Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 01-22-2009, 01:50 PM   #1
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG,FMIC, Big turbo
Default How to get haziness away?
Alrite here is my problem. I cut/dremeled my stock headlight lense off the housing because I am doing a homemaid retrofit project. Well I applied some Meguires Plastic Scratch and that made a horrible haze over the lense and I cant get that haziness gone to save my life I have tried different waxes and of course tried to sand it off but nothing works. Any suggestions?
emsmap is offline   Reply With Quote
Old 01-22-2009, 02:02 PM   #2
98imprezaWagon
Member#: 142548
05 WRX
i use perfect-it 3000 (rubbing compound) and buff it...comes out like new...hope this helps..i have also tried sanding kits, they made it horrible...this worked for me.
98imprezaWagon is offline   Reply With Quote
Old 01-22-2009, 02:07 PM   #3
derekman
Member#: 142213
How fine was the sandpaper that you used? Usually wetsanding a headlight will remove any haziness.
derekman is offline   Reply With Quote
Old 01-22-2009, 02:18 PM   #4
emsmap
Member#: 159334
02 WRX, 99RS, 96L
I wet sanded it with 800 grit sandpaper and then completed another sanding with 1000 grit sandpaper and still really hazy
Old 01-22-2009, 02:19 PM   #5
emsmap
Member#: 159334
02 WRX, 99RS, 96L
hmmmm I might have to look into that. Thank You
Old 01-22-2009, 02:52 PM   #6
kevpotts
Member#: 170156
2010 370z
white
you'll need to go with a higher grit, get up to like 2000, then go at it with a rubbing compound or a heavy polish.
kevpotts is offline   Reply With Quote
Old 01-22-2009, 03:06 PM   #7
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Yeah 1000 isnt high enough. The kits you can buy at auto parts stores come with paper up to 3k i think. I used some scratch X after the wet sanding kit and it turned out pretty decent.
Mike
GrimmSpeed is online now   Reply With Quote
Old 01-22-2009, 03:09 PM   #8
emsmap
Member#: 159334
02 WRX, 99RS, 96L
wow 3000 grit is like a peice of notebook paper lol
Old 01-22-2009, 03:19 PM   #9
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
I'm curious as to how the Meguiars plastic polish (assuming you used something like Plast-X) caused the lens to become hazy. You are talking about the plastic, clear lens and not the silver reflector, right? With the lens, you will need to work up to 2000 grit like Kev mentioned. The lens will still be hazy (wetsanding does not remove haze) so you will need to follow up with the compound (as mentioned) and a polish. The goal with each step is to remove the marks left by the former so you can move on. At the end, a plastic/finer polish can be used to further enhance the clarity. ......800 grit is really aggressive and should only be used in the worst cases IMO (if at all).
Kean is offline   Reply With Quote
Old 01-22-2009, 03:27 PM   #10
emsmap
Member#: 159334
02 WRX, 99RS, 96L
^ Thank you for your input! Anyway yes the reason I used 800 is because there were some scratches on the inside of the lense so that took them right off. I will invest in some compound and polish this evening to see if that helps with some 2000 grit
Old 01-22-2009, 03:29 PM   #11
derekman
Member#: 142213
Exactly. Then top it off with a layer of clearcloat.
Old 01-22-2009, 03:31 PM   #12
kevpotts
Member#: 170156
2010 370z
white
you should post some before/after pics. That kinda stuff gets me through the work day.
Old 01-22-2009, 03:44 PM   #13
emsmap
Member#: 159334
02 WRX, 99RS, 96L
cool man I actually have taken quite a bit of project pictures from this. I am using the ebay projector headlights housing and have completly stripped them down and made quality projector headlights with a lense going over them. They pretty much look like the WRC headlights now. I will post pictures when finished
Old 01-22-2009, 03:46 PM   #14
Kean
Member#: 25187
'08 Foz Prem TGM
....if you have a drill and can get your hands on a polishing pad/ball that can be mounted to it, it will really help cut the time required with the compound and polish(es) you use. There are even kits on the market that include the items needed. Even something like the Powerball by Mothers (readily available in the retail market and mounts to any standard drill) may do the trick.
Old 01-22-2009, 08:58 PM   #15
getcha
Member#: 184961
06 CT9A
Wicked white
Wetsanding headlights puts in very fine, very uniform, very densely spaced fine scratches, of course it will look hazy. Its meant to put in uniform "damage" to eliminate non uniform damage to allow a surface to be polished out more easily than a non uniform surface(read scratch of varying depth and dimension)
Keep in mind that the newer factory headlights come with a UV protection on it.
What you will need to do since you already have worked with 800 and 1k grit, you should start to work down in finer and finer grits(maybe something like 1500 -2000-3000) then maybe you can get to a point where you can hand polish or machine polish the now fine marks out.
