Old 01-25-2011, 03:25 PM   #651
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
Originally Posted by shilohb View Post
it is a tradstone vertical flow core it supports 1492 CFM's 1000HP I hammer formed the tanks to fit the buid but you can buy the tanks from tradstone also
I've been following them a little bit more lately. I ran into the vertical flow setup and have been trying to keep an eye out. How much did the intercooler run you if you don't mind me asking?
arco is offline   Reply With Quote
Old 01-25-2011, 03:49 PM   #652
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
http://www.treadstoneperformance.com...tercooler+Core
it was 260 tanks are around 70 each if you do not want to make them.
you need a good tig welder and a way to pressure test your intercooler
it is not easy to make it fit but I will have only 3 foot of intercooler tubing
the stock intercooler is a vertical flow also
the down side is they are only 80% efficient vs 90% on a cross flow BUT they have much better flow characteristics I am going to be useing meth so I will have some chemical cooling that will make up for it
shilohb is offline   Reply With Quote
Old 01-25-2011, 03:53 PM   #653
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
Originally Posted by TurboRX View Post
My Process West VMIC V1, with a new coat of black paint on the bottom of the radiator. This setup has been used for 3+ years of fairly regular commuting and still works great. Not quite as extreme as the other setups in here (stock 257 + 20G and normal supporting mods, ~370whp), but quite good for the street!
it looks good! how is your response vs a fmic? i bet it is pretty intense with the 20g
Old 01-25-2011, 04:03 PM   #654
TurboRX
Member#: 2455
99 GM6
99 996 Project
Response is very good, not quite instant like the stock turbo, but it also doesn't all on it's face like the stocker. I never had the 20G with a FMIC, only the stock turbo, so I don't really have a comparison. The biggest difference I noticed was the lack of power loss on hot days. With the 39 and a FMIC or TMIC, the warm weather really killed the power output. I'm not sure why but that is no longer as noticeable.
TurboRX is offline   Reply With Quote
Old 01-25-2011, 04:10 PM   #655
arco
Member#: 57156
2007 V.8 207 STi
I am having fitment issues with the garrett intercooler that I'm using so I just in the market of something else. I'm trying to keep my budget a bit lower since i don't have a tig welder accessible to me nor have the funds for end tank work.
I'll be running meth as well and will be using some pretty short piping with a reversed manifold. It will be setup like this
Old 01-25-2011, 04:56 PM   #656
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
Some guys get jeep Cherokee radiators it frees a lot of room up
Old 01-25-2011, 06:33 PM   #657
arco
Member#: 57156
2007 V.8 207 STi
yeah I remember reading that route. A friend and I almost went with it but we changed our minds.
Old 01-28-2011, 11:24 AM   #658
arco
Member#: 57156
2007 V.8 207 STi
Question and Opinion time:
I can't fit both the current radiator setup and intercooler that I have right now. It's just occupying too much space. The bumper is having a hard time sitting correctly with the radiator placement. It can be fixed by either getting a new radiator or intercooler. Either I'll be getting a shorter intercooler or I'll be getting a shorter radiator. Both are very good pieces. I don't want to go down in quality from what I already own. Which would you replace?
Specs:
Intercooler: 24"x10.38"x3.5" Garret core. Rated up to 800hp. Part number 703520-6011
Radiator: 16.5"x28"x2.5" Koyo. Also keep in mind I have a fan and shroud to fit and an AN fitting mounted on.
Old 01-28-2011, 08:36 PM   #659
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
Are you going to run ac?
Old 01-29-2011, 02:09 AM   #660
arco
Member#: 57156
2007 V.8 207 STi
More than likely I'm getting a Treadstone TR8 intercooler. I am planning on running AC still because when it's all said and done, it'll be my sole daily driver.
Old 01-29-2011, 12:14 PM   #661
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
What I ran into was my radiator support was to high to make it clear the fans radiator and condenser I'm using a 2009 Nissan altima condenser 110 dollars from 1 800radiator a northerner radiator and flex fans
I had to trim the radiator support and lower subframe to clear the Intercooler with the tanks the Intercooler is 25L x 3.5W x 12H
I also would have made the bottom of the radiator and condenser visable if I had not trimmed the subframe and coresupport
Old 01-29-2011, 04:54 PM   #662
Flacolandia
Member#: 264662
2007 STI
V Mount thats the way to go
Flacolandia is offline   Reply With Quote
Old 01-30-2011, 05:04 PM   #663
arco
Member#: 57156
2007 V.8 207 STi
I trimmed mine as well but I'm using a smaller intercooler now so I don't think I need to cut any more of the lower support than I have already. I'm not sure yet though. I am adding a Mishimoto radiator fan and shroud now which is a little wider so I'm not sure if that will cause any issues.
