View Poll Results: what should i get first
sway bars 24 96.00%
strut bars 1 4.00%
Voters: 25. You may not vote on this poll
Old 01-16-2009, 01:37 PM   #1
bugeye-joemomma
Member#: 192841
2002 Wrx
Sedona Red
Default what should i get first?
i have a 2002 wrx and as far as suspension goes its completely stock, and i was wondering what would be better to get first sway bars or strut bars?
bugeye-joemomma is offline   Reply With Quote
Old 01-16-2009, 01:42 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Sways bars X eleventy!!
Strut bars do relatively little in the way of performance when compared to sway bars.
Tony
Old 01-16-2009, 01:46 PM   #3
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
Rear sway mostly, i would say and endlinks too! strut bars mostly the front are more for looks
06HAWKMAN is offline   Reply With Quote
Old 01-16-2009, 02:04 PM   #4
gr8r rex
Member#: 155652
2002 PSM WRX
www.forced4s.com
Strut bars are not even worth it. I have them, they don`t do anything. Good swaybars front and rear with kartboy endlinks is a HUGE DIFFERENCE
EDIT: TIRES FIRST!
gr8r rex is offline   Reply With Quote
Old 01-16-2009, 02:22 PM   #5
Back Road Runner
Member#: 60082
2004 Forester STI
One the cheap, bump up the rear bar to the oem 20mm and call it a day. If you want a little more then that, look at a whiteline adjustable rear, say 20-24mm adjustable. The end links should be upgraded. This will neutral out the handling without messing up the comfy ride.
My advised next step would be tires after that, especially if the car is still very stock and running on oem RE92s. A good performance tire will bump up the grip considerably.
If you've got cash laying around after that, look at the rubber bits all over the car.
-Steering rack bushings and ALK for snugging up the front end and create a very exact and precise front end/steering.
-Rear lateral link and trailing arm bushings and subframe locking bolts to lock down the rear end and make the back end exact and precise.
-Engine, pitch stop, and transmission mounts(& crossmember) and rear diff outrigger and rear bushings to lock down the drivetrain and remove all slop and delay in power delivery between engine and ground.
-Front and rear shifter bushings and transmission mount(& crossmember) to lock down the shifter and tighten up shifting precision.
-Front and rear tophats to remove the cush in the suspension and provide more direct road/chassis interaction.
Address what bugs you. If you upgrade all the bits with Group N, Kartboy, and Whiteline rubber and poly bits, you will essentially have a whole new car, something that is a precision tool rather then a sloppy mess. Also, it's an '02, so the stock rubber bits are starting to get/have been worn out anyways. The individual parts are not all that pricey, but the sum of all does get expensive. Check out Rallispec and Turn in Concepts for all your bushing/mount parts. Rubber > Poly where you can use it. Spherical bearings are viable alternatives. All the front bushings/mounts are direct bolt on/swap in stuff. All the rear bushings are press fit, and require a lot more work. There are alternative, easy options that do the same job. Look up Unabomber's Sexy Rear End at Turn in Concept's site. Also, all the lateral links and trailing arms are press fit too, easier because they're smaller, but for a direct swap, consider aftermarket pieces for a direct bolt on, generally a poly bushing or spherical bearings, not cheap though.
The oem 20mm rear sway can be gotten from SubaruGenuineParts, the aftermarket Whiteline adjustable and endlinks from Turn in Concepts.
Old 01-16-2009, 03:03 PM   #6
nhat
Member#: 140163
03 STi
hellaflunctional
the only thing my front strut bar does is prevent my windshield from creaking when i go over bumps.
sway bars you'll feel immediately.
Old 01-16-2009, 03:04 PM   #7
kumanchu
Member#: 146696
i vote neither.
tires FTW!
kumanchu is offline   Reply With Quote
Old 01-16-2009, 08:20 PM   #8
dougb76
Member#: 160340
2009 wrx 5 door
RIP
Originally Posted by kumanchu View Post
i vote neither.
tires FTW!
