Old 01-20-2009, 12:39 PM   #1
Silver Bullet 2.0
Member#: 89508
2001 RSTi w/PPG
tightness. hella un-flush
Default what offset with 8.5" wide wheel?
Probably a n00bish question but I couldn't seem to find this in any sticky or old thread.
I have coilovers so I believe that gives me a little more room to wiggle with, I am also trying to avoid fender rolling but I don't know if it is possible with this width. I would really like to squeeze an 18" diameter wheel, but if 17" is my only option I'm fine with that in order to avoid fender rolling.
Any help is appreciated - thanks
Silver Bullet 2.0 is offline   Reply With Quote
Old 01-20-2009, 12:43 PM   #2
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
what is your ride height?
and what size tire are you shooting to run?
generally for an 8.5 on a bugeye on coilovers without fender rolling you want to shoot for a +48mm or higher and a 225 or 235 tire.
although if you're really low you may be forced to either roll your fenders or choose a higher offset or raise the car.
WRX8XB is offline   Reply With Quote
Old 01-20-2009, 01:10 PM   #3
Silver Bullet 2.0
Member#: 89508
2001 RSTi w/PPG
I'm about an inch low in the back and 1.5 in the front.
If I get 17s I have some 245s I wanted to throw on.
I don't mind adjusting ride height if it is necessary.
Do you think 18's are out of the question?
Old 01-20-2009, 02:06 PM   #4
blackcompany
Member#: 143158
2007 STI
UGM
You have more room at stock ride height, but, I have done a bit of reading and question asking myself. Been told a lot of different things for offset, as fair as wheel height, I dont know why 18 would be out of the question, just changes tire thickness. 17's I would run 45 18's I would run 40. tires can get pretty thin, I've seen em at 35 but they get even smaller I'm sure.
blackcompany is offline   Reply With Quote
Old 01-20-2009, 02:09 PM   #5
ted dibiase
Member#: 94752
2003 wrx
wrb
I have 17x8 rpf1's, offset of +48, and I think the tires were 235/40/17. No where even close to rubbing anything.
ted dibiase is offline   Reply With Quote
Old 01-20-2009, 02:10 PM   #6
Silver Bullet 2.0
Member#: 89508
2001 RSTi w/PPG
do you have coilovers or stock struts?
Old 01-20-2009, 02:23 PM   #7
Silver Bullet 2.0
Member#: 89508
2001 RSTi w/PPG
^^ the reason I ask is because if you have that with stock struts I would like to think I could do 8.5s with my coils
Old 01-20-2009, 02:31 PM   #8
ted dibiase
Member#: 94752
2003 wrx
wrb
I have those upgraded subaru coil overs. It isn't a STi takeoff, but something that the dealer sold way back when I bought the car. Supposedly it lowers the car 1.25" and 1.5". I tried finding a pic, but it looks like they don't sell them anymore.
Old 01-20-2009, 02:34 PM   #9
MrSlowbaru
Member#: 129231
2005 wrx
cgm
17X8.5 you will prob want a 42 offset, you will most likely have to roll the fenders a little bit if you want to run anything larger than 245 with an acceptable amount of daily driver camber.
by the way, a 17x8 48et can run 245-40-17 and not rub with factory camber settings and being dropped with out coilovers.
MrSlowbaru is offline   Reply With Quote
Old 01-20-2009, 02:38 PM   #10
WRX8XB
Member#: 45323
Wink
17x8 +45mm or 17x7.5 +48mm?
a 235/40/17 is a bit short for a WRX but the taller gearing in the WRX isn't as badly effected as an STi.
OP what's the ride height? (measured from center of hub to fender)
camber settings?
as I said, ideally you want a +48mm. You could go to a lower offset if you were willing to roll the fenders. Also a 245 maybe pushing it on stock fenders, unless you're at ~14" rear ride height.
and 18s or 17s don't matter as you just need to make sure you get the right profile tire.
do you have a wheel picked out?
I know of a set of 18x8.5 +48mm wheels for sale PM me if you're interested.
Old 01-20-2009, 02:41 PM   #11
ted dibiase
Member#: 94752
2003 wrx
wrb
17x8 +45
I'm probably spewing all kinds of non sense. They might actually be 245/40/17. I tried to squeeze the biggest tires that I could onto the car. I think it was pretty close to stock height too.
Old 01-20-2009, 02:52 PM   #12
Silver Bullet 2.0
Member#: 89508
2001 RSTi w/PPG
I'm at 13" ride height. I can't remember my camber settings though
Old 01-20-2009, 02:53 PM   #13
Silver Bullet 2.0
Member#: 89508
2001 RSTi w/PPG
I want the 18 x 8.5 rota grids
Old 01-21-2009, 03:44 PM   #14
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
17x8.5 ET48 with 245/40/17's cleared my stock struts no problem. I had to roll my fenders, but I have a wagon.
bluescoobywagon is offline   Reply With Quote
Problem with 255's on 8 inch wide wheel? import111 Tire & Wheel 40 12-12-2005 06:22 PM
Re070's fit 8.5" wide? Mrfairlady Tire & Wheel 2 08-11-2005 12:00 AM
Need 8.5" Wide wheels for STI Redneck Ricer Tire & Wheel 6 09-09-2003 09:46 PM
cheap 8.5" wide rims ellisnc Brakes, Steering & Suspension 0 10-24-2002 07:56 PM
8.5" wide wheels on a gc8? RuCKuS Brakes, Steering & Suspension 2 08-14-2002 02:36 AM
