Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 01-22-2009, 11:21 AM   #1
SilentEdge
Member#: 199766
2010 STi SE
Default When do you have to tune?
The car I just bought has only a cat back exhaust in regards to power mods. I wanted to install an up pipe and down pipe. At what point should I start thinking about getting a tune?
SilentEdge is offline   Reply With Quote
Old 01-22-2009, 11:23 AM   #2
Retiarius
Member#: 198130
After you install those mods. Not required, but you will be happy you did.
Retiarius is offline   Reply With Quote
Old 01-22-2009, 11:26 AM   #3
MIKE DD
Member#: 106818
2003 Truck
02 & 03's are can run well w/no tune on those mods. But like he said, you'd be happier w/a tune. OTS map would be good, ProTune would be best to get the power out of your mods.
MIKE DD is offline   Reply With Quote
Old 01-22-2009, 11:35 AM   #4
p01ntb1ank
Member#: 134299
when you think you're done with modding or won't mod for a long time. some mods require a tune and you'll just be wasting your money if you get tuned again.
p01ntb1ank is offline   Reply With Quote
Old 01-22-2009, 11:37 AM   #5
blackcompany
Member#: 143158
2007 STI
UGM
^ seconded, or if you put something on and your car runs like crap.
blackcompany is offline   Reply With Quote
Old 01-22-2009, 11:41 AM   #6
Retiarius
Member#: 198130
That is HORRIBLE advice. Why did you even bother?
Old 01-22-2009, 11:57 AM   #7
zackdeha
Member#: 200840
isnt it every 3000 miles for most cars?
zackdeha is offline   Reply With Quote
Old 01-22-2009, 11:58 AM   #8
zackdeha
Member#: 200840
ha he ha he disregard that last statement.. sry
Old 01-22-2009, 12:05 PM   #9
blackcompany
Member#: 143158
2007 STI
UGM
...lol!
Old 01-22-2009, 12:18 PM   #10
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Get a tune when you get the downpipe and uppipe installed.
tux121 is offline   Reply With Quote
Old 01-22-2009, 12:21 PM   #11
FlatironsTuning.com
NASIOC Storefront Vendor
Member#: 171650
Generally speaking, there are usually improvements to be made from re-flashing your ecu, even if you haven't added any exhaust parts, etc. to your car.
When you put a turbo-back exhaust on your car, you will see an improvement, but it will likely only be about 50% of what you would get if got a tune as well.
If you want to see some dyno # with a stage 1 flash compared to a stage 2 flash, follow the "Project Car" link below.
J. Cooley
Flatirons Tuning Project Car
Flatirons Tuning F.A.Q. Blog
Flatirons Rally Team Blog
FlatironsTuning.com is offline   Reply With Quote
Old 01-22-2009, 01:27 PM   #12
ChandlerWRX06
Member#: 184206
2013 X1 sDrive 28i
gray
next time hit the edit button not the post again button lol
ChandlerWRX06 is offline   Reply With Quote
Old 01-22-2009, 01:49 PM   #13
SilentEdge
Member#: 199766
2010 STi SE
Old 01-22-2009, 02:18 PM   #14
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Anytime you change the way the MAF reads (new MAF housing), the way the fuel is injected (injectors, fuel rails, etc), or the way the car builds boost (wastegate, new downpipe, etc), you need a tune. Other mods might benefit from a new tune, but it's usually not necessary. Your car might be alright with a downpipe without a tune, most other subies need a tune after changing the downpipe though because the drop in restriction typically leads to overboosting unless the wastegate duty cycle is dialed down some.
Old 01-22-2009, 03:33 PM   #15
Scooby-King
Member#: 180499
2007 SRT8-Cherokee
2008 Sierra Denali
If when you say Tune . . you mean Oil Change
Than YES !
Scooby-King is offline   Reply With Quote
Old 01-22-2009, 03:33 PM   #16
bran521
Member#: 154342
2002 wrx impreza
PSM 4eat original owner
i think it was 02-03 wrx's that tunes arent really a necessary after an uppipe downpipe upgrade, although like most people said^^^it is much better to have one. any other year after that i think you would NEED a tune, please correct me if im wrong.
bran521 is offline   Reply With Quote
Old 01-22-2009, 03:54 PM   #17
lagwagn
Member#: 161287
2004 impeza wrx
black stageII
i think all wrxs before 06 have a cat in the up pipe and also and factory egt or something of that nature, so that would have to be taken care of. you dont want a cel. you can also put a resistor in place of the sensor
lagwagn is offline   Reply With Quote
Old 01-22-2009, 05:14 PM   #18
BELLOTARU
Member#: 200836
2006 2.0R
Blue mica
Beware. If you change up and down pipe you can have preassure peaks. I would make an ECU reprogramation after install it.
BELLOTARU is offline   Reply With Quote
Old 01-22-2009, 06:50 PM   #19
subeerex
Member#: 87430
02/5 BugEye-Peanut
Sedona Red Silver
...I wanted to install an up pipe and down pipe...
I woke up this morning, looked out the window and...it's still mods-unfriendly California out there!!!
subeerex is offline   Reply With Quote
Old 01-22-2009, 10:25 PM   #20
GUN-IT
Member#: 199693
2005 STI
Crystal Grey Metallic
Funny, I got into it with some idiot yesterday on IWSTI. He stated that Using a Cobb Access Port stage 2 map with a new intake, turboback exhaust, and fuel pump would not need to be custom-mapped or pro-tuned for someone's particular set-up. I was just blown away. His computer would absolutely be CONFUSED!!!!! For some reason, I go to that site........I like punishment I guess...........
GUN-IT is offline   Reply With Quote
Old 01-22-2009, 10:28 PM   #21
Member#: 51961
2005 STi
2012 WRX
The intake is the only questionable part in there. The turboback is already taken care of in the stage 2 map, the fuel pump doesn't need a re-tune, and the intake would only need a re-tune if it changes the MAF scaling by more than a couple percent (which depends on the intake).
Old 01-22-2009, 10:37 PM   #22
GUN-IT
Member#: 199693
2005 STI
He was talking ebay parts....... Something tells me that intake will have a little turbulence. Of course, it wouldn't bother me to be wrong. I wouldn't mind getting parts off of ebay since they are so cheap. The computer wouldn't need to be re-flashed due to the change in fuel pressure? Or will the AP handle that?
Old 01-22-2009, 11:23 PM   #23
SilentEdge
Member#: 199766
2010 STi SE
Shhhhhhhh.
<_<
>_>
Old 01-22-2009, 11:41 PM   #24
ScarryFatKidGT
Member#: 200950
1998 Legacy GT
"Tune" not "Tune up"
ScarryFatKidGT is offline   Reply With Quote
Old 01-23-2009, 04:50 AM   #25
Iflysti06
Member#: 156955
2006 STI
UR GT35R w/ mad bolt ons
Talking
LMFAO
Iflysti06 is offline   Reply With Quote
Do you have to tune an EBCS? Jackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-12-2009 03:42 PM
Do you have to unplug the AP when car is off? STI 08 Bahrain AccessPort 2 10-03-2008 05:38 AM
Do you have to have a B.A. in Business to get an MBA? Eric SS Off-Topic 15 04-19-2004 11:30 PM
What do you have to do to lose your license to practice medicine? HoRo1 Off-Topic 5 04-08-2004 11:32 PM
Do you Have to resuface Rotors when you do pads yebokmj Brakes, Steering & Suspension 17 01-29-2002 07:12 PM
