Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 01-21-2009, 07:25 PM   #1
P&L Motorsports Inc.
Vendor Sales Rating: (26)
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Default P&L Motorsports, built shortblocks, rotated turbo kits, and other power goodies!
This thread will be re-opened when new parts are available. For any questions please contact us via Private Message!
P&L Motorsports Race Application Oil Pump - EJ Series
[PL-Sub0040]
Our P&L upgraded oil pump starts life as an OEM 2008 Subaru STI pump. These 2008 STI oil pumps are 11mm in OEM form which we hone out to outperform a 12mm (the JDM oil pump!) The flow characteristics have also been modified to allow the most unrestricted oil passage.
Included Parts
  • Modified Brand New OEM 11mm Oil Pump from 08 STI
  • All Necessary Brand New OEM Bolts
  • Brand New OEM Oil Pump Seal
P&L Online Store - Buy it HERE!
$279.95
We were able to get our hands on some Fluidampr dampers that have JUST been released for the Subaru EJ motors. These things are ultra high quality, and can help keep that built motor of yours in tip top shape! Cheap insurance for your motor FTW!
A good aftermarket damper protects your crank. Fluidampr is in a class all by itself, because it is designed to provide maximum control of all engine harmonic vibrations, regardless of the rpm at which they occur and regardless of the crankshaft's natural frequency. This translates to maximum protection of the crank, main bearings, related engine components and more consistent power output. Also, Fluidampr is maintenance and repair free. Fluidampr is effective on both race and street applications.
$348.99
__________________
[B]P&L Motorsports[/B]
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
P&L Motorsports Inc. is offline
Old 01-21-2009, 07:26 PM   #2
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
P&L Motorsports Air Pump Block Off Plate Kit - 06+ WRX & 08+ STI
[PL-Sub0028a]
Included in our P&L Motorsports Air Pump Block Off Plate Kit for the 06+ WRX & 08+ STI is as follows:
  • 1 Round Plate
  • 1 Arrowhead Plate
  • 4 Allen Head Bolts
  • 2 OEM Metal Gaskets
$29.95
P&L Motorsports Air Pump Block Off Plate Kit - 07 STI
[PL-Sub0028]
Included in our P&L Motorsports Air Pump Block Off Plate Kit for the 07+ STI is as follows:
  • 1 Round Block Off Plate
  • 2 Allen Head Bolts
  • 1 OEM Metal Gasket
$14.95
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 01-21-2009, 07:26 PM   #3
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
P&L Motorsports AVCS Line Kit - Braided Stainless Steel
[PL-Sub0028]
Some highlights of the new AVCS lines:
• Extensively street and track tested on multiple platforms
• Direct plug and play install that is easily reversible
• 100% maintenance free
• Stainless steel braided lines
• Leak free Banjo and AN fittings
• -4 lines for improved oil flow
• A must for track use and cars with hardened motor mounts
$84.95
P&L Motorsports Head Breather Adapter -10AN or -8AN Fitting
[PL-Sub0021]
P&L Motorsports' Breather adapters were developed in conjunction with our drag race program. Nitrous and high boost (30+ PSI) applications will typically have engines built "loose" to handle the incredible amounts of piston expansion seen in forged applications. The unfortunate by product is blow-by. If the factory lines are capable of venting in the first place, they usually blow right off causing an unbelievable mess, and potential for oil fire, etc.
By moving to a dedicated, AN connection, all those fears are eliminated in an elegant package.
These Breather Adapters are currently designed to work on a non-AVCS WRX head.
P&L Online Store - Buy the -10AN HERE!
P&L Online Store - Buy the -8AN HERE!
$79.95
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 01-22-2009, 04:25 PM   #4
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
P&L Motorsports Power Steering Line - Braided Stainless Steel
[PL-Sub0026]
This line upgrade is a very desirable to those looking to use a variety of intake, inlet and intercooler setups. Manifold reversal modifications are simplified by the flexibility this line allows.
Our Stainless Steel Power Steering Line upgrade features:
- AN fittings for proper seal and ease of installation.
- The hose assembly itself is made from the highest quality braided line.
- Over engineered design and materials will allow a lifetime of service even under multiple times more hydraulic pressure than what you will ever expect on your vehicle.
- Replaces the high pressure line for the Power Steering System.
- Form following function, the aesthetics and clean installation appear OEM in several aspects.