I'm interested in the condenser that you're using. I've been looking into an option so that I can still have AC as well.
Here is my build thread if you wanna see some of the work I've done for the kit.
http://forums.nasioc.com/forums/show....php?t=1835809
Old 03-15-2011, 01:31 PM   #664
arco
Member#: 57156
2007 V.8 207 STi
if anyone is interested in making a v-mount I have an intercooler: 24"x10.38"x3.5" Garret core. Rated up to 800hp. Part number 703520-6011
This was taken off a v-mount intercooler setup in Swiftwrx1's car. Search my name for more info
Old 03-16-2011, 03:52 AM   #665
arco
Member#: 57156
2007 V.8 207 STi
Wow. What happened to this thread? Well I'm pretty much done with my v-mount. One more day of small things here and there and I'll be back on the road.
How about leo? Any new pics?
Old 03-27-2011, 03:50 AM   #666
haha_to_06_plus
Member#: 159983
I wanted to know how people usually wire in fans that aren't stock. For the most part, they are only single speed fans rather than the stock dual speed fans. Because of that, I am unsure of how everything is wired in. Please add in any help that you have. Thank you in advance.
haha_to_06_plus is offline   Reply With Quote
Old 03-27-2011, 10:22 AM   #667
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
Do not know yet
If there was some sort of a diode in line you could run both
I am real close to dealing with the same issue I will post what I do
Old 03-31-2011, 11:38 AM   #668
arco
Member#: 57156
2007 V.8 207 STi
I wired my Mishimoto fans this way. I just wired both the high and the low speed into the fans. I haven't taken the car out yet so I'll see how that goes soon.
Old 03-31-2011, 11:44 AM   #669
TopSubi84
Member#: 278368
2005 Impreza WRX STI
White, 2011 STI White
Those are some sick V-Mount setups. Do most of you guys run AC with these custom setups? Seems like a lot of work to run AC. I know the PE/ ARC kit you can run AC. But these customs ones are just too cool.
TopSubi84 is offline   Reply With Quote
Old 03-31-2011, 11:49 AM   #670
TopSubi84
Member#: 278368
Originally Posted by leoimpreza View Post
OMG! That is one sick ass black subi. Who owns this? Any more pictures of this v-mount setup with no bumper on?
Old 03-31-2011, 11:58 AM   #671
04ImprezaWRX
Member#: 120237
2004 WRX
^ rey_vibora is his username. He's since parted most of the car, but that's the power enterprises v mount you'll be able to find pics just search it up.
04ImprezaWRX is offline   Reply With Quote
Old 03-31-2011, 05:19 PM   #672
TurboRX
Member#: 2455
99 GM6
99 996 Project
Here are a couple of pics from a recent shoot. No serious changes, just newer pics:
Old 03-31-2011, 05:46 PM   #673
vicious7
Member#: 212184
1997 Ver.3 WRX STI
Glacier White
I'd love to see a GC8 with a v-mount that still has a working front bumper.
vicious7 is offline   Reply With Quote
Old 03-31-2011, 05:55 PM   #674
itsmyturn
Member#: 225554
1999 Impreza 2.5WRSX
That makes two of us...
itsmyturn is offline   Reply With Quote
Old 03-31-2011, 06:41 PM   #675
TopSubi84
Member#: 278368
Thank you.
The Ultimate Auxiliary Lighting and Mount Thread Rapid_Roo Electrical & Lighting 6898 09-18-2016 12:41 AM
Brembo Caliper mounting threads slightly stripped what to do? dogfrndnew Brakes, Steering & Suspension 31 03-31-2013 11:20 AM
FS : CUSCO Engine Mounts xdrian Engine/Power/Exhaust 6 06-20-2010 08:37 PM
Group N transmission mount threads JBravo920 Transmission (AT/MT) & Driveline 5 10-28-2007 10:17 PM
aftermarket seat mounting thread aspera Motorsports 8 12-05-2003 10:27 PM
