t
sylver
Default 2.5i or Cosworth manifold???
To begin I do have a GC8 RSTI with a EJ257 forged engine and a rotated GT30R turbo kit!
At the end of the last summer my frend totaled is 05 2.5I and give me is intake for free! I plan to install it on my engine to find the last bit of HP and TQ I can find on my engine!
But last week I find that Cosworth have made wonderful cast intake that I can buy here in Quebec Canada for 1500$CAD!!!
THE QUESTION IS: will it worth the 1500$ to install the Cosworth intake or do you think the FREE 2.5i intake will do a good job the help me to find a bit more HP and the most important of all, allot more TQ???
Please help me to make my choise???
OB2 is offline   Reply With Quote
Old 01-15-2009, 09:43 PM   #2
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
interesting...
TDagen is offline   Reply With Quote
Old 01-15-2009, 09:51 PM   #3
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
Cosworth Manifold for my HTA86 STI swapped 98rs.
Its designed to make power. The 2.5i just happens to "work".
Junior
Junior2JZ is offline   Reply With Quote
Old 01-15-2009, 10:10 PM   #4
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
There it is^
Old 01-15-2009, 10:22 PM   #5
jays05
Member#: 78165
05 STI 35r + e85
I want cosworth. Junior have you tested it yet?
jays05 is offline   Reply With Quote
Old 01-15-2009, 11:31 PM   #6
Mycues1982
Member#: 86995
2005 Tacoma
Yea but is it really worth $1000? I think the 2.5i manifold is better designed for a FMIC application givin that the runners are directed out the rear. Since the Cosworth looks to have been designed for a universal application it still uses the same brick wall design but with a larger plenum. It would be nice to see what the cosworth looks like on the inside though. Maybe the runners are designed better then I assume.
Mycues1982 is offline   Reply With Quote
Old 01-16-2009, 12:35 AM   #7
cellgeek101
Member#: 143941
04 STI JBP
07 LIMITED #602/ 06 BUSA
From the info that I gather...when XX tuning was selling n/a manifolds...there was more than just slapping the manifold on and it works...there was port done as well and some modification.
I would love to see the new cosi and a n/a mani back to back test!
cellgeek101 is offline   Reply With Quote
Old 01-16-2009, 12:43 AM   #8
Mycues1982
Member#: 86995
2005 Tacoma
Yea there will need to be some modification to use the 2.5i manifold, I think mostly to get fuel rails to work. I havn't researched it much but I think some custom hold down brackets might be needed. You will also need a TB adapter if your running anything but the DBW tb. I have 2 of them here and plan on doing some testing with them over the summer to help me determine a design for an intake manifold I'd like to produce myself.
Old 01-16-2009, 02:19 AM   #9
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
why not just get the free one and have it port and polished for like a 1/4 of the price?
watchunglava is offline   Reply With Quote
Old 01-16-2009, 12:51 PM   #10
Mycues1982
Member#: 86995
2005 Tacoma
Well you can't really port the 2.5i, you could sand and polish the runners some though. The flange section already matches up to the cylinder heads and gaskets perfectly.
Old 01-16-2009, 08:34 PM   #11
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
I have already done the 2.5i intake manifold on my ej257. I took wrx TGV's and had them ported and welded the ends shut. Then I had the manifold cut where the tgv's should be and had the wrx units welded on and portmatched on the insides. This gives you all the fuel rail options in the world and only cost me about $250 total. My car should be done in the next two weeks. Curious to see what it can do on a 35R car(mine).
2.5iSTI is offline   Reply With Quote
Old 01-16-2009, 08:40 PM   #12
CosworthSTI77
Member#: 195473
2007 STI
Still waiting for my cosworth to come in, ordered it a month ago, looking forward to how its going to hopefully better my numbers on the cosworth longblock !!
CosworthSTI77 is offline   Reply With Quote
Old 01-19-2009, 04:04 PM   #13
OB2
Member#: 51500
1999 impreza rs-t
sylver
Thanks for the info, and keep me informed on the 2.5I and the Cosworth intake!!
Old 01-29-2009, 03:26 PM   #14
OB2
Member#: 51500
1999 impreza rs-t
sylver
TOOOOP....
Nobody use 2.5I intake manifold...........want more info about it???
Old 01-29-2009, 04:51 PM   #15
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I think Phil from Element reported having using it on his time attack car, and did mention about the need to increase fueling at the top end after it went on, which was a sign that it was making more power than usual
jigga is offline   Reply With Quote
Old 02-02-2009, 09:36 AM   #16
OB2
Member#: 51500
1999 impreza rs-t
sylver
Comunication witht Me vs Phil Grabow:
Phil :
Yes I run that manifold but it requires custom plenum spacers (about 15mm), grinding, different fuel rail spacing, and welding closed some things. The 05 Legacy NA has the same upper (you use your TGV housings) so this is a much easier option than going with the unit I did.
Unfortunately I didn't document the before and after results on the dyno since I had no time before my race. When I tuned the map I could tell by how much more fuel I had to add that I had a sustantial gain around 5500-6500 rpm but there was more lag.
Thanks,
Phil Grabow
Old 02-02-2009, 10:04 AM   #17
9vapors
Member#: 92582
I like the Cosworth manifold, just unfortunately doesn't come with long intake runners.
9vapors is offline   Reply With Quote
Old 02-02-2009, 12:12 PM   #18
xdrian
Member#: 104200
828 WHP BUGEYE
Street Proven Performance
long intake runners are for na cars iirc, short runners are for turbo cars
xdrian is offline   Reply With Quote
Old 02-02-2009, 12:41 PM   #19
madmax718
Member#: 172501
not 100% true. Long runners still help with velocity issues, but has other drawbacks with turbo cars.
madmax718 is offline   Reply With Quote
Old 02-03-2009, 01:01 AM   #20
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
What drawbacks would there be???
Old 02-03-2009, 01:45 PM   #21
9vapors
Member#: 92582
What I meant to say was that unlike the V8 manifold, you need to run TGVs with the Cosworth, it doesn't come with the deletes...
Old 02-04-2009, 08:41 AM   #22
xdrian
Member#: 104200
828 WHP BUGEYE
Oh I see what you mean
Old 02-04-2009, 12:18 PM   #23
charliew
Member#: 125304
All street motors are na till the boost comes up. How can long runners be a concern under boost. It seems long runners only add intake volume to me.
charliew is offline   Reply With Quote
OH WTB: 2.5i factory exh. manifold TRBO_BXR Private 'Wanted' Classifieds 1 09-29-2009 12:18 AM
NA 2.5i w/ turbo manifold shtbxr22 Normally Aspirated Powertrain 23 08-14-2009 03:59 PM
Wanted:2005 legacy 2.5i or impreza 2.5i subiers555 Private Vehicle 'For Sale' Classifieds 7 05-30-2009 08:26 AM
WTB: 06-07 subaru impreza 2.5i stock exhaust manifold Vizzionz Private 'Wanted' Classifieds 8 07-27-2008 03:14 AM
2005 2.5RS or 2006 2.5i or 2006 2.5 wagon Prelude Canada Region Forum 16 09-21-2005 05:10 PM