$99.95
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 01-26-2009, 08:56 PM   #5
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Moroso Oil Pans - $649
Moroso has been a long time standard in quality performance oil pan manufacturing. Countless hours of R&D and real world racing tests go into the performance minded designs of these hand crafted pans.
The Subaru EJ series motors are the latest to receive an upgraded oil pan unit from Moroso. These baffled, wet sump pans are designed to provide ample oil pressure under the hardest motorsport conditions.
Included along with the oil pan is a brand new oil pick up and pick up tube with stabilizer bracket. The stock oil pick up tubes have been known to BREAK due to poor factory welding, so this is a must have upgrade to those who wish to preserve the life of their motors.
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 02-17-2009, 12:32 PM   #6
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
P&L Motorsports 13mm Headstud Kit - DOHC EJ Series Motors
[PL-Sub0043]
FOR IMMEDIATE RELEASE:
Click for large version
P & L Motorsports 13mm Headstuds were engineered to provide increased clamping force for high boost and high compression engines. A must for those running more than 30psi and 9:1 compression ratios. We have tested these on our 900hp drag car up to 45psi with no head gasket failures. Whether you're building a street monster or a high performance race engine, these are a must.
Specs:
• Made from ARP2000 material.
• Capable of achieving clamp loads in the 215,000-220,000 psi range.
• 13 mm body diameter. (3.6 mm more than current ARP stud)
• 110 ft/lb torque spec.
• Larger 24.5 mm/o.d. washer for increased clamping area.
• Broached hex on top of stud for easy install.
• 2 taps provided for ease of installation. (starter and bottoming)
Kit includes:
• 12 studs ,nuts, washers.
• 2 taps.
• Install instructions.
• Molly lube.
Applications:
• EJ series DOHC engines US/JDM/EURO spec.
Note: Block and Cylinder head must be drilled and tapped. Professional installation by machine shop is highly recommended.
$399.95
P&L Online Store - Buy It HERE!
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 02-26-2009, 06:02 PM   #7
ShugSTi
Member#: 187128
Is there anything you guys don't think of!
ShugSTi is offline
Old 03-02-2009, 11:06 PM   #8
mdunkley43
Member#: 96193
2004 WRX
Java Pearl
do you have a complete power steering line replacement kit ?
mdunkley43 is offline
Old 03-03-2009, 04:12 AM   #9
xANDRESx
Member#: 178979
i just did a ej257 shortblock swap in to a wrx. with stock wrx heads.
wicht oil pump do you recomend me to use?
xANDRESx is offline
Old 03-03-2009, 04:13 AM   #10
xANDRESx
Member#: 178979
i need one but i dont know if the 11mm modified is too much ?
can you shipped to costa rica?
xANDRESx is offline
Old 03-05-2009, 08:45 PM   #11
mdunkley43
Member#: 96193
2004 WRX
Java Pearl
these guys ever check their own threads ? Anyone else receive a response ?
Old 03-06-2009, 01:11 PM   #12
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Well....... Thee are a couple more things, see the post below.
Unfortunately just the High pressure one. The return really is tucked out of the way and never leaks.
I do apologize weve been a little behind on the forum responses. Between 6 forums and pm's it gets a bit much sometimes.
If you are using stock heads and do not plan on reving past 7000k a stock 10mm or 11mm pump will be sufficient, with the 11mm having a greater flow output and being the better choice.
What engine set up are you running?? If you have a 2.5L and plan on racing/ driving the car hard or have a upgraded turbo set up ,this pump is a must.
We can ship world wide. Using fedex,ups,usps,dhl,bax global
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 03-06-2009, 01:29 PM   #13
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
P&L Motorsports/RAW 08-09 STI Dual AVCS Camshafts manufactured exclusively by Kelford.
(PL-Sub208)-(PL-Sub208a)
Description:
Everyone wanted them... so leave it to P&L Motorsports and Raw Performance to deliver!
Over the past couple of months we have been doing some behind the scenes testing with a new AVCS camshaft system for the new '08 STI. They're impressive to say the least. We won't release too much technically, as we're still doing some pretty serious testing in terms of just how far you can push these high duration, high lift cams, with AVCS tuning.
Needless to say, anyone who has run a Kelford product, knows they DELIVER. Plain and simple...
