Old 01-22-2009, 12:57 PM   #1
chico_kj_23
Member#: 119740
1993 JDM WRX
Default EJ20G Downpipe?
I have had no luck searching so i think i will ask. What down pipes are people running on their ej20g. will the 02+ down pipes work? i assume not but just thought i would ask. thanks!
chico_kj_23 is offline   Reply With Quote
Old 01-22-2009, 01:10 PM   #2
bape-ape
Member#: 136009
96 RapeWagon
Ugly
02+ are longer IIRC.
bape-ape is offline   Reply With Quote
Old 01-22-2009, 01:31 PM   #3
DSM_Outback
Member#: 56345
93 Swapped L
Green
If you use it with an 02+ exhaust, will work fine.
DSM_Outback is offline   Reply With Quote
Old 01-22-2009, 01:33 PM   #4
chico_kj_23
Member#: 119740
1993 JDM WRX
awsome, thats the plan!
Old 01-22-2009, 03:04 PM   #5
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
yeah i have 02 wrx exhaust...all exhaust will fit from 02-07 wrx/sti... except the new 08's...
azn0boi04 is offline   Reply With Quote
Old 04-14-2009, 06:46 PM   #6
zachattack54
Member#: 173213
06 STI
If already had a exhaust system on(not sure of brand came with car, pretty sure its custom) could I run a 02+ downpipe and if it did not line up exactly could I just take it to a muffler shop and get the them to custom fabricate it so it works?
P.s. Sorry to bring this thread back from the dead but I am doing a little build right away and I got a few questions.
zachattack54 is offline   Reply With Quote
Old 04-14-2009, 08:06 PM   #7
sniper512
Member#: 189923
1993 JDM WRX
Yes a shop should be able to match them up if they have any skills.
sniper512 is offline   Reply With Quote
Old 04-15-2009, 02:21 AM   #8
thad
Member#: 176616
1994 impreza
white
I've been using an 02 wrx exhaust with an 05 sti down pipe, and more recently, an aftermarket down pipe for 02 + wrx. this is on a GC (4dr) w/ 96 ej20g, for the most part fitment is ok, but I've noticed occasional contact between the muffler and sway bar.
I noticed that the muffler sits a bit further aft in the GD with the same exhaust.
thad is offline   Reply With Quote
Old 04-18-2009, 04:32 AM   #9
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
JDM downpipes are shorter than the usdm ones. so if you use a jdm downpipe youll just have to custom fit the midpipe. or just get a usdm 02+ downpipe.
be careful with ebay stuff too. from what ive seen, all the ebay stuff quality-wise is great but they have weird flange positions so they dont match at all to usdm or jdm parts. so if you want an ebay exhaust, theyre great and cheap (i have one, sounds great) but get the whole turbo-back. if you try and use (for example) the cat-back section of an ebay catback with an invidia downpipe, it will end up about 4 inches short
elislider is offline   Reply With Quote
Old 04-28-2009, 02:59 PM   #10
clean 93
Member#: 181440
1993 wrx
I have a rocket rally downpipe and apexi n1 catback on my gc. It fits great and I only had to modify one hanger that was pointing to the right rather than the left. All the other hangers worked fine.
clean 93 is offline   Reply With Quote
Old 04-28-2009, 06:02 PM   #11
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Get one custom made?
i_c_the_light is offline   Reply With Quote
Old 04-29-2009, 06:53 PM   #12
zachattack54
Member#: 173213
06 STI
Quick question about o2 sensor?
I got a downpipe and 02 sensor is not the right size and not long enough. Could I just go ahead and get a 02+ oxygen sensor or what have you guys been doing? Thank you for the info I am still acquiring knowledge.
Old 04-30-2009, 01:18 PM   #13
zachattack54
Member#: 173213
06 STI
BUMP!! I need to figure this out. I did some research and it sounds like that guy is the EGT sensor. It is most definietaly not the right size. What should I do I need some help bad and I am searching and searching and I can't really find a answer!!!!!!.
Old 04-30-2009, 02:31 PM   #14
Rei_Akira
Scooby Scammer- Do Not Buy From User
Member#: 194555
1997 GC8 coup
green
there should be one egt and one 02 sensor bung on the dp.... did you buy an ebay dp or what did you go with?
