#1 |
Member#: 67371
Vehicle:05 BUILT 2.4L STI |
Here are some old videos from the car...
http://videos.streetfire.net/video/L...Eye_380382.htm Best time on the old set-up: 9.40 @ 149 Some details from the old set-up: Built EJ25 (by Freedy Estrada) Hydra 2.1 (tuned by Junot) GT40R Stock STi 6 speed And so on... The new set-up is coming along well... Changes: New Turbo!!! Hydra 2.6 (sponsored by Element Tunning) So far the car made 708WHP @ 34 psi (3rd gear o a Dynojet). This was just to check everything was running right with the new Hydra. Then a new dyno run was made, this time in 4th gear with a little bit more boost... unfortunately the stock 6 speed broke 4th gear at 6,200 rpm. At that point (6,200RPM) the car had 749WHP and like always... this run was made running all boost. The goal is to reach 800WHP at 38-40 psi and keep improving those times. Dyno graph and videos coming soon (as soon as it happens ) BTW- With 604WHP this car ran high 9's so this is not your typical high reading Dynojets. Stock Sti's and Evo's make 225-230WHP on this dyno. EDIT- NEW NUMBERS!!! 800WHP!!! ALL BOOST SAE Uncorrected STD Dyno runs are done in 4th gear. Let's see if it holds for Wednesday when the RRT will take this car to the track!!! ![]() ![]() ![]()
#2 |
Member#: 105814
NWIC
Vehicle:two V8's.. 'murica |
How much does the car weigh?
#3 |
Member#: 84482
Vehicle:2005 STI.UR gt4088r E85 pro comp sti |
wow thats sick....it broke the 6 speed....i can't believe that
#4 |
Member#: 143158
South East
Vehicle:2007 STI UGM |
awesome, is it a super late booster? judging by what I could see I wonder how much is left of the interior...what class you run?
#5 |
Member#: 82612
Vehicle:'02 WRX - Sold Now 2013 WRX |
This is not far off from being the fastest stock 6spd world-record time!!
I beleive the fastest is held by a Supra running about 8-sec flat currently. |
#6 |
Member#: 109527
Vehicle:1997 GC8 8.38@165Mph blue |
Damm! the Boys from PR rule
#7 |
Member#: 67371
Don't know the exact weight but close to the typical GDB with weight reduction (stock parts replaced by lighter parts) then add a cage, 6 speed and few other things. This is still a street car "glass, full interior and so on"
I'll say somewhere around 2900-3000 lbs with driver. But that's just a guess . |
#8 |
Member#: 145585
Vehicle:2002 S202 Yellow |
Wow, that is crazy power. What are you going to do about the gearbox?
#9 |
Member#: 101691
Vehicle:09 G37x coupe SOLD - 35r bug/hawkeye |
i could not imagine getting to 149mph in the quarter mile..thats crazy...im at 126(and thats considered kinda fast) gotta love bugeyes..keep up the good work...whats going in it now? 6spd ppg? or getting into a 5spd ppg box and save some weight?
#10 |
Member#: 81102
awesome stuff
#11 |
Member#: 132130
TXIC
Vehicle:2002 Ford F-150 Graphite Gray |
why do puerto rican cars go fast?
its not like they're even talking **** either, they come here and still lay down the law big valleys sti was drove to the race where it beat dynoflashes evo....that dope as hell! |
#12 |
Member#: 67958
Vehicle:MY96 Time Attack and 06 STI daily |
It's pretty disheartening to see more people breaking the stock 6 speed, but hey...that's what happens when you make power. Keep it up!
#13 |
Member#: 114631
Vehicle:2007 11.5 @ 118 Stock Turbo Record Holder |
This is why I had a Puerto Rican tune my car, Junior FTW!!! For some reason tuning just seems to be in their blood.
