Welcome to the North American Subaru Impreza Owners Club Thursday August 27, 2015
Old 01-22-2009, 04:43 AM   #1
2.5ReallySexy
Member#: 167943
Default Windshield washer sprayer Intercooler sprayer
04 WRX with Sti turbo, sti intercooler, Catless up pipe, catless down pipe, stock exhaust for now (trying to stay low key), 255 fuel pump. Running 8 psi till i can afford to get injectors and a V2 cobb access port.
Edit since everyone is so worried
I have a ****ing tune
I was thinking about how i really dont need my my passenger side sprayer so i wanted to take hose off and put a new sprayer and connect it to the sti air splittler and making it a intercooler sprayer what is your guys opinion on doin this? Any suggestions?
my issue would be using it would also spray the right one which i dont want so it would kind of be a losing both of them. Which i dont think would be a problem since i never use them
2.5ReallySexy is offline   Reply With Quote
Old 01-22-2009, 04:46 AM   #2
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
whoa dude. you need to get injectors and a tune asap. and at least a downpipe. you really really need a tune or accesport though man.
evan_impreza is offline   Reply With Quote
Old 01-22-2009, 06:01 AM   #3
2.5ReallySexy
Member#: 167943
maybe you did not read my post, I clearly said I have a down pipe, I did not ask about a tune so yeah stay on topic
Old 01-22-2009, 06:11 AM   #4
ano2186
Member#: 158938
05 wrx 18G
just get a water meth kit and be done with it i didn't think the intercooler sprayer helped any where as the water meth cools the air charge more efficiently
edit: and get that tune ASAP so you dont blow that thing up
ano2186 is offline   Reply With Quote
Old 01-22-2009, 06:19 AM   #5
2.5ReallySexy
Member#: 167943
I have a ****ing tune!
The meth thing seems spendy
Old 01-22-2009, 06:28 AM   #6
ano2186
Member#: 158938
05 wrx 18G
i just picked up a smc meth kit from one of the other users on here for $300 there are some good deals on used things on here
didnt know you had a tune saw that you were trying to get a APv2
Old 01-22-2009, 07:20 AM   #7
turd_ferguson
Member#: 114609
You can do what the previous owner of my car did and swap the wagon windshield washer bottle and control stick (whatever that thing is called attached to the steering column to control the windshield wipers ). The wagon has an extra pump for the rear window, so you can use that for an intercooler sprayer.
turd_ferguson is offline   Reply With Quote
Old 01-22-2009, 08:04 AM   #8
retreif
Member#: 162113
2011 WRX
Obsidian Black Pearl
It is my understanding the intercooler sprayer merely helps intercooler recover from heat soak faster. It will not make the intercooler provide colder air.
retreif is offline   Reply With Quote
Old 01-22-2009, 09:17 AM   #9
WRX216
Member#: 8027
2002 WRX sedan
Midnight Black
The sedan and the wagon use the same sprayer tank, the wagon just has an extra pump for the rear window. If you have the sedan, you can just get another pump and grommet. Drill the appropriate sized hole in the second unused boss on the tank, install pump and wire it to a switch (or what ever activation system you want to use) and voila waterspray. If I remember correctly around $30. HTH
Chris
WRX216 is offline   Reply With Quote
Old 01-22-2009, 10:20 PM   #10
timmy87
Member#: 200952
02 WRX
cobb accessport kicks ass! i need a pump and injectors though... someday
timmy87 is offline   Reply With Quote
Old 01-22-2009, 10:33 PM   #11
theguy
Member#: 144244
2006 WRB STi
www.CAMtuning.com
its not worth your time to spray liquid on the intercooler, it won't do much if anything for cooling purposes. just focus on getting the injectors in there for now. if you want to add meth/water injection later just do that but the effort to do what you want is too much for a gain of practically nothing.
oh yeah, get a tune!!
theguy is offline   Reply With Quote
Old 01-22-2009, 11:19 PM   #12
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Way to post a bunch of crap. Post your proof and then I'll post mine, I have $20 in paypal that says I'll win and you'll never reply back to this thread.
Old 01-23-2009, 02:53 AM   #13
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Are you really running Said setup in your info?
Ill toss in a few bucks also.
Marlons101 is offline   Reply With Quote
Old 01-23-2009, 03:00 AM   #14
2.5ReallySexy
Member#: 167943
So it is benificial then to do it then?
Old 01-23-2009, 03:37 AM   #15
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
lower IATs and raise octane? whats bad about that?
