Old 01-19-2009, 08:18 PM   #1
ReDHaTyGuY
Member#: 200618
Default Idle jumping high in stop n go traffic
me and my Gf have a 03 wrx that she purchaced used with 80k on it .. im just getting around to asking this, this past summer when it was fairly hot out and we would be driving in stop n go traffic .. when we would come to a stop the car would idle really high like 3k.. if she would turn the car off and restart it it would idle fine untill we started driving again and came to another stop.. now it only did this when it was really hot out.. ive been searching for some answer's and have came across a few possiblities but im looking for some more input on this... the car is stock as far as i know with the exception of a AEM cold air intake... i was thinking maybe the iacv needs cleaned or something of that nature.. im going to be doing a 90k service here soon so i wanna try n fix this problem while im at it
ReDHaTyGuY is offline   Reply With Quote
Old 01-19-2009, 09:44 PM   #2
pro934
Member#: 169234
2005 STI WRB Reffing
the Kumite from the South
I'd be willing to bet you are on the right track with the IACV. Hot weather tends to make your car run rich as well, the air is less dense than cold air. Maybe get your AFR's checked as well. You may have purchased a car that was returned back to stock and the previous owner still has a tune on it that is making you car act funny.
pro934 is offline   Reply With Quote
Old 01-19-2009, 10:02 PM   #3
skimobile
Member#: 92114
03 WRX Bugeye
2.61L Hybrid Track Toy
IACV is good to clean out but I'll bet a paycheck that the problem you are referring to is the result of the Cruise Control cable pulling on the throttle body.
If you follow the cable to the firewall on the passenger side you'll see the black pastic box of the control unit. This unit distorts slightly under heat and pulls on the cruise contol cable, causing the problem you refer to.
The easy fix is to make sure you increase cable slack on the cruise control cable at the cable adjustment point on the throttle body. Again, that is the PASSENGER side cable on the top of the throttle body. Just loosen the jam nut, adjust the cable to increase slack and retighten the cable adjustment & jam nuts.
I had the same exact problem and it never returned after slack was added to the cable.
skimobile is offline   Reply With Quote
Old 01-19-2009, 11:05 PM   #4
GUN-IT
Member#: 199693
2005 STI
Crystal Grey Metallic
Clean your MAF sensor with MAF sensor spray cleaner. It may be throwing your computer if it's too dirty and causing it to run rich...........
GUN-IT is offline   Reply With Quote
Old 01-20-2009, 10:46 AM   #5
subeerex
Member#: 87430
02/5 BugEye-Peanut
Sedona Red Silver
MAF/IACV the most likely causes. These are sencitive buggers!...they don't take much.
subeerex is offline   Reply With Quote
Old 01-20-2009, 11:38 AM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
2001 2.5 RS/70 Van
02 WRX Rally Stud
Front 02 sensor beginning to fail will also cause these symptoms.
Old 02-03-2009, 01:45 PM   #7
scooter4483
Member#: 71834
2005 WRX w/ premium
WR Blue
i wanna try this first as i have the stop and go traffic idle go up to 2k rpms. how do i do this? any pictures?
scooter4483 is offline   Reply With Quote
Old 02-03-2009, 02:04 PM   #8
WMCCook29
Member#: 152685
2005 VF34 WRX Wagon
Here's a photo of what you need to adjust (bottom right corner, the actual jam nut is just out of the picutre): http://69.213.167.230/tr/wrx/images/...L/P8160014.jpg
WMCCook29 is offline   Reply With Quote
Old 02-03-2009, 02:12 PM   #9
p2adan
Member#: 176574
2008 2.5i
When driving my 08 2.5i while slow rolling in 1st with the clutch in, it would rev the RPM's to about 2.5k. I think this was intentional so that when you engage the gears again there is less wear on the tranny/differentials. Correct me if I'm wrong, but it could be something else as well.
p2adan is offline   Reply With Quote
Old 02-03-2009, 02:18 PM   #10
1sicWRX
Member#: 104631
99 911 Carrera
03 Land Rover Disco SE7
Clean MAF, clean IACV, check functionality of the a/f ratio sensor(front 02) put stock air box back on...
1sicWRX is offline   Reply With Quote
Old 02-03-2009, 02:35 PM   #11
dauss
Member#: 108369
2005 CGM WRX Wagon
68HTA
Head to the dealer and get the recall fixed.
dauss is offline   Reply With Quote
Old 06-05-2009, 09:45 AM   #12
scooter4483
Member#: 71834
2005 WRX w/ premium
WR Blue
how do u give the cable slack? based off the pic, what is the point of losenning that nut on that clamp? i read the recall is for when the cable in the lever gets loose not what i have going on.
Idle jumps to 2000 in stop and go traffic... Synx Factory 2.0L Turbo Powertrain 32 10-19-2009 03:25 PM
shift fork gets loose when car is in stop and go traffic? rougeben83 Transmission (AT/MT) & Driveline 3 06-02-2009 12:21 PM
How do you drive in stop and go traffic? Ken Off-Topic 49 09-26-2007 01:56 PM
high engine idle after stop & go traffic nocturn Factory 2.0L Turbo Powertrain 14 10-14-2005 11:52 AM
stop and go traffic for miles on end -- arrival of smelly clutch Xymox Newbies & FAQs 20 08-25-2005 03:56 PM
Message Board Statistics All times are GMT -4. The time now is 02:19 PM.
