Old 01-18-2009, 09:22 AM   #1
Ekeenan86
Member#: 155493
1999 Legacy Outback
Default Washing In Extreme Cold?
It has been below 20 degrees for the last few weeks and recently has been around -5. However my car has been covered in salt and residue from the snow. I want to know if its harmful to wash the car in this kind of cold. I would take it to a self wash place to give it a good rinsing.
Ekeenan86 is offline   Reply With Quote
Old 01-18-2009, 10:22 AM   #2
Magic Marker
Member#: 181568
2011 3.6R Legacy LTD
Steel Silver Metallic
In the winter I go against my better judgement and run all our Subies through the local car wash to get the salt off. Whatever paint flaws I get I'll just correct in the spring. Getting a few minor scratches that I can buff out is better then letting salt just sit on the paint.
Magic Marker is offline   Reply With Quote
Old 01-18-2009, 10:38 AM   #3
ARBoost
Member#: 190876
2005 STI CGM
361hp/370tq Done by Jorge
Agree the scratches can just buff out and there not gonna be that bad anyways just surface scratches. Keep that thing clean .
ARBoost is offline   Reply With Quote
Old 01-18-2009, 01:25 PM   #4
Vew
Member#: 74229
2004 PSM WRX
I have tried washing in below freezing weather. This biggest problem is the water freezes before I am able to dry off the car.
Vew is offline   Reply With Quote
Old 01-18-2009, 02:22 PM   #5
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
just dont use the foaming brush.
jdubya301 is offline   Reply With Quote
Old 01-18-2009, 02:51 PM   #6
Boostinbildo
Member#: 163892
05 AW STI:SOLD
Black 93 Singled tt Supra
If I were you id just go to the touchless automated wash bays that blow dry the car at the end. It will get off all the salt, but not all the dirt and grime. But if you do it often, like weekly, there shouldnt be much buildup anways.
Using the ones that blow dry at the end are good, because if u spray ur car and then leave, all that water will freeze on the car, and then just attract more salt to it like a magnet. If its blow dried off, this will happen much less.
Boostinbildo is offline   Reply With Quote
Old 01-18-2009, 03:08 PM   #7
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
I just got my car washed yesterday (19 degrees) and I always use the same place. Soft cloth auto wash and 2 stages of blow dry. Still had some water drops....a very quick towel off gets most of that, then just live with what's left.
jack
Old 01-18-2009, 03:36 PM   #8
98imprezaWagon
Member#: 142548
02 BattleWagon
i just do it at home using very hot water...usually i have just enough time to wipe her down before it starts to freeze. imo using the hot water takes all the dirt and grime off much easier than going to a car wash and spraying it.
98imprezaWagon is offline   Reply With Quote
Old 01-18-2009, 04:00 PM   #9
drkramm
Member#: 159156
2007 wrx
wrb
hmm hot water and cold glass
drkramm is offline   Reply With Quote
Old 01-18-2009, 04:13 PM   #10
Ekeenan86
Member#: 155493
1999 Legacy Outback
I try to keep it salt free as much as possible however that's basically impossible with the roads around here. Any threat as to water seeping in, freezing, and cracking the plastic or various pieces on the car?
Old 01-18-2009, 04:46 PM   #11
Magic Marker
Member#: 181568
I probably wouldn't even worry about that. It isn't much different then if it rained and it froze the next day.
Old 01-18-2009, 04:54 PM   #12
DC16A2
Member#: 174357
2002 OBS
I use fairly warm water, with the coldest outside being 12F. Today was 30F, so I used all cold tap water. It looks nice now, but the salt will be back on the car within 2 days =(
DC16A2 is offline   Reply With Quote
Old 01-18-2009, 05:04 PM   #13
06WRBScoob
Member#: 182439
Fill a spray bottle with antifreeze consintrate and use that for a presoak then take a bottle of soapy water and cut it with some salt to wash!
06WRBScoob is offline   Reply With Quote
Old 01-18-2009, 05:12 PM   #14
mikeythejew
Member#: 141672
One thing to remember is that rust wont occur in freezing temperatures.
mikeythejew is offline   Reply With Quote
Old 01-18-2009, 06:40 PM   #15
Ryan314
Member#: 82989
Hybrid VF22
I swear by TOUCHLESS car washes in the winter.