Specs:
Part#PL-Sub208
Adv. Duration @.25mm: int-264 / exh-264
Net Lift: int-10.75 / exh-10.25
Part#PL-Sub208a
Adv. Duration @.25mm: int-272 / exh-272
Net Lift: int-11.35 / exh-10.75
Kit Includes:
2 AVCS intake cams
2 AVCS exhaust cams
Tube of Cam Lube
Retail $1049
Available for pre-order here > http://www.pandlmotorsports.com/osCo...sort=2a&page=2
Note:Wait time approximately 2-3 weeks.
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 03-06-2009, 03:59 PM   #14
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
P&L Motorsports Signature Series Stage ONE short blocks - $2899.99
It was inevitable.
People have asked for years when we'd start releasing engines built to our own specifications.
After years of aggressive motorsport experience, it was a natural transition for us to apply what we've liked and not liked about the different specifications we've tried. What we have here is the beginning in P&L Motorsports staged series of Signature Series engines.
Stage 1 addresses the fundamental flaw in the latest generation of the 2.5L engine, the piston castings. We start off with a brand new 2.5L engine, and then proceed to FULLY disassemble the motor and verify clearances and component fitment.
We do MUCH more then simply drop in a set of pistons! All engines are case split, and all bearings, surfaces, and critical elements are hand measured, inspected, and fully blue printed! We then machine and hone all cylinder bores to match the exact specifications for our pistons.
Your fully blue-printed engine is then custom fitted with forged alloy pistons custom manufactured by CP, for us. To top everything off, all piston skirts are fully coated for maximum engine performance and cylinder component life.
Specs:
* New Subaru 2.5L engine
* Case split and disassembled to inspect all critical surfaces and bearings
* Fully Blueprinted
* Fully machined and honed cylinder liners to assure proper piston to wall clearances and maximize engine life
* Bore specific, custom fitted pistons exclusively made for P&L Motorsports by CP Pistons
* Fully coated piston skirts for maximum cylinder bore component life
* Forged EJ257 Crankshaft
* Forged EJ257 Connecting rods
* CP High Performance Piston Rings
* 7500 RPM maximum rev-limit
Note: Recommend P&L Motorsports Modified Oil pump and ARP Engine Stud kit.
http://www.pandlmotorsports.com/osCo...roducts_id=509 <-- More details can be found on our shopping cart, here.
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 03-11-2009, 12:08 AM   #15
mdunkley43
Member#: 96193
2004 WRX
Java Pearl
Thanks for the response. Do you have any pics of this power steering line installed ? I managed to jack the metal hard lines going to the steering rack so i am thinking of replacing the whole thing.
Old 03-11-2009, 09:23 PM   #16
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Here's a little sneak peak... V4 of our 30/35R up-pipe. Schedule 40 Stainless anyone?
-Jorge
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 03-11-2009, 09:51 PM   #17
dudley123
Member Sales Rating: (7)
Member#: 120831
PIA Purpose Built -
SEMA-FullRace/HRE/Cosw.
longblock packages??
dudley123 is offline
Old 04-04-2009, 03:42 PM   #18
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
We can supply our stage 1 block either with cosworth heads , or we can get you set up with our own package.
Please pm us with the set up you plan or running and we can steer you in the right direction.
Paul
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 04-04-2009, 03:51 PM   #19
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Bump
We are proud to announce.
As of 4/6 we will have our Rotated 30r .82 and 3071r .63 turbo kits in stock and shipping within 2 days of purchase. No more waiting 3-4 weeks
Thank you to everyone that has been patient with past orders. There has been over 50 kits sold already.
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Old 04-21-2009, 09:35 PM   #20
Member#: 67199
07 8.8@171mph STI
97 RS 8.3@165mph
Thread will be closed for a bit. We're having a sale on GD Exhausts!
__________________
p: 847-678-4311
e:
[SIGPIC][/SIGPIC]
Closed Thread
Sbr 35r Turbo kit and other mods SeanCuttaz Engine/Power/Exhaust 15 11-04-2009 02:27 PM
P&L Motorsports built cars take 1st and 3rd in Modified AWD at Summit Point! P&L Motorsports Inc. Motorsports 9 08-20-2008 07:50 PM
WTB: Rotated Turbo Kit and/or Tial EWG michaeldover Private 'Wanted' Classifieds 0 03-16-2006 10:15 AM
Turbo Kit and other stuff for sale` USMARINE24M Private 'For Sale' Classifieds 5 09-14-2004 08:42 PM
ludespeed turbo kit and other misc stuff. garretwp Private 'For Sale' Classifieds 17 05-24-2004 05:26 PM
