Old 01-16-2009, 09:42 AM   #1
cgmwrxFTW
Member#: 198107
2006 CGM Stage 2 WRX
Limited
Default Slipping Problem...?
So last night I was driving, it was about 0 degrees out, and I gave it in 5th gear to pass a car, and right when boost hit, sokmething was slipping... I do believe it smells like a burning clutch, but I am not sure...
If you guys could tell me what you think, know it could be that would be awesome...
Otherwise also if it is my clutch, suggestion for a new, or better clutch...
Just looking for some guidance and help...
Thanks,
Brock.
cgmwrxFTW is offline   Reply With Quote
Old 01-16-2009, 09:56 AM   #2
smurfwrx
Member#: 151928
09 Triumph S3
yup. Probably the clutch. I'd do some more "testing" to be sure, but that's got to be it if you ask me. Try a hard pull in 3rd. Do your RPM's seem to rise much faster than you start moving? That's teh slippage. The good news is, as long as it's just starting to slip, if you are easy on it you will have enough time to get another one and replace it. It wears out gradually but once it starts slipping, don't dilly-dally too long.
Go to Unabomber's Manifesto and check out the Clutch/Flywheel FAQ. Everything you need to know to make a replacement purchase.
smurfwrx is offline   Reply With Quote
Old 01-16-2009, 11:01 AM   #3
psychoskip
Member#: 78408
Now selling doses
of Acromegaly - GET SWOLE
+1 clutch.
Find an OEM exedy replacement clutch kit. I found mine on ebay. It came out to less than $200 shipped.
psychoskip is offline   Reply With Quote
Old 01-16-2009, 11:09 AM   #4
3hunHP
Member#: 173473
2012 STI
Plasma Blue Pearl
+1 clutch
3hunHP is offline   Reply With Quote
Old 01-16-2009, 12:20 PM   #5
RubbleDTD
Member#: 155997
2004 PSM WRX wagon
18Gxt
If you are planning on more engine modifications in the future I would recommend the ACT HDMM modified street disk + heavy duty pressure plate. It has around a 400 ft-lb holding capacity (up from the stock 300 ft-lb rating on the OEM exedy) and still features an organic full disc for smoother engagement and a little more "transmission insurance". From what I have read during the research phase, the Exedy stage I disc (an HDMM competitor) has tends to have more issues with clutch shudder, and sometimes expierences dis-engagement issues.
If you don't plan on going crazy with power mods, stick with the OEM exedy. and make sure you get your flywheel resurfaced properly! resurfacing is really important.
And yes, it is definatly your clutch slipping...
RubbleDTD is offline   Reply With Quote
Old 01-16-2009, 12:46 PM   #6
psychoskip
Member#: 78408
Now selling doses
I would only resurface if you cannot afford to purchase a new flywheel.
Resurfacing is around $30-$50. You can find a new one for a comparable price, or maybe even a low mileage one off another WRX.
Old 01-16-2009, 03:25 PM   #7
cgmwrxFTW
Member#: 198107
Limited
Wow, thanks a lot for all of the responses, and the help...
Thanks you so much for your time..
Brock
Old 01-16-2009, 03:26 PM   #8
cgmwrxFTW
Member#: 198107
Limited
-And I am sorry, I am a newb... What's Unabomber's Manifesto...
Clutch slip problems on my swap speedymaker Transmission (AT/MT) & Driveline 0 05-20-2010 05:48 PM
Missing/slipping problem e-type Pre-2002 Factory Turbo Powertrain 3 07-08-2005 06:09 PM
Trunk slipping problems Suby1128 Interior & Exterior Modification 7 06-21-2004 01:28 PM
clutch slip? tans problem?? philip_g Transmission (AT/MT) & Driveline 2 05-10-2003 01:52 AM
problem with a slipping clutch ben98 Normally Aspirated Powertrain 2 02-19-2001 06:46 PM
Message Board Statistics All times are GMT -4. The time now is 02:21 PM.