If youre planning on attacking this further, I would suggest reading up on products effective by hand that are easily available to you.
If you end up ordering I would say look into meguiars m105, then IP from menzerna and you can follow those with your PlastX that you have. And these if done by hand or machine may require multiple applications, moreso by hand.
Make sure you coat the headlights after with a sealant or wax of some sort as the UV protection in them may now be compromised.
getcha is offline   Reply With Quote
Old 01-23-2009, 02:53 PM   #16
REVNU
Member#: 82147
2005 WRX Sedan
What type of applicator did you use with the PlastX? I find starting with a foam pad works best with PlastX as a lot of times a Microfiber or Cloth applicator is too aggressive. Also, this is why you should ALWAYS do a test spot whether it be on paint or plastic to make sure you don't run into this problem, but I'm sure you've figured that out by now.
Once you get all those scratches out, I find that the Meguiar's Plastic Cleaner and Plastic Polish are a great one-two combo for filling and reducing scratches in plastic. They contain no abrasives so it comes out pretty nice with some work.
REVNU is offline   Reply With Quote
Old 01-23-2009, 09:40 PM   #17
emsmap
Member#: 159334
02 WRX, 99RS, 96L
Thank you for all your suggestions! So basically I should sand more and more with finer papers then use a rubbing compound and then a rubbing polish?
Old 01-23-2009, 10:32 PM   #18
Kean
Member#: 25187
'08 Foz Prem TGM
....simply put, yes. However, just keep in mind that the purpose of each step is to correct the abrasions left by the previous one until you are left with a nice clear lens.
Old 01-28-2009, 02:30 AM   #19
pumaking
Member#: 162825
2015 WRX Base
I used a product called Crystal View. A lot of people recommended it so I went ahead and tried it. Im happy with it.
Heres it they looked before.
Pretty much just follow instructions on package and you get these results
This is what it looked like when finished.
You can see here Passenger side wasn't done yet and Driver Side just finished.
pumaking is offline   Reply With Quote
Old 01-28-2009, 11:42 AM   #20
rpeirats
Member#: 172278
Chapter/Region: PRSIC
2005 WRX
VF39'd 310whp/321wtq
i use brake fluid to remove the yellowish haze off my headlights... Works perfect
rpeirats is offline   Reply With Quote
Old 01-28-2009, 11:49 AM   #21
Kean
Member#: 25187
'08 Foz Prem TGM
....brake fluid is also an effective paint remover. There are safer, proven methods to refinish headlamps.
Old 01-28-2009, 04:20 PM   #22
TexSurfer
Member#: 76072
LoL, very true. Same chemicals found in paint remover products. Pretty toxic stuff in brake fluid. Some of which can degrade polycarbonate, which is what most headlight lenses are made up of now. So you might get rid of discoloration, but you are probably doing more long term damage to the lense. I'd find something made specific for the job, and let brake fluid be brake fluid.
TexSurfer is offline   Reply With Quote
Old 01-28-2009, 09:57 PM   #23
rpeirats
Member#: 172278
2005 WRX
I think I didnt explain myself very well. I am not talking about large amounts.
What I do is put a polishing cloth over a finger or two, apply a very SMALL amount of brake fluid (2-4 drops) to the finger tips, and slowly and carefully rub the hazy area. The haziness disappears INSTANTLY. Then, with a clean cloth, wipe the area, and then wash with water and soap.
I have been doing this for years without any negative effects. Its cheap, VERY easy, and takes no time.
Old 01-28-2009, 10:18 PM   #24
dave_mtu
Member#: 179830
2004 WRX Wagon
ok, i have been in this battle for awhile too. I tried cleaning mine up by wetsanding, etc. Ive used up to 2500 grit, then used Macguirs Plastic Polish. But, after a few hours they are hazy again due to the super fine scratches from the sanding.
Your lights look really good, how long has it been since you applied this? Do they still look like this half a year later?
dave_mtu is offline   Reply With Quote
Old 01-28-2009, 10:59 PM   #25
EROC263
Member#: 96887
I use this because I can get it for free from work and it's been working well so far. Have to re-apply every 6 months or so.
http://www.autogeek.net/duragloss-plastic-polish.html
EROC263 is offline   Reply With Quote
Dogs getting harassed by birds in backyard. How to get rid of birds? MyOtherRideIsUrMom Off-Topic 85 06-11-2010 12:46 AM
How to get Media Player to minimize to "buttons" -=C=- Off-Topic 9 09-20-2005 02:47 PM
Holy hell these people know how to get people to allow them to meet with them. aod Off-Topic 11 03-02-2005 03:13 PM
Do the 2005s get boost creep? If so, how to get rid of it? Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 09-09-2004 07:13 PM
Any tips on how to get AC hose away from Strutbar Zapper Brakes, Steering & Suspension 3 11-01-2002 03:28 AM
