Old 01-17-2009, 08:16 PM   #1
Rabid_Machina
Member#: 167278
2004 WRX
Default front parking lamps dont work after H.I.D. install
i installed oem sti hid lamps on my wrx w/the lightwerks harness everything works except the corner/parking lamps up front.
drl disabled from behind glovebox, connectors cleaned(assemblies are in great condition, little cleaning needed just dust) and snapped in all the way, no blown fuses, new bulbs courtesy of prodriven rex.
is there something i could probably be missing?
Rabid_Machina is offline   Reply With Quote
Old 01-17-2009, 08:33 PM   #2
Horkus
Member#: 112667
2002 WRX wagon
They probably miss wired the harness area.
DMM the parking light wire and see if there is 12V. If no, then try re activate your DRL and see if it comes back up.
Horkus is offline   Reply With Quote
Old 01-17-2009, 08:38 PM   #3
Rabid_Machina
Member#: 167278
2004 WRX
im using the stock connector for the turn signal and parking lamps, this and high beams are the only connectors that are compatible. harness has nothing to do with those lights they are strictly for the driving lamps and ballast.
Old 01-18-2009, 12:34 AM   #4
Rabid_Machina
Member#: 167278
2004 WRX
figured it out, hahaha should of checked which direction i put the led bulbs in. thanks for responding though, i appreciate it.
this thread can now be closed, moved or deleted. thanks.
turn singnals dont work after wheel install Bug_eye_mobster Interior & Exterior Modification 9 03-04-2010 02:43 AM
Driver Door lock dont work after new alarm install hoyin Car Audio, Video & Security 13 01-18-2007 03:08 PM
Dash Lights dont work after installing new stereo, help!! wrxboy944 Electrical & Lighting 2 07-30-2005 07:29 AM
HIDs dont work after FMIC install b0dh1 Electrical & Lighting 6 01-11-2005 02:12 PM
Please help! Brakes dont work after spring install cvcsmkr Brakes, Steering & Suspension 4 01-19-2002 03:05 PM
