Old 09-18-2009, 08:10 PM   #451
leoimpreza
Member#: 197989
2002 Impreza WRX STI
WR Blue
Originally Posted by 9vapors View Post
What wg is that in the top pic above? I like that heat shield on it...
It's Power Enterprise RX6R turbo kit (RX6R turbo, exhaust manifold, uppipe, external wastegate, downpipe etc...)
leoimpreza is offline   Reply With Quote
Old 09-18-2009, 10:40 PM   #452
Deuce Cam
Member#: 130444
'85 AE86 GTS
Originally Posted by Sp00L View Post
has anyone seen a Mid mount setup on a subie yet?
almost the same as V mount but the intercooler is mounted further forwards and the radiator sits directly behind it, you would need a smaller then OEM radiator though thats the only problem, so the pipes could run on either side of it.
I could be wrong but I believe that's basically what the team orange cars run. The radiator is located behind the ic and the ic is located high up like it would be on a v-mount (unlike a fmic setup). The kicker is the radiator and ic are still both perpendicular to the ground. The radiator isn't as tall as the stocker allowing the ic pipes to easily pass over it.
I'll admit that there haven't been any good pics of how the radiator is setup on the team orange cars, but I bet it's as I described.
Deuce Cam is offline   Reply With Quote
Old 09-18-2009, 11:13 PM   #453
WRX2EVOX
Member#: 203011
04 WRX
Their radiators are mounted in the trunk, hence the big openings in the trunk lid and ducting in the doors.
WRX2EVOX is offline   Reply With Quote
Old 09-18-2009, 11:36 PM   #454
Sp00L
Member#: 169701
2006 WRX
1997 240SX
i think only a few of their subies have that setup. im pretty sure tanakas 06 they run in the U.S and Europe has a normal radiator setup, not 100 % sure though, but i saw that car at D1.
A mid mount setup really wouldnt be that hard with a little bit smaller of a radiator and an intercooler that fits under the core support and has backwards facing end tanks, you just wouldnt be able to run AC because of that stupid condenser. it would be a hell of alot cheaper then a V mount and would be alot more simple and practical. i think the hardest part is finding a radiator that has stock location inlets and outlets and is the perfect size.
Sp00L is offline   Reply With Quote
Old 09-19-2009, 12:20 AM   #455
Deuce Cam
Member#: 130444
'85 AE86 GTS
Yeah, only some of them have the rear mounted radiator - you can tell if it has the cut-outs on the rear doors. I've got the subie sport issue with the team orange drift cars (the ones that were at subiefest) and the radiator is clearly mounted below and behind the intercooler. You can only tell when looking at the front of the car. You can't even see the radiator in any of the engine bay shots I've seen because it sits low.
One has to keep in mind that the ic is farther forward on the team orange cars than most v-mount setups. They actually have the top part of the radiator support - between the headlights - cutout and that's where the ic is fitted.
Edit: I couldn't post the pics, but post #202 in this thread shows what I'm talking about.
Old 09-19-2009, 05:05 AM   #456
old_duwel
Top Scoob 015
Member#: 18175
99 STI RA Ltd #450
WRB blue
man, i wouldn't mine doing a v-mount setup.
old_duwel is offline   Reply With Quote
Old 09-19-2009, 12:19 PM   #457
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Do it^^
scby rex is offline   Reply With Quote
Old 09-23-2009, 04:04 PM   #458
ColesSTi
Member#: 99205
2005 Impreza WRX
IM about to buy all the stuff I need to do a v mount.
What are some good radiators to get for the setup?
ColesSTi is offline   Reply With Quote
Old 09-23-2009, 05:17 PM   #459
leoimpreza
Member#: 197989
WR Blue
Old 09-23-2009, 05:29 PM   #460
leoimpreza
Member#: 197989
WR Blue
I will use in my custom v-mount set-up Pace Products 3-row water radiator core....
Old 09-23-2009, 05:33 PM   #461
Sp00L
Member#: 169701
2006 WRX
1997 240SX
does anyone know what a good intercooler is for a V-Mount ?
ive been searching trying to find one that has backwards facing endtanks.
