Old 01-17-2009, 09:22 AM   #1
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
Default WRX Rack and Pinion going bad??
What are the chances that a 04 wrx rack and pinion is going bad at 54K miles. I have had the inner tie rod connecter fixed thinking that that was causing the clunk in the front driver side wheel. The shop told me last night that it could possibly be the rack and pinion. Does that sound right? The noise will happen when I am making a turn, and it sounds almost like something is loose. Sometimes while going straight I will hear it, but not often. Any opinions guys. The car is a DD and it also has whiteline steering rack bushings. It has made this sound ever since I bought it, so last 20K.
shamrock 05 is offline   Reply With Quote
Old 02-10-2009, 07:14 PM   #2
shamrock 05
Member#: 120057
One (highly recommended) suspension shop recommended it could be the lower ball joint eventhough when the car was looked at there were no signs of it going bad. Could it be ?
Old 02-11-2009, 03:14 AM   #3
johnkaldar
Member#: 51047
1999 gc8 RS/sti-ra
my car made popping noises during low speed sharp turning. It was the wheel bearings getting chewed up.
johnkaldar is offline   Reply With Quote
2008+ wrx sway, sti sway, wrx springs, wrx wheels, Streering Rack and Pinion Assembly yurka89 Suspension/Brakes/Handling 1 09-30-2009 07:37 PM
04 WRX rack and pinion shibby2821 Suspension/Brakes/Handling 0 08-25-2009 04:34 PM
Rack and Pinion or P/S Pump Going? trueno16v Brakes, Steering & Suspension 4 03-13-2009 11:43 AM
Rack and pinion going? bngofast Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-10-2008 10:11 PM
FS: UT 2002 WRX Rack and Pinion jaredpack Suspension/Brakes/Handling 2 09-26-2007 01:56 PM