#14 | |
Member#: 114631
#15 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
"World Quickest and Fastest bugeye WRX gets even better!" ![]() why does everyone need a title? So whats the difference between a GDB WRX and GDB STi once you gut it and put an ej257 and a 6 speed in the wrx? i thought evos were always teh l33t fAs3tAr3st? |
#16 | |
Member#: 67371
![]() I know it going to be tough (the gearing don't help) but if it can do a low 9's or even a high 8's pass on the stock gears that would be awesome. The previous 6 speed had hundreds of launches... but then again it was 4th gear that let go... You could always strengthen the stock gears... but eventually a PPG 6 speed would be awesome! A PPG 5 speed is not an option... it just lacks the strength to hold 600+ lb/ft of torque. BTW- I think the limit of the stock 6 speed is somewhere around 600 lb/ft of torque (which is amazing) when is mounted in a 3000 lb car. |
#17 |
Member#: 165206
Vehicle:2006 WRB DPSti w/ white shoes |
#18 | ||
Member#: 67371
... Anyway the title is just that... the title (And it sounds awesome too ) The point is, it gets you to look at the thread. And since this is PPB let's just show one of the premier subies to the community.Quote:
#19 |
Member#: 36033
SCIC
the engine and tranny are what make it an STi over a wrx...
So its has the same chassis as teh STi, it has an STi motor, and an STi tranny......but we're gonna call it a wrx so we can say its the fastest..... i really dont care....i just find it amusing... I'd rather say "we have the 5th fastest wrx/sti in the world" than make some subcategory that puts you at #1.... i mean in the top 20 each one of them could be #1 something...jdm, edm, adm, usdm, 5 speed, 6 speed, wrx, sti, gc8, nos, all boost, fat driver, girl driver, hairy ballz, etc |
#20 |
Member#: 101691
Well if a gc8 had an sti swap or whatever else and it was the fastest/quickest, then the title would be "the worlds quickest and fastest gc8"
there is nothing wrong with the title. its exactly what it is |
#21 | |
Member#: 36033
SCIC
which is what im saying. if you took the drivetrain outta a gc8 sti and put it in a gc8 2.5rs are you gonna call it the worlds fastest 2.5rs when you're using an STi drivetrain in the same chassis that the STi rides on? The thing is they cant say "worlds fastest GDB"......which is what i was getting at. the drivetrain IS the difference between all the models that ride on the same chassis. so if you put an STi drivetrain in a wrx....you essentially have an STi. Just because you buy the STi drivetrain yourself and put it on the GDB chassis instead of having them do it at the factory doesnt make it not an STi. Last edited by Phatron; 01-21-2009 at 01:17 PM. |
#22 |
Member#: 165206
#23 |
Member#: 142011
International
that's an awesome car!!!
#24 | ||
Member#: 67371
An STi is a little more than an Engine + tranny. What about the brakes? The aluminum suspension? The Wider track, the extra caster, wheels, rear end, interior and so on. Yeah the engine and transmission is the biggest thing but again if you swap a B18C engine to a Civic would that make it an Integra? You know just saying...
Anyway don't get wrap up in things like that! It's just a title man. ![]() Last edited by Speed; 01-21-2009 at 01:38 PM. |
#25 | ||
Member#: 36033
SCIC
zero? Last edited by Phatron; 01-21-2009 at 01:54 PM. |
| Thread Tools | |
| Display Modes | |
| MINI USA and ABF PERFORMANCE Partner to Build the World's Quickest and Fastest Drag-r | AVANTI R5 | Non-Subaru News & Rumors | 5 | 08-22-2008 09:16 PM |
| NOPI Texas Fastech WRX Quickest and Fastest No Nitrous WRX in the USA VIDEO | evorace1 | Proven Power Bragging | 36 | 05-03-2007 07:04 PM |
| Which STi is the quickest and fastest? | turboup | Proven Power Bragging | 27 | 10-24-2006 12:28 PM |
| Colorado's new quickest and fastest WRX. | pace | Proven Power Bragging | 77 | 09-28-2002 12:30 AM |
