Old 01-20-2009, 08:08 PM   #1
rice or die
Member#: 191034
1992 legacy turbo
Default 550cc using legacy ecu
ok so has anyone ran yellow 550cc jdm sti injectors on their 91-94 stock turbo legacy ecu? if anyone has, does it work? i heard it will run rich but how rich?
rice or die is offline   Reply With Quote
Old 01-20-2009, 08:25 PM   #2
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
It will not be nice.
i_c_the_light is offline   Reply With Quote
Old 01-20-2009, 08:47 PM   #3
rice or die
Member#: 191034
1992 legacy turbo
have u done it before?
Old 01-20-2009, 09:03 PM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Odds are this....
Idle will be crap. 550 injectors are 1.5 larger. The ecu can trim back about 20-25%.... So you will be too rich at idle. Normal driving around may be drivable, horribly rich, but drivable. Then at WOT you will be about 8-1 AFR as the stock ECU is notorious for being 10-1 AFR on just 370 cc injectors!
So find some JDM 440 and call it good, or get an emanage or PerfectPower6. Then you can run the 550s no problems.
Old 01-20-2009, 09:17 PM   #5
rice or die
Member#: 191034
1992 legacy turbo
dang cuz i have a set of good 550's sitting here!
Old 01-20-2009, 09:26 PM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Want to trade them for some 440s?
Or just buy a PerfectPower6. You can find them used for 200-250. Then SAFELY boost higher (after tuning) AND get better milage in general.
Old 01-20-2009, 09:45 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Like Doug said, my Ej22T ECU ran 440's just fine. I don't think I would want to try to run 550's on that ECU. I ran slightly rich at idle and didn't get great mileage. I bet the car would barely run on 550's.
Old 01-20-2009, 09:46 PM   #8
rice or die
Member#: 191034
1992 legacy turbo
lol i know that the 550's is more rare and expensive then 440's
i got an ej20 twin turbo short block for sale, i got alot for sale heres my c-list add http://seattle.craigslist.org/see/pts/996705993.html
Old 01-20-2009, 10:33 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i don't think there any jdm yellow injectores ..
the ej20k are 480s
Old 01-20-2009, 10:40 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
If they really are 550's then they are later and not compatible with your fuel rails anyway.
As for their value I have to disagree with you. Most of the upgraded injectors are worth about the same. 440's 480's 550's. Injectors are injectors. You may consider them rare but those of us who have been around a while know where to buy these sorts of things and just need to pick up the phone or send an email and we'll have a set coming. It's nothing personal and isn't meant as an insult. It just helps to know your audience if you are gonna make a comment like that.
Old 01-20-2009, 11:20 PM   #11
rice or die
Member#: 191034
1992 legacy turbo
well i just seen price differences from the greys and yellows and people saying yellow are more rare, that is why i said that, but it sounds like i was wrong so my bad. but yeh they are yellow side feed that fit into my 92-94 n/a rails, i belive they are 550 and i really need a set of 440's because i really want to run more psi
Old 01-21-2009, 09:01 AM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
Where did you get them?
Old 01-21-2009, 09:37 AM   #13
linsavy
Member#: 11620
1997 GF4-STiV3 clone
I have a set of grey 440s from my EJ20K. Recently cleaned by pro shop. Make me an offer.
linsavy is offline   Reply With Quote
Old 01-21-2009, 10:25 PM   #14
rice or die
Member#: 191034
1992 legacy turbo
i got the 550's off a ej20 twin turbo motor. and i dont have money right now to buy 440s so id only be able to trade things for them such as my 550's
Old 01-21-2009, 11:08 PM   #15
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I bet those are 440s....... there are yellow STI USDM 550s, and then there are Yellow JDM 440s.... Someone correct me if I am wrong.
I would install them and just see how it runs.
Old 01-22-2009, 02:07 AM   #16
rice or die
Member#: 191034
1992 legacy turbo
my yellows look EXACTLY the same as these
http://cgi.ebay.com/SUBARU-IMPREZA-W...3286.m63.l1177
Old 01-22-2009, 10:05 AM   #17
Matt Monson
Member#: 832
99 2.5RS, '85 911
Nope. You are correct and thus why I asked the question. I suspected all along that these were 440's, and they are.
Old 01-22-2009, 10:59 AM   #18
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
NO!!!!!!
pintle greys (ej20g/ej20h)are 440
pintle yellows (ej20k/ej20r) are 480
ball yellow (ej2555/7 -usdm sti)are 550
those numbers are at from tests at 2.5 bar(some strange down under method) vs 3 bar (correct testing pressure)
only thing i am not sure of is the ej207/ej208 yellows ..i assume they are still 480cc
Old 01-22-2009, 11:44 AM   #19
Matt Monson
Member#: 832
99 2.5RS, '85 911
I still believe that pintle yellows are 440, contrary to the information you have put up. Call me stubborn.
So, what is missing from that list is the ball yellows from v5/v6 Ej207 that I have sitting in my garage. I believe that those are the 480 yellow tops.
Old 01-22-2009, 03:24 PM   #20
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
Would the yellow 440 99WRX injectros drop in to my 91SS without swapping out my fuel rails for N/A rails?
maciek is offline   Reply With Quote
Old 01-22-2009, 06:39 PM   #21
rice or die
Member#: 191034
1992 legacy turbo
well the yellows will go into the rails but wont seat properly because the rails that i pulled my yellows off of had the same style as my stock ej22t. on the rails i pulled off my yellows the fuel line goes straight into the injector seats, it doesnt have the male and female connections.
Old 01-22-2009, 07:09 PM   #22
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Originally Posted by Jaxx View Post
NO!!!!!!
But that's what we measure them here downunder and that's what we refer to them as.
Old 01-23-2009, 08:12 AM   #23
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
It will not run good at all! It wont even start! It will be the worst thing ever for your car! ........
So wanna trade for my gray 440's?...
... since yours will allow me to get an additional 40hp out of my tdo5
blkgm8 is offline   Reply With Quote
Old 01-23-2009, 11:13 AM   #24
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
stubborn-just using the ol knoggin .. the down under folks refer to the yellow pintels as 440(at 2.5 bar) and the greys as 380 ..
i want to send at least one of my yellow pintels off to be tested so that i can can have an accurate % increase for my 650s
yeah but its really annoying since EVERYthing here (and japan) is measured at 3bar
Old 01-23-2009, 11:56 AM   #25
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
You know what I'm going to do from now on everytime someone mentions injector flowrates...
Can I use my AP cable (not married) to check a CEL code on my 04 sti using open ecu?? OneArmedScissor Open Source Reflashes 4 09-16-2008 01:30 PM
Sti pink injectors 550cc used for 8k BlackMagic*Club5 Private 'For Sale' Classifieds 6 02-27-2006 05:51 PM
Want a Used Legacy, read this Used car review. Diabolical1 CC News & Rumors 2 11-22-2005 09:01 AM
Wanted- FMIC New/Used and ECU New/Used fpr STI TimL Private 'Wanted' Classifieds 1 12-20-2004 12:07 PM
MY00 Legacy ECU same as MY00RS? Jason Normally Aspirated Powertrain 3 02-19-2001 12:41 AM
