Old 01-19-2009, 12:58 PM   #1
Boost2the_moon_ej20
Member#: 112782
Default 2.2t vs. 2.2 n/a crank
Does anyone know the strength differences between the two, and should it just drop in? I spun a bearing in my 91 ss 2.2t and am looking at my options. I have a 2.2 (out of a 93 legacy L) n/a complete motor on standby and for the moment I just need this car back on the road. I do plan on building this motor up, but the time isn't right just yet. Any info wil be greatly appreciated. I did read through a bunch of threads using search also....
Boost2the_moon_ej20 is offline   Reply With Quote
Old 01-19-2009, 05:42 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
There's no difference. You can also use a crank from an Ej18 in there. They're the same.
Old 01-19-2009, 07:29 PM   #3
94 GT
Member#: 193676
94 legacy GT
silver (grey soon!!)
what are the differences between all the cranks????? is the 20g's crank different than the 22t's?? are the 2.5's any different?? do these engines mainly very by stroke or bore????
just wondering cause I have a 22t block sitting in my trunk at the moment if I can get any money for it I will but if not I might build somthing good like really good!!!!!!! but what cranks work with the old closed deck blocks???? also do the twin cam heads bolt right up to the 22t block?/ my 20G is also a closed deck block are they the same block with a different crank??? any help would help me out alot!!
thanx Jesse
94 GT is offline   Reply With Quote
Old 01-19-2009, 08:45 PM   #4
RallyColtTurbo
Member#: 16819
With very few differences, all phase 1 cranks (except EJ25) are the same.
The only one I know for a fact is different is the early Legacy RS/RA, which was hand balanced. Even at that, it is most likely the same forging as all the others. There may be others from Impreza RAs, but not sure. Anything you will find in a North American vehicle is exactly the same.
For phase 2 motors there are a few different cranks, mostly to do with factory oiling improvements.
For phase 1 EJ25 cranks the stroke was increased from 75mm to 79mm. The rod journal diamer was decreased from 82mm to 78mm. I know little about phase 2 EJ25 cranks so I won't comment.
RallyColtTurbo is offline   Reply With Quote
Old 01-19-2009, 10:09 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
Old 01-20-2009, 08:51 AM   #6
Boost2the_moon_ej20
Member#: 112782
Thanks for the info guys. I actually made a decision last night to satisfy my original intentions. I'm going to just install the whole n/a motor (swapping over cams and intake manifold) and put my tdo4 and tmic on it and run at low boost. Meanwhile I'll still be able to have the car on the road and build the 2.2t block on the side.
'96 2.2 Outback vs. '97 2.5 Outback Limited wrxlvr Legacy Forum 3 01-04-2006 01:31 PM
stroking the 2.2T to a 2.4 marios03wrx Subaru Conversions 14 04-04-2005 01:22 AM
2.2t vs 2.5t factory bottom ends power? availability? jdchmiel Normally Aspirated with bolt-on Forced Induction Powertrain 3 01-16-2004 12:01 PM
swapping 2.2T into 95L 2.2N/A..questions scottsubarus Normally Aspirated Powertrain 4 04-01-2003 08:37 AM
02 2.5rs vs 01 2.5rs Blindeye_03 General Forum Archive 8 02-24-2001 11:56 PM
