Old 04-03-2002, 11:57 PM   #1
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
Question disconnect battery, but keep power to ECU?
Is there a power line that I can hook a battery up to in a WRX so that the ECU won't reset even if I disconnect my car battery?
bemani is offline   Reply With Quote
Old 04-04-2002, 01:00 AM   #2
fullyimprezed
Member#: 15770
2002 Impreza WRX
WR Blue Pearl
I've seen a little battery (9V), that is attached to a cigarette lighter plug. The idea is that you plug this into the cigarette lighter (or power plug), disconnect your battery, and it should keep critical items with power (radio, but only for station presets, clock, and the all important ECU). I have seen these around either on a web site such as IPD (www.ipdusa.com), or elsewhere. Don't be put off by the fact that IPD is a Volvo specialist, just hunt around the site.
fullyimprezed is offline   Reply With Quote
Toggle switched power to ECU? Ghost STI Electrical & Lighting 17 04-06-2010 12:19 AM
Before disconnect battery...should i switch to valet mode? rebbeach611 Car Audio, Video & Security 1 09-04-2006 07:32 PM
disconnected battery, does ECU need to re-learn? ihavebettersound AccessPort 4 08-10-2006 07:59 PM
no power to ecu marc l Electrical & Lighting 0 12-14-2005 03:57 PM
Necessary to disconnect battery for ECU swap? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-17-2004 01:35 AM