Old 09-23-2009, 08:08 PM   #462
ColesSTi
Member#: 99205
2005 Impreza WRX
Hey spool like these? http://www.extremeturbosystems.com/I...670/index.html
What I ment, about what are good radiators. I am looking for the hose placement and height etc. I like the one on the esx motorsport car for example. Where can I find one similar.
Old 09-23-2009, 08:10 PM   #463
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
You want a stepped core radiator for a v-mount. Process west sells them..
tino is offline   Reply With Quote
Old 09-23-2009, 10:48 PM   #464
dudley123
Member#: 120831
PIA Purpose Built -
SEMA-FullRace/HRE/Cosw.
yessir.. stepped core is ideal in a true v-mount setup.^^
dudley123 is offline   Reply With Quote
Old 09-23-2009, 10:50 PM   #465
Sp00L
Member#: 169701
2006 WRX
1997 240SX
thanks for the link, but i think 33" is too big to fit under the radiator support, i beleive from headlight to headlight its like 29" on a GD, says they build custom ones though so hmm..
Old 09-24-2009, 11:55 AM   #466
leoimpreza
Member#: 197989
WR Blue
Another Greek Monster w/ v-mount cooling set-up...
Old 09-24-2009, 07:10 PM   #467
scby rex
Member#: 104878
02 wrxbastardchild
Thats some awsome pics of that car. Its one of my faverites you show us.
Old 09-26-2009, 11:09 AM   #468
ColesSTi
Member#: 99205
2005 Impreza WRX
Hey spool, If you if you bought the one 12'' by 33'' and had the core de-sized to 28''. It could be bolted onto the radiator cross member, like the ARC intercooler team orange uses. But if I go that route, I am going to angle it 30 degrees to leave room for the radiator.
Old 09-26-2009, 12:57 PM   #469
Sp00L
Member#: 169701
2006 WRX
1997 240SX
yeah, or you could just buy a forge intercooler, wich is 28" long, but i still think that is too big, dont think there is enough space for the pipes to run.
http://www.forgemotorsport.com/conte...ct=FMINT104UNI
precision also makes one thats 26.75 x 6 x 3.5, seems like it would be a good fit.
Old 09-29-2009, 11:54 AM   #470
leoimpreza
Member#: 197989
WR Blue
Old 09-29-2009, 12:49 PM   #471
9vapors
Member#: 92582
^^^That is so great.
9vapors is offline   Reply With Quote
Old 09-29-2009, 12:54 PM   #472
CatfaceType-R
Member#: 81102
oh yes it is, damn cooling; needed a ron davis radiator; I wonder why the car is making so much heat with all the venting too
CatfaceType-R is offline   Reply With Quote
Old 09-29-2009, 01:14 PM   #473
Subaruski
Member#: 39905
Leo! You stole my pics before I could even post them in this thread
Originally Posted by leoimpreza View Post
Another two shots of the GST Impreza.
Here is one of our local Vegas guys at the same event.
Subaruski is offline   Reply With Quote
Old 09-29-2009, 01:31 PM   #474
leoimpreza
Member#: 197989
WR Blue
Sorry mate but I can't resist when I see v-mount cooling system...
Very nice pics!!!
Old 09-29-2009, 03:30 PM   #475
oly kenji
Member#: 211299
2005 STi
going into 2001 gc
sheesh tino's setup is ridiculous
oly kenji is offline   Reply With Quote
The Ultimate Auxiliary Lighting and Mount Thread Rapid_Roo Electrical & Lighting 6889 05-30-2016 04:14 PM
Brembo Caliper mounting threads slightly stripped what to do? dogfrndnew Brakes, Steering & Suspension 31 03-31-2013 11:20 AM
FS : CUSCO Engine Mounts xdrian Engine/Power/Exhaust 6 06-20-2010 08:37 PM
Group N transmission mount threads JBravo920 Transmission (AT/MT) & Driveline 5 10-28-2007 10:17 PM
aftermarket seat mounting thread aspera Motorsports 8 12-05-2003 10:27 PM
