Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-03-2002, 09:47 PM   #1
imprez25
Member#: 12479
1997 Jeep Cherokee
Default RPMs drop when thottle is pressed
When I give my 98 rs gas the rpms drop and then the engine revs up. I drove another 98 with the same mods as mine and it did not do this. I was wondering if it could be a problem with the timing. I replace the spark plugs hopping to solve the problem but it did nothing. It seems like it is missing and my gas mileage is not what i want it to be or what I think it should be.
Any help would be great
thanks
shaun
imprez25 is offline   Reply With Quote
Old 04-03-2002, 10:23 PM   #2
grimlock
Member#: 2683
2011 STi 5-Door
Does it only really start to pick up when you floor it, or is there just a little hesitation when you first press the gas? If it only feels good when you floor it, you may have a bad O2 sensor.
Ross N.
grimlock is offline   Reply With Quote
Old 04-04-2002, 04:32 PM   #3
imprez25
Member#: 12479
1997 Jeep Cherokee
it just happens when I first press on the gas, then it is fine.
Old 04-04-2002, 05:47 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
still have oem plug wires?
Jay
Old 04-04-2002, 06:22 PM   #5
Teh Legacy
Member#: 9853
to keep your mouth
shut.
yeah, it either sounds like a timing problem, or plug wires. if you have access to an engine diag computer, then i'd say put it on there so you know there's not something more seriously wrong with it.
Teh Legacy is offline   Reply With Quote
Old 04-04-2002, 08:27 PM   #6
imprez25
Member#: 12479
1997 Jeep Cherokee
I still have the stock wires, but I have changed the plugs (Denso's). I don't think anything is majorly wrong. It seems like it may be a timing issue. I know it has distributerless ignition, how do I check the timing? Set it?
Passenger Bogs when clutch is pressed HELP! Carbon888 General Community 52 12-27-2005 02:05 AM
large rpm drop when shifting uphill hybrid gti 2 Normally Aspirated Powertrain 7 11-11-2005 06:12 PM
RPM drops when WOT near 5000rpm viodea Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 08-26-2003 03:03 PM
Noise when clutch is press in neutral? MrWRX2 Warranty Issues & SOA Problems 5 03-30-2002 03:58 PM
Installed Cobb CAI, rpm drop when shifting? tymax Normally Aspirated Powertrain 5 03-22-2002 03:09 PM
