Old 01-18-2009, 09:00 PM   #1
rs dude
Member#: 200538
2005 impreza 2.5rs
white
Default what is my hp?
I have a 2005 impreza 2.5rs with the following mods:
Stromung catback exhaust
Borla headers
Injen intake
Stromung high flow cat
K&n air filter
Perrin lightweight crankshaft pulley
Can you please help!?
rs dude is offline   Reply With Quote
Old 01-18-2009, 09:27 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
If you are lucky, 150 whp....
Old 01-18-2009, 09:35 PM   #3
novacivic
Member#: 117980
2005 sti
wr blue
anywhere between 5-500hp depending on the dyno.
novacivic is offline   Reply With Quote
Old 01-18-2009, 09:40 PM   #4
rs dude
Member#: 200538
2005 impreza 2.5rs
white
so would that mean like 210 to the flywheel
Old 01-18-2009, 11:04 PM   #5
lemons
Member#: 186654
2005 2.5 RS
Navy Blue
The HP you have is exactly.....
..... the number that a dyno reading gives you.
And theres no way an intake, exhaust, and pullies give you +50HP at the crank.
PS. Isnt there a different forum for this? I dont see a turbo in your mods list.
lemons is offline   Reply With Quote
Old 01-18-2009, 11:06 PM   #6
rs dude
Member#: 200538
2005 impreza 2.5rs
white
i know, i dont have a wrx which has the turbo, the rs has no turbo
Old 01-18-2009, 11:07 PM   #7
ceecel
Member#: 169899
2004 STI stg2 93oct
Platinum Silver
take it to a dyno if ur wicked serious
ceecel is offline   Reply With Quote
Old 01-18-2009, 11:09 PM   #8
rs dude
Member#: 200538
2005 impreza 2.5rs
white
im sure a dyno costs money to use and i dont really feel like goin and doin that, im just lookin for a range so i have some sort of clue, and y wouldnt i be "wicked serious"
Old 01-18-2009, 11:17 PM   #9
lemons
Member#: 186654
2005 2.5 RS
Navy Blue
Take a look in the N/A forum. There are some good discussions in there. Dont expect too much HP from your mods though. My uneducated guess would be +10 - 15HP. RS's are rated from Subie 165 at the crank. At the wheels it is much less because the power is going to four wheels instead of two.
Old 01-18-2009, 11:23 PM   #10
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
TrueHP is generally what you trap in the 1/4 mile.
Old 01-18-2009, 11:26 PM   #11
forrealsss
Member#: 182954
2008 WRX hatch
SSM
Don't 2.5RS's make ~120whp? With his mods he probably has somewhere around ~130whp... But it's all relative to the dyno you're using.
forrealsss is offline   Reply With Quote
Old 01-19-2009, 12:12 AM   #12
ceecel
Member#: 169899
2004 STI stg2 93oct
Platinum Silver
Im saying "wicked serious" because ur car is not really that upgraded man. just add like maybe 15 hp onto the regular RS and there u have it. And if u were serious about numbers u would spend the money on a dyno.
Old 01-19-2009, 09:14 AM   #13
leftho0k
Member#: 177589
bupmty pmb for going to the dyno idea.. if i was to conjecture i'd say around 125-135 wheel.
leftho0k is offline   Reply With Quote
Old 01-19-2009, 09:38 AM   #14
rs dude
Member#: 200538
2005 impreza 2.5rs
white
the injen intake says it adds 17 hp alone, and with all the other mods i dont really get how it could be so low
Old 01-19-2009, 09:55 AM   #15
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Because injen lied to you. I don't know the numbers, but i personally would be surprised if you saw more than 10HP with bolt ons like that. 'Specially with no tune.
Try over in the N/A forum - this one is for turbo'd motors.
Also, you need to remove that intake. It's causing MAF issues which cannot be corrected, causing extreme rich conditions at low RPM.
sniper1rfa is offline   Reply With Quote
Old 01-19-2009, 10:01 AM   #16
rs dude
Member#: 200538
2005 impreza 2.5rs
white
whats MAF?
and do u mean NASIOC is only for turboed cars?
Old 01-19-2009, 10:19 AM   #17
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Mass Airflow Sensor - it's what measures the air coming into the engine. Your intake is causing it to read extremely high under certain conditions due to a resonance being set up in the intake tract. You need at least the stock snorkus, though it's simplest to use the stock airbox as well. This is not a problem on turbo cars.
The important thing is that you need to remove the intake and put the stock one back. There is a sticky in the N/A forum about it.
and this is the N/A with bolt on turbo (forced induction) forum. The N/A forum is here.
Old 01-19-2009, 11:06 AM   #18
tronnnnnnn
Member#: 186577
2006 WRX TR
SGM
This is most likely the gains they got after tuning and retuning the car to get the best numbers from the injen system....... you will not see anything close to those gains by just bolting it on
tronnnnnnn is offline   Reply With Quote
Old 01-19-2009, 05:51 PM   #19
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
That all depends on the dyno. Reddevil's number of 150whp is probably pretty close if he's measuring on a Mustang dyno. Most Mustangs put a stock RS at 120-135whp. Each dyno is different.
The Dyno Dynamics dyno in my town puts a stock 2.5RS at 95whp.
And that's only two out of maybe half a dozen brand of dynos.
Take the example of my old personal RS. It made 151whp and 158ft/lb of torque on Cobb's Mustang dyno. That was with intake, exhaust (including headers, pulley and cams. I brought it home and it made 138whp and 135.5 ft/lb of torque. So same car, same set up, different dynos. You will also note that on a Mustang I made more torque than HP. But on a DD I made more HP than torque.
So the guy who said you will make as much power as you make on the dyno you run your car on, got it right. Dynos are like shoe sizes. Adidas says I'm a 9.5, while Nike says I'm a 10 and La Sportiva says I'm a 42.5...
What is my lugnut torque specs on my '02 WRX? Fireguy615 Tire & Wheel 11 01-06-2010 02:17 PM
What is max hp running sti exhaust? andmoon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-30-2006 04:41 PM
Oh What oh What is my ram configuartion Gerkins31 Off-Topic 2 07-15-2005 11:34 AM
What is max HP for 205 block? treebeard Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-26-2004 09:50 AM
what is the HP rating of a VF23? WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-10-2003 09:46 AM
