Old 01-22-2009, 09:48 AM   #1
rockle3
Member#: 167573
09 spec B
Default swap is done but...
hey nasioc i need your help
my friend did a ej20g swap for me
although there is still a bit of work to be done
(gauges, and what not)
theres one really big problem thats a nuisance
the car idles fine, hell it is drivable
but when the turbo starts to spool,
i get a kickback and the car kind of bounces
friend said it might be his wiring, the crankshaft sensor
or the ecu
i truthfully have no idea
i dont know too much about cars, but if you guys can troubleshoot for me
that would be great
thanks in advance!
rockle3 is offline   Reply With Quote
Old 01-22-2009, 10:57 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
is your check engine light on ?
what is the blink code
very unlikely the crank sensor .. or it would never start
first guess is the maf or maf wireing ..
second is a ground for the 2 wire temp sensor
Old 01-22-2009, 04:09 PM   #3
rockle3
Member#: 167573
09 spec B
yeah check engine is on
ill see what code it is when i go to my friend's shop
oh along with that
the gas gauge and the water temp gauge dont work
the speedo dont work either cause all the wiring isnt done
could that be it?
Old 01-22-2009, 08:13 PM   #4
suberdave
Member#: 101865
88 GL-10 STi
my guess is you havent hooked all the wiring up to the IP cluster. therefor your ECU has no input form the VSS. whenever you get to about 2500RPM it cuts fuel.
get that taken care of and all will be well...
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 01-22-2009, 10:52 PM   #5
rockle3
Member#: 167573
09 spec B
i can pass 2500 fine
if i dont get under boost
and just lightly push the throttle
it can go up to 4k
Old 01-22-2009, 11:17 PM   #6
Aphex28
Member#: 11506
2015 WRX
haha I didn't realize you were from HP.
I grew up in Northvale right next to Hogan's Field
Aphex28 is offline   Reply With Quote
Old 01-22-2009, 11:26 PM   #7
DumbUglyDragon
Member#: 61077
1993 WRX
Check your coilpacks, I had a nearly identical problem, turns out coilpacks were all cracked. When ever it started to build boost, it would misfire like crazy (so it would buck like mad).
DumbUglyDragon is offline   Reply With Quote
Old 01-23-2009, 01:45 AM   #8
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
I'm with Dave. Something is wrong with your speed sensor signal, and it's putting your ECU in severe limp mode.
-Rob
rob is offline   Reply With Quote
Old 01-23-2009, 08:17 AM   #9
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
sounds like you are hitting fuel cut... for some reason or another. Could be a sensor, but check for loose i.c hose also.
blkgm8 is offline   Reply With Quote
Old 01-23-2009, 09:06 AM   #10
subaruwrx
Member#: 1818
03 1996 Impreza Wa
Soon to be a v3 STI
If your gauge cluster is not hooked up, that will do it. I had the speed sensor CEL and I thought it couldnt be related, but it is.
If not, check all your hoses all over again...
subaruwrx is offline   Reply With Quote
Old 01-23-2009, 09:12 AM   #11
rockle3
Member#: 167573
09 spec B
wtf speedo can affect engine performance?
i never knew that could happen..
its nice to see another valley guy haha
harrington park is the suxorzzzz
hmm gotta check that out
Swap is done. WRX tranny with v6 RA gears into Legacy SS. Innovative Tuning Subaru Conversions 3 03-06-2011 08:51 PM
engine rebuild is done, but..... iluvdrt Legacy Forum 8 02-16-2007 06:23 PM
Swap is done & Paint is done JeremyRS Member's Car Gallery 61 05-20-2006 12:13 PM
My Engine Swap is Done! Cajual Legacy Forum 46 12-23-2003 02:46 PM
My EJ205 engine swap is done!!:) Homemade WRX Subaru Conversions 47 09-23-2003 04:50 AM
