Welcome to the North American Subaru Impreza Owners Club Wednesday August 5, 2015
Old 01-19-2009, 11:43 AM   #1
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Default AutoX Gurus - Aftermarket pistons ok in BSP?
AutoX experts,
I ran my STi in BSP last season. In the off-season, I blew a ringland. Currently, my engine is dissassembled and receiving new aftermarket pistons. Does this change from stock to aftermarket kick me out of BSP?
The piston size is the same, but the material of construction and ringland design are different.
Thanks for your feedback!
MAHLE PISTON
PART #: WRX209917I22
**INCLUDES PRECISION FITTING RINGS
APPLICATION: MAHLE Racing Pistons Subaru 2.5 Turbo WRX STI,Forester,Legacy EJ25/257
BORE: 99.50mm
STROKE: 79.0mm
ROD LENGTH: stock
PIN DIAMETER.: 23.0mm
COMP. HEIGHT: 30.70mm
DOME VOLUME: -22cc
WEIGHT: 399 grams
COMPRESSION RATIO: 8.5 to 1
T-WRX is offline   Reply With Quote
Old 01-19-2009, 11:48 AM   #2
KC
Member#: 442
13 Crosstrek XV
00 S2000
15.10.R:
R. Cylinders may be rebored to no more than .0472 in. over standard bore and the appropriate standard oversize piston may be substituted. This overbore dimension is an absolute limit; no additional tolerance is permitted to accommodate wear. Cast or forged, non-stock pistons of the same dimensions and configuration as original equipment pistons may be used. Additionally the replacement pistons must be of the same weight or greater as the original equipment pistons. Replacement pistons must match OE piston configuration exactly including quench area. The allowance for the use of aftermarket forgings vs. OE castings does not permit alternate piston dome designs. This allowance does not permit alternative ring configurations.
If the pistons meet that criteria bolded, you're good to go. As far as the rings, someone more knowledgable than I would have to answer that... I don't know what 'alternative ring configurations' means in SP context.
--kC
KC is offline   Reply With Quote
Old 01-19-2009, 12:29 PM   #3
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Ha....learned something...
Old 01-19-2009, 12:38 PM   #4
espEVO
Member#: 97610
If the ringland is a different design then the rules state that it is NOT a legal piston for SP.
I see nothing wrong with alternate materials, that looks to be allowed.
John
espEVO is offline   Reply With Quote
Old 01-19-2009, 01:07 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
What's Doug Gill's email addy?
I'd send a letter to be sure......
Jay
Old 01-19-2009, 02:34 PM   #6
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
The way the rules are written, it doesnt look like youre going to stay BSP legal, as the stock compression is 8.2 and these pistons are 8.5.
cucamelsmd15 is offline   Reply With Quote
Old 01-19-2009, 02:50 PM   #7
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
& 2006 IAG WRX (ForSale!)
dgill@scca.com
CamaroFS34 is offline   Reply With Quote
Old 01-19-2009, 02:51 PM   #8
solo-x
Member#: 37624
Compression ratio changed? = not legal for SP
Weight changed? = not legal for SP
Ring land configuration changed? = not legal for SP
In short, no, those pistons are not legal for SP.
solo-x is offline   Reply With Quote
Old 01-19-2009, 07:18 PM   #9
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Thanks guys - very helpful information.
So it sounds like it may not be legal for SP. Drat.
Old 01-19-2009, 07:36 PM   #10
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
But you will have a Dependable car now
dstan is offline   Reply With Quote
Old 01-19-2009, 07:40 PM   #11
Mechie3
Member#: 120152
I looked into this a bit for ESP and it looked like staying stock was really the only way to assure you met all of the rules without getting some expensive custom deal.
Mechie3 is offline   Reply With Quote
Old 01-19-2009, 08:21 PM   #12
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
This is per the STI FSM
Cylinder Bore STD
(A) 99.505 — 99.515 mm (3.9175 — 3.9179 in)
(B) 99.495 — 99.505 mm (3.9171 — 3.9175 in)
Max over bore is 0.5 mm (0.020 in)
Subaru makes an STD A & B piston.
and an oversize piston.
0.25 mm (0.0098 in) OS / 99.745 — 99.765 mm (3.9270 — 3.9278 in)
0.50 mm (0.0197 in) OS / 99.995 — 100.015 mm (3.9368 — 3.9376 in)
This is the same as my 2.5RS.
I am assembling an SP motor for my DSP RS right now using the factory .5mm OS pistons. That is about all you can do to the bore and pistons.
There is also a surface grind limit on the head of .012" and .004 on the block for the STI in the FSM. It will give you a smal bump up in compression.
My RS FSM will only allow .004 on the head on block.
Patrick L is offline   Reply With Quote
Best stock pistons produced in USDM/JDM engines and Comparison to Aftermarket pistons Audioexcels Pre-2002 Factory Turbo Powertrain 13 03-01-2010 12:11 AM
aftermarket forged piston/rods in ej207 ImprezaRSfan! Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 37 08-02-2005 03:50 PM
Hey AutoX Gurus...should I... mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 34 04-30-2004 10:11 AM
Autox gurus -- can you explain this? sdecker Motorsports 108 03-17-2004 05:24 PM
How do people like their aftermarket pedals? OK in the wet? Patrick Olsen Interior & Exterior Modification 12 01-26-2001 12:22 AM