Old 01-23-2009, 10:05 AM   #16
XRWITS
Member#: 157870
0407 STi's
One Black, One White
Default Intercooler
Hey, You have alot of other things to think about before adding water to your intercooler.
First off you are running a STi turbo on stock injectors or a WRX with stock exhaust you need a tune man.
then I would look at some NOS I think you will need two of the big ones. but you need them by tonight so hurry (unless you car went above 140MPH on its own then you only need one) adding a playstation or loud stereo makes it have more "street apeal" so people think its faster. you will also need a NOS fogger system, stand alone fuel management (not a bad way to spend $10k)
and you need a laptop in the passenger seat so you can engage stage 2. just be careful of danger to manifold I suggest not to press both NOS buttons at the same time. you passenger floorboard might fly off. But if it does fly off just try to pick up Vin Diesel and it should be magicly replaced. Just be very careful when trying to hit 140MPH your car might spin without notice when you reach those speeds and your reverse lights might come on for no reason. Please be careful.
LOL that was fun. anyway we can race once my clutch is done. I wanna see what your car can do on 8Lbs. ill bring a honda so I dont beat you to bad.
(oh and we are so drinking next weekend- Not topic related just to lazy to myspace)
XRWITS is offline   Reply With Quote
Old 01-23-2009, 10:19 AM   #17
theguy
Member#: 144244
2006 WRB STi
www.CAMtuning.com
it says ON, not in. injection is worth it, who gives a **** about spraying on the intercooler, its not worth the effort.
you owe me $20
Old 01-23-2009, 10:33 AM   #18
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
you owe me $20
Why wouldn't it be worth the effort? Cooler IAT are ALWAYS better. That's a FACT. Spraying water onto my stock IC improved it's efficiency by 13%, It went from 59% to 72% Or in other words IAT into throttle went from 136*F down to 117*F on a pedal to metal run from 0 to 130 MPH on a 77*F ambient day.
wrxdrvr is offline   Reply With Quote
Old 01-23-2009, 11:21 AM   #19
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Please PM me for my paypal so you can send me $20.
Old 01-23-2009, 12:56 PM   #20
Grammar Police
Guest
Member#:
If you follow this procedure you have to make sure not to hit your NOS button too soon, or you will lose your pink
Old 01-23-2009, 01:00 PM   #21
Grammar Police
Guest
Member#:
you owe me $20
Not worth the effort? takes about 20 minutes to move and fasten a nozzle. The effectiveness of an IC is based on the rate it can transfer heat to the atmosphere from the compressed air passing through it. Metal---> fluid heat transfer is significantly faster than Metal--->air. Spray nozzles have been used to increase IC efficiency for a long long time. Do your homework to avoid further posting of false information.
Old 01-23-2009, 01:07 PM   #22
sfwrex
Member#: 200801
2003 WRX
lol thread successfully hijacked
sfwrex is offline   Reply With Quote
Old 01-23-2009, 05:37 PM   #23
retreif
Member#: 162113
2011 WRX
Any suggestions?
I am interested in your next steps. I have heard of the wagon tank swap for our year WRX and getting the STI switch for the interior from a local guy here. Really cheap at a "pull your part" yard for the tank.
Ignore some of the noise here.
Old 01-24-2009, 06:26 AM   #24
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
jesus tuned my hot rod
Chris
exactly! there's a few vendors and a few members that have put together some kits that include all parts, wires and cool switch. i just added one last month, it was a breeze to install and works great. just make sure to add distilled water and not tap. pm me if you'd like i'll put you in touch with a friend who has a kit.
mongoosaroo is offline   Reply With Quote
Old 01-24-2009, 06:57 PM   #25
dineth00i30
Member#: 198513
2004 G35 Sedan 6MT
what is you just keep a spray bottle and park the car and just spray some water on the IC? would it work?
<-------------- NEWBEEEEEE
dineth00i30 is offline   Reply With Quote
How do i remove Windshield washer sprayers? Rockstar25 Interior & Exterior Modification 3 05-29-2006 06:53 AM
Windshield washer to intercooler spayer question? Clzay Water/Methanol Injection, Nitrous & Intercooler Cooling 19 01-17-2006 05:10 PM
weird problem w/ the windshield washer sprayer flyingmachine General Community 11 08-27-2005 12:57 AM
WTB: windshield washer sprayer nozzles nunyo Private 'Wanted' Classifieds 0 08-03-2004 12:01 PM
