Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Closed Thread
Old 01-20-2009, 02:07 PM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default RCE swaybars are in stock. RCE coilovers, springs etc. are also in stock
RCE swaybars have finally arrived.
Here are the specs:
Racecomp Engineering 04-07 STI swaybars
We didn't try to reinvent the wheel here, just provide another option for GD STi owners looking for a swaybar set that will work well with stock springs, lowering springs, or coilovers. The settings for the front bar are 25.5 and 28.5mm, rears are adjustable from 25.5, 27.0 and 28.5mm. So you could run these and not have to go to a bar that is actually 27mm thick.
Specifications:
25.5mm physical diameter
4142 Chrome Moly
Heat treated and cold finished.
Ends are hot forged on a 125 ton press.
Front and rear adjustable.
Washer tabs on front and rear to prevent walking
Purchase front and rear bars-$499
Swaybars purchased individually will be $260/ea.
Racecomp Engineering GD Chassis Lowering Springs
Spring Rates and Drop:
295/275 23/20mm - Yellows
285/269 15/10mm - Blacks
278/259 30/15mm - Wagons
$389/set
RCE Tarmac Zero
Racecomp Engineering Tarmac Zero Coilovers, our new more affordable coilover entry based on our highly successful RCE Tarmac 2s.
Built by KW Suspension in Germany to our specs, these use the same high quality stainless steel corrosion resistant construction as our RCE T2s.
The difference here is our Tarmac Zeroes have preset damping that maximizes both performance and ride quality. This allows the end user to just put them on and drive without worrying about playing with too many adjustments. It also keeps them more affordable. Ride height is still adjustable of course.
Linear spring rates:
400 lbs/in front
340 lbs/in rear
Front and rear helper springs included. Can be used with camber plates or Group N strut top mounts.
$1950/set
Racecomp Engineering Kool Brake Kit
This kit was designed to cool and vent the braking system, thus reducing rotor temperatures. Initial testing at Summit Point Raceway showed up to a 200 F drop in rotor temperature when using aggressive pads. Testing was done with Pagid Blue RS-42, Pagid Yellow RS-19 and the new RS-29 brake pads. Designed to work with both stock STi rotors and any aftermarket 2 piece rotor, this kit is available now.
The Kool Brake Kit includes 12 feet of high quality, motorsport grade, high temperature hose far better then other options on the market. There is no need to upgrade. Stainless steel hose clamps are also included.
The RaceComp Engineering Kool Brake Kit is now exclusively offered in dry carbon fiber to improve unsprung weight savings. The spindle ducts are considerably lighter then the OEM dust shields that are replaced during installation.
Current applications are 2004-2007 STi.
$459/set
Whiteline Suspension is also available
Full selection of suspension parts for GD and GRB chassis.
ALK, swaybars, roll center kits, endlinks etc.
__________________
[CENTER][CENTER][SIGPIC][/SIGPIC][/CENTER][B][I][COLOR="Red"]"We do pricing a little differently. Every price you see includes the shipping cost to our office(Surrey, BC), duties and exchange rate . This creates a built in cost savings, no hidden fees, and less hassles. The best part is we still have a price match guarantee!"[/COLOR][/I] [/B]
[COLOR=black]Service Center: 604 530 9160 [/COLOR] [COLOR=black]Email- [/COLOR]
[/CENTER]
dalesalignment&brake is offline
Closed Thread
Can anyone tell what type of springs these are? lotarg Brakes, Steering & Suspension 5 06-04-2010 03:28 PM
FS: (NJ) Ground Control Coilover springs 9" / 315 lb/in JZeezSTi Suspension/Brakes/Handling 6 11-29-2009 09:49 AM
WRX in STX (flipping coilover springs question) neuspeed Motorsports 39 05-12-2005 11:18 PM
Stock Wagon Struts/Springs/Top Hats, preferably in So Cal SC WRX Private 'Wanted' Classifieds 0 11-24-2003 06:00 PM