+1 Tires will make more of a difference then most anything else. Think about it, tires are the only thing that connects your car to the road.
dougb76 is offline   Reply With Quote
Old 01-16-2009, 08:21 PM   #9
EdHilario
Member#: 137398
2004 Impreza 2.5RS
I'd get sway bars before strut bars for sure. Rear sway made a big difference on my car but I have yet to get a front sway bar. I do have both front and rear strut bars and only the rear made any difference. The front was more for engine bay bling lol
EdHilario is offline   Reply With Quote
Old 01-16-2009, 09:47 PM   #10
bugeye-joemomma
Member#: 192841
2002 Wrx
Sedona Red
i thought sway bars but i figured id ask you fellas first, and i was thinking of getting the cusco front and rear sway bar package right here:
http://scoobytuner.com/products/?vAp...&productID=730
Old 01-17-2009, 02:38 AM   #11
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
1. Read the suspension rules sticky.
2. Read it again, paying special attention to rule #4.
3. Ask a more specific question
IMHO the Cusco front bar is not big enough to be worth it. There are plenty of rear bars out there in the same size. Buy used, like the FAQ says. It's cheaper. Pick a bar based on size, not brand.
Old 01-17-2009, 11:27 AM   #12
bugeye-joemomma
Member#: 192841
2002 Wrx
Sedona Red
oh im sorry, lol i didnt even notice that.
but what i want to use the car for is everdaydriving but i wanna go autocrossing and such this year
Old 01-17-2009, 12:06 PM   #13
bugeye-joemomma
Member#: 192841
2002 Wrx
Sedona Red
ok so i just looked at the cobb ones again that i posted the link to earlier.
apparently both are 25mm, now my question is with both bars even, will that get rid of the understeer noticibally(sp?) or will those be too much for my stock suspension? ive been reading alot of the stickeys on this subject but im still a bit confused on it.
Old 01-17-2009, 12:14 PM   #14
Butt Dyno
Member#: 17301
is the "dark side"
Did you read the swaybar FAQ? It discusses the Cobb bars specifically...
Old 01-17-2009, 12:31 PM   #15
bugeye-joemomma
Member#: 192841
2002 Wrx
Sedona Red
i dont think im finding the one youre talking about, unless its post #5 on this thread? http://forums.nasioc.com/forums/show....php?t=1152714
Old 01-17-2009, 01:11 PM   #16
Butt Dyno
Member#: 17301
is the "dark side"
Right. The Cobb bars are hollow, and a hollow bar is not as stiff as an equivalent diameter solid bar. Post #5 has the "solid equivalents". So the Cobb bars are not even unless the rear bar is on the middle setting. Since the rear bar is adjustable you have some flexibility there to play with the rear bar to try to get the balance you want.
Old 01-17-2009, 01:50 PM   #17
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
He's already got an OEM 20mm rear sway if he has a sedan. I'd go with 24mm front and rear whitelines, or the Cobb set.
And i'd go with sways over tires personally in terms of fun-to-drive factor. Get tires when you need them. If you're trying to be competitve in auto-x, then yeah, you need better tires. But for just street driving, i just want a tire that has decent grip and a decent sidewall.
- Andrew
AndyRoo is offline   Reply With Quote
Old 01-17-2009, 02:59 PM   #18
bugeye-joemomma
Member#: 192841
2002 Wrx
Sedona Red
okay cool, thanks guys
what should i get first for PS3??? ODiz413 Off-Topic 35 10-11-2007 01:05 AM
What should I get first? Springs or Swaybars? volkl23 Brakes, Steering & Suspension 19 05-18-2007 09:07 PM
what should i get first, gauges or AP? jojotherider AccessPort 10 07-30-2006 09:16 AM
What are the first couple mods should i get, first wrx ever tcr04 General Community 40 12-14-2005 04:42 PM
What should I get first, tuna or UTEC? hernan Engine Management & Tuning 8 11-06-2004 01:22 PM