Rei_Akira is offline   Reply With Quote
Old 04-30-2009, 02:54 PM   #15
zachattack54
Member#: 173213
06 STI
It is a 3" BBP and my stock one only had the one sensor and so does the new one. But the problem is that they are both different sizes.
Old 04-30-2009, 05:28 PM   #16
elislider
Member#: 133923
03 Legacy GT wagon
for reference: the EGT is a temperature sensor so the ECU can tell if the catalytic converter is getting too hot. for any catless applicaton, there is no EGT. if your car has an EGT stock and you are going catless, then you will want to get a resistor for the egt plug and trick the ecu into thinking it is always the right temp. (search the forum for egt resistor and youll find info about that)
a stock downpipe has 2 sensors: O2 at the top (before the cat) and Temp sensor at the bottom (after the cat). i have an invidia downpipe and the O2 sensor goes way at the very bottom end of the downpipe so i lengthened the wires for the sensor plug. since the stock O2 sensor normally goes right at the top of the dp
Old 04-30-2009, 05:35 PM   #17
Rei_Akira
Member#: 194555
1997 GC8 coup
green
does your Invidia dp have spots for both sensors? and in the case of Zach what would you suggest since he only has one spot in his dp?
Old 04-30-2009, 09:56 PM   #18
zachattack54
Member#: 173213
06 STI
Well I went to our local subaru shop and We decided on going totally without and the car seems to be running fine with no CEL's. Right now I'm running straight off the downpipe and wow is it loud. I like it a lot though.
Old 04-30-2009, 10:00 PM   #19
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
The only sensor in the downpipe of a JDM is the cat temp sensor - unplug it and don't worry about it.
You will need an O2 block off plug for the O2 fitting on the turbo outlet part of the downpipe.
Just for reference, your O2 is in the header.
rockcrete is offline   Reply With Quote
Old 05-01-2009, 12:46 AM   #20
sniper512
Member#: 189923
1993 JDM WRX
^+2
I have done this as well.
Old 05-01-2009, 01:24 AM   #21
elislider
Member#: 133923
03 Legacy GT wagon
ive done that. and agreed, its loud as hell
my invidia catless bellmouth downpipe has one 1 spot for a sensor and its for the O2 sensor down by the very end of the downpipe.
My engine is a jdm v3 sti (ej20k). it has no sensors in the uppipe and 2 sensors in the downpipe, 1 is the O2 (top before the cat) and 1 is the temp sensor after the cat
i should have clarified earlier. i was referring to my jdm sti downpipe. it has a single catalytic convertor
in this picture, the stock downpipe (jdm v3 sti) looks like the one on the right
in this pic, wrx catless (full downpipe replacement), wrx catless top section only, wrx stock, jdm wrx (and i think usdm lgacy turbo)
Old 01-15-2010, 11:53 AM   #22
MY2ND04WRX
Member#: 121476
04 WRX HYBRIDX2
PSM for now
OMGHi2U
Is there a piece to make the JDM V3 STI downpipe work on my 04 WRX??
This is what I have and it looks like the JDM V3 STI.
You can see the New pipe is about 4 inches shorter. Any suggestions on what I should do?
Thanks in advance
(You wrote)in this picture, the stock downpipe (jdm v3 sti) looks like the one on the right
[/quote]
MY2ND04WRX is offline   Reply With Quote
Old 01-16-2010, 03:41 AM   #23
thoughto
Member#: 29145
1998 Version 4 STI
White, gold wheels
rockcrete, sniper512: There's no harm in just removing the cat temp sensor, no CEL on an EJ20K? Just noticed my aftermarket DP I was going to fit has no hole for it.
thoughto is offline   Reply With Quote
Mines flashed EJ20G ecu, and ej20G engine harness liberty2000rs Engine/Power/Exhaust 1 10-31-2006 12:54 AM
EJ20G TD04 turbo, EJ20G intercooler xtian Engine/Power/Exhaust 20 07-18-2006 04:39 PM
jdm ej20g downpipe silvialost Private 'For Sale' Classifieds 0 02-20-2006 11:21 PM
ej20g downpipe question scoobydorift Subaru Conversions 1 05-11-2004 07:50 PM
Local FS: sedan spoiler, MRT TMIC for EJ20G, and EJ20G GC8 headlights annointed Tri-State Area Forum 3 05-10-2003 01:12 AM
