Old 01-19-2009, 03:14 PM   #1
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
Default Comment on alignment specs. Am I crazy?
See below photo. I asked for:
-1.5 camber front, -1.0 camber rear, 0 toe front, 1/16 toe out rear
Running HotBits DT1 gravel setup, so it has camber bolts in the rear. This was the first alignment done on the car since the coilovers were installed, and a week had passed (and 120 miles) before I requested the alignment.
Is it me, or did they completely not do what I asked?
I'm going back to get them to fix the front at least, and have them take a stab at actually getting everything else closer. Thoughts?
Geek Guy is offline   Reply With Quote
Old 01-19-2009, 03:38 PM   #2
pauli18c
Member#: 174553
2005 STi 360whp
345wtq on 93oct @ 20psi
looks to me like they did a "green" toe alignment, and didnt even bother with camber for the fronts. Didnt do anything at all with the rear...
you got hosed
pauli18c is offline   Reply With Quote
Old 01-19-2009, 03:39 PM   #3
Geek Guy
Member#: 8151
2002 WRX Rally Car
Well, to be fair, I have the lifetime alignment so I didn't pay a dime But I think that was part of the motivating factor in their work effort as well.
I called them and am heading back to get it redone this evening.
Old 01-19-2009, 04:13 PM   #4
orvtech
Member#: 115602
i had your same numbers except -2.5 on front for autox
orvtech is offline   Reply With Quote
Old 01-19-2009, 04:34 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
somebody above said it....
you got hosed
Old 01-19-2009, 07:56 PM   #6
Geek Guy
Member#: 8151
2002 WRX Rally Car
Update: I took it back and had them try again with the new specs (just to see if they were paying attention). Well, they didn't start on my car until 6:30p (1/2 hour before closing) and messed it up even worse. Now, because of my rideheight I will likely need camber bolts to get as close as to my specs as requested:
Car drives HORRIBLY now. It's pretty clear from the results. They gave up halfway through.
So, I've got some aftermarket bolts coming in to add some more camber. I'll get the bolts installed and then take it down there for a third time to see how they do.
Old 01-19-2009, 08:13 PM   #7
Daishi00
Member#: 78952
2005 WRX
CGM
WTF did they do to the rear of your car? They absolutely destroyed the thing. Go to a real alignment shop and pay the money to have a correct alignment done.
Daishi00 is offline   Reply With Quote
Old 01-20-2009, 10:15 AM   #8
resonant evil
Member#: 99705
12 sti
dirty
looks like you went to a firestone type place. they really make their dime on dd passenger cars, they really fall off on the performance side. you might get lucky and have a knowledgeable tech but not likely. you have to understand what they are thinking, "why would you want -2deg of camber, thats wrong".
for this it is required you show up early, bring reserve amounts of patience, and be on hand (watch from as close as possible) for the job. the last is a pain in the ass for the tech and you, but, they have already showed their incompetence.
the least they should have done is got you as close as possible, made the left and right side even. the shop closing is no excuse for not finishing the job, they shouldnt have started.
the first job looks like they didnt even look at your request, they just got you within subaru specs.
resonant evil is offline   Reply With Quote
Old 01-20-2009, 10:25 AM   #9
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
their printouts make no sense... yesterday the 'after' front cambers were -0.5 / +0.1 and today the 'before' values are -1.3 and +0.9 ???
yes you will need camber bolts to get the rear camber you want but on an 02 sedan the front should go to -1.5* with the stock adjusters unless something is bent
UkNuck is offline   Reply With Quote
Old 01-20-2009, 11:06 AM   #10
leecea
Member#: 37359
2003 WRX
It only took me one experience like this to realize that I could do a better job myself.
To be fair though, these places are set up to ensure alignment is within factory specs on a stock car. You may be expecting too much from them.
leecea is offline   Reply With Quote
Old 01-20-2009, 11:27 AM   #11
DuckStu
Member#: 124060
2004 WRX STI
That's standard in the alignment industry. It's refered to as a "Toe & Go". I have friends that are car nuts and autocross etc that are managers and employees at alignment places,..and they don't set anything but toe. They'll tell you that all the customer cares about is that the steering wheel is straight.
Most any alignment shop will ONLY set the toe,..and never check the other settings.
Most alignment rack operators don't even know HOW to check caster. (Checking caster requires the operator to turn the wheel to the right, sometimes press a button,..then turn it to the left, and sometimes press a buttton,....and then straighten it back out. If they do an adjustment,..they will have to repeat this procedure. You'll NEVER see that happen).
So I bought a laser level thingy from Black & Decker and do mine myself.
DuckStu is offline   Reply With Quote
Old 01-20-2009, 12:46 PM   #12
delongedoug
Member#: 124113
and beyond!
Well there's your problem right there. Don't get your car aligned where you get your dog his shots.
Seriously though, I would take it somewhere else as they seem to have no idea what is up. What good is free lifetime alignments when they can't get them right? When I brought my car to Firestone I got lucky. When I told the tech the specs I wanted he asked if I autocrossed and it turns out he had run with the same group as I do. So he knew what he was doing and where I was coming from.
That place sounds like a butchershop.
delongedoug is offline   Reply With Quote
Old 01-20-2009, 02:38 PM   #13
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Quoted for truth.
Old 01-20-2009, 10:43 PM   #14
BIGSKYWRX
Member#: 7958
09 GH B+
What kind of suspension do you have that comes w/ camber bolts in the rear? I think you may have the wrong suspension possibly- look at your first printout your rear camber is 1.1 and 1.5- it's in red because it's POSITVE, if it was neg it would be green and normal
what kind of suspension changes the rear camber by ~ 3 degrees???? a normal camber bolt is not going to over come that much camber
the guys doing the alignment are obviously not rocket scientists, but I'd be much more concerned w/ exactly what suspension you have bolted onto your car
Old 01-20-2009, 10:47 PM   #15
Zottyzot
Member#: 62150
2007 WRX wagon
UGM
You could try talking to the tech, and greasing his palm abit. This might get you what you want.
Zottyzot is offline   Reply With Quote
Old 01-21-2009, 12:07 AM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
or what the bent trying to align it wrong
Old 01-21-2009, 04:36 PM   #17
delongedoug
Member#: 124113
and beyond!
Agreed that +2.3 in the rear is a red flag.
EWG on stock TD04? Am I crazy? Rugy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-14-2008 12:06 AM
Need comments on wheel alignment shop in Calgary Modifying Western Canada 34 05-27-2007 03:21 PM
Driving on a bad CV joint... am I crazy? cocheeze 'Old School' Subaru Forum 4 12-12-2005 08:43 PM
My alignment specs - pls comment cool555 Brakes, Steering & Suspension 5 09-03-2005 02:04 AM
Comment on my alignment/setup MattSTi Brakes, Steering & Suspension 1 06-03-2005 01:00 AM
