Old 01-22-2009, 11:57 AM   #1
k22addict
Member#: 92561
Default compression and leak down test on an 04 sti
kind of a dumb question but..... is there any other way a compression test or leak down test for that matter can be performed with the engine out of the car?
k22addict is offline   Reply With Quote
Old 01-22-2009, 06:15 PM   #2
Franko
Member#: 193628
2010 STI
SSM
Well usually you want an engine warm to do either because the results will be lower when it is cold due to everything being looser. You can perform a leakdown easily. Piston at top dead center on the compression stroke (valves closed) and whack it to her. Results will generally be a bit lower like I said.
A compression test will be a bit more tricky to do since usually you need to crank the car over with the starter to get compression. Although I dont think it will really be nessicary since the leakdown will tell you if you have a healthy engine or not.
Franko is offline   Reply With Quote
Old 01-22-2009, 08:03 PM   #3
k22addict
Member#: 92561
"whack it to her" please explain...im thinking some sort of baseball bat when i hear this
Old 01-22-2009, 11:31 PM   #4
flycaster
Member#: 60142
2011 WRX
Grey
Heh, heh...yeah, I can see how the metaphor might be a little tough to follow. What he means is to pressurize the cylinder with a 100 psi shot from the leakdown tester. Some guys, me included, just say "shoot it", but "whack it to her" works too.
flycaster is offline   Reply With Quote
Old 01-23-2009, 04:23 PM   #5
Franko
Member#: 193628
2010 STI
SSM
Hehe, Yeah sorry about that. Just do a normal leakdown test and then if you find one cyl is exceptionally bad (over 20%) then do like 100 psi and you should be able to tell where its going. Listen in the exhaust, listen to your intake and take the oil cap off and see if its coming from there.
It might be hard to hold the engine at top dead center when you put 100 psi in the chamber so be prepared for the engine suddenly turning over.
08 STi compression and leak down test results erikm Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-14-2010 09:14 PM
Need help with compression and leak down test EsubaruJ Rocky Mountains Impreza Club Forum -- RMIC 7 01-14-2010 08:21 PM
Compression and Leak down test? Go350zGo Southern California Impreza Club Forum -- SCIC 15 09-03-2009 09:21 PM
compression & leak down test graff Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-12-2007 02:47 PM
Recommonded Shop for Compression Test and Leak down test? stook2003 Vancouver Impreza Club Forum -- VIC 0 07-02-2007 04:20 PM
