Old 04-03-2002, 07:17 PM   #1
FastRS
Member#: 13265
04 Sti
Default Misfire CEL on EJ22T w/ 2.5 heads???
does anyone else out there running the turbo legacy block with 2.5 heads and legacy turbo plugs have problems with a CEL code for misfire? if so do you know what causes it? thanx.
FastRS is offline   Reply With Quote
Old 04-03-2002, 10:52 PM   #2
adamsrs
Member#: 3768
I am going to be running this setup after tomorrow, I'll get back to you!
adamsrs
adamsrs is offline   Reply With Quote
Old 04-04-2002, 03:25 PM   #3
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
05 Legacy GT 06 Armada
Do the coolent channels in the heads match up with the ones in the block? Also does the mounting face of the cylinder head provide a close enough fit to the block to not be problematic?
MY99 2.5GT is offline   Reply With Quote
Old 04-04-2002, 05:52 PM   #4
adamsrs
Member#: 3768
supposedly they mount together perfectly! Many people have dont this swap. Please keep up posted though!
adamsrs
Sanity check: multiple CELs on Phase 1 2.5 jonesboy Normally Aspirated Powertrain 3 01-16-2008 12:45 PM
more heads on the way-2.5 heads for sale-valve timing input needed ssspoon Factory 2.0L Turbo Powertrain 1 07-08-2002 06:55 AM
Boost vs power ej22t w/2.5 heads mikeje Normally Aspirated with bolt-on Forced Induction Powertrain 4 10-21-2001 02:11 AM
99 2.2 vs 2.5 heads on EJ22t block mikeje Normally Aspirated with bolt-on Forced Induction Powertrain 4 10-21-2001 12:28 AM
what compression is 2.5 heads on EJ22T Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 17 08-07-2001 06:41 PM
Message Board Statistics All times are GMT -4. The time now is 06:37 PM.
