Old 01-18-2009, 07:11 PM   #1
aakrusen
Member#: 77308
'02 WRX
Default Oil pressure and temp at oil filter
I was looking into adding the autometer oil temp and oil pressure gauges and I was going to buy one of the adapter plates that goes between the oil filter and the engine. Can I get my temp and pressure readings from this area and have it be accurate? Are there easy/better places to get this info from my engine? Is there anything else I should be considering when doing this project?
aakrusen is offline   Reply With Quote
Old 01-18-2009, 07:19 PM   #2
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Are you planning on running an oil cooler? (my racecar has the sandwich....honda) If you are, then it'a an easy way to run everything into a single adapter at first glance. But you need to look at what it's going to take to get the sensors in and then the whole sandwich in place. I don't know how the STi is, but I look at my LGT and have no interest in this. The other consideration is that for oil pressure, you're going to want it on the cool side....just before going into the block. For oil temp, you want it coming from the engine....not the cooler.
jack
Old 01-18-2009, 07:26 PM   #3
BluScubi
Member#: 162726
2009 LGT
QSM
What he said^^^^^ I have the sandwich adapter with both oil temp and press located there. The pressure reads comparably to what others report but the temp always reads what seems like a low reading. Other places to consider for tapping are the oil gallery plug on the top back of the block under the IC, and the stock oil press switch location on the top front of the block behind the alternator.
BluScubi is offline   Reply With Quote
Old 01-18-2009, 07:33 PM   #4
aakrusen
Member#: 77308
'02 WRX
Do you know where I could find a pic or diagram of these areas. Also, I need the thread pitch and stuff for adapters in these areas. I was going to spend $40 on the sandwich adapter or I could spend $40 on installation components in these areas. Is it worth the headache to tap into these areas or should I just do the sandwich? I may run an oil cooler down the road but if I had to answer now I would say no.
Old 01-18-2009, 07:58 PM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Go to the top of this forum and read the Unabomber's Manifesto. Inside is the Gauge FAQ, where all things will come to light.
Old 01-18-2009, 10:29 PM   #6
CynicX
Member#: 48199
06 WRX
The galley plug mentioned is under the passenger side of the alternator. Look down there with a flash light and you'll see the stock oil pressure sender. Remove that (it does NOT give you a low oil pressure light disconnect) and screw in a sensor there.
You will need an adapter to change the threads but I dont know the numbers off the top of my head. Search for one on aftermarket part websites like fastwrx.com or whatever.
There is another galley plug directly behind it on the opposite side with a plug in it. Its underneath the front passenger corner of the intercooler. They also make relocation SS braid lines for those fittings to make them more accessible....
CynicX is offline   Reply With Quote
Old 01-18-2009, 11:26 PM   #7
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
This is my sandwich plate set up, easy install
Micky is offline   Reply With Quote
Old 01-19-2009, 12:12 AM   #8
aakrusen
Member#: 77308
'02 WRX
What do you have tapped into the sandwhich?
Old 01-19-2009, 02:52 AM   #9
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
Oil temperature and pressure, for Defi gauges
Old 01-19-2009, 07:43 AM   #10
CynicX
Member#: 48199
06 WRX
That looks pretty good. I tried a sandwich adapter on mine but there was no way to make it fit. The people I bought it from told me I had to bend something out of the way, however it was hitting an oil line, which I'm not trying to bend.
I had a different sandwich adapter though....
prosport gauges water temp,oil pressure and gauge sender,oil plate adapter&perrin pod jeremywrx15554 Interior/Dressup/Audio & Security 18 08-11-2009 08:57 PM
Prosport Premium Gauges 52mm Oil Pressure and Temp Remote Oil Pressure Sender Kit skribblez32 Interior/Dressup/Audio & Security 4 07-01-2009 03:50 PM
FS: DEFI link gauges, green/black, 52mm Oil pressure and temp, and EGT lotusdrift MAIC Private Classifieds 8 08-12-2008 02:55 PM
FS: DEFI link gauges, green/black, 52mm Oil pressure and temp, and EGT lotusdrift Interior/Dressup/Audio & Security 7 08-12-2008 08:42 AM
want an oil cooler but already using a sandwitch adapter for oil pressure ands temp.. mpower22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 04-19-2006 03:43 PM