Ryan314 is offline   Reply With Quote
Old 01-18-2009, 07:27 PM   #16
Psybin
Member#: 112719
2014 Evolution X GSR
06 STI & 05 9-2X = Sold
They turn the hose off at my garage during the winter... grrrr
There is a coin op car wash down the road, half the bays are closed during the winter, the other half they leave the sprayers running a little to keep from freezing. I put in $1.50 and fill my soap bucket and spray down the car. Hand wash with my soap and sponge, then put in another $1.50 and rinse it down and hand dry. I can normally get everything dried before it freezes. During the winter I use a spray and wipe wax, it does a good enough job.
Psybin is offline   Reply With Quote
Old 01-18-2009, 08:01 PM   #17
ashergrey
Member#: 174533
0694 WRXLtd/LegWagon
WRB/Pure White
Same here.
ashergrey is offline   Reply With Quote
Old 01-18-2009, 08:43 PM   #18
hella_sti
Member#: 139289
2003 WRX Wagon
touchless car washes FTW. Esp when you know the code, hahah.
coldest I'v washed my car is in -30 and the water got trapped in the wheels and I had to chip it off.
hella_sti is offline   Reply With Quote
Old 01-18-2009, 09:53 PM   #19
ceecel
Member#: 169899
2004 STI stg2 93oct
Platinum Silver
I usually just take it to the local sprayer and give it a good blast...but i concentrate more underneath the car...when i take it for oil changes I always ask to see under the car so I know where the salt builds the most and then i spray those areas when the car is done! It is almost always between -15 to -30 celsius here from dec-mar. Just make sure u dry ur door jams so u dont go out to frozen doors in the AM and tryin to get to work lol.
ceecel is offline   Reply With Quote
Old 01-18-2009, 11:18 PM   #20
pnutbutta
Member#: 192572
2007 Impreza
CGM
+1
if you feel the need to wash your car in the winter, it doesnt matter really if some water freezes on the exterior, just remember to wipe your doorjambs! If you have a good opportunity to throughly wash it, apply some silicone spray to the weatherstipping to help it not stick as bad!
Chris
pnutbutta is offline   Reply With Quote
Old 01-19-2009, 06:29 PM   #21
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
+1
Touchless... blow dry.
flimflamman is offline   Reply With Quote
Old 01-19-2009, 09:32 PM   #22
EnterTheDragon
Member#: 6511
optimum no rinse with a warm bucket of water
EnterTheDragon is offline   Reply With Quote
Old 01-19-2009, 10:04 PM   #23
haberkorn
Member#: 97732
2004 STi
65 Nova [email protected]
I wash my car in my warm shop...I like floor drains.
haberkorn is offline   Reply With Quote
Old 01-19-2009, 10:37 PM   #24
Rayman21287
Member#: 105125
2005 WRX/ 2008
Stage Pi/MercedesC300 4MA
Hehe, that is my experience as well here at UND.
Where abouts are you?
Ron
Rayman21287 is offline   Reply With Quote
Old 01-19-2009, 10:37 PM   #25
Cre8ive
Member#: 15617
2007 WRX STi OBP
'02 WRX OBP
I did the 48hrs of Tri-State drive. 1,200 miles of snowy, slushy, salty roads behind 40+ cars for three days. My black car was gray. So on my way home at midnight, even though there was light snow on the ground, i stopped at the self wash place to spray it down. I lucked out because the booth i pulled in, the timer didn't work and i sprayed my car for over 20 minutes straight for free!
This weekend I'll hand wash it with warm water and pull it in the garage to dry it off before it freezes.
Cre8ive is online now   Reply With Quote
Extremely noisy rear suspension in the cold tedstriker Brakes, Steering & Suspension 10 12-15-2011 06:51 PM
check engine light in extreme cold? ShaneInHisRoom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-13-2009 08:24 PM
Washed my car out in the cold today Master2192 North West Impreza Club Forum -- NWIC 17 12-19-2005 02:52 PM
Mods VS. IM test, Extreme Cold, Warranties Konvict Alaskan Impreza Club Forum -- AKIC 8 10-22-2003 02:26 AM
Extreme Cold oh_BS General Community 13 10-02-2003 09:11 AM
