Old 01-07-2012, 03:34 AM   #701
GhostSenshi
Member#: 279449
2004 8.78 E/T WRX
Platinum Silver
Originally Posted by Eww Evo View Post
What exactly is the V mount for??
looks like it would be better cooling efficiency but of course not knowing, I could be wrong.
GhostSenshi is offline   Reply With Quote
Old 01-07-2012, 08:16 PM   #702
Serkan
Member#: 180514
2004 Sti
Better cooling and much shorter piping for faster spool.
There has been talk about using Jeep cherokee radiator. Is it the longer in length, shorter in height one ?
this one :
or square ones :
If the first one is used I guess it will not be a v-mount anymore. More like radiator taking the place of regular fmic location.
Serkan is offline   Reply With Quote
Old 01-08-2012, 03:47 AM   #703
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
The second thing is the main thing. You normally wont see huge improvements in engine temps with v-mount vs. a normal fmic setup Overall, the radiator fans normally pull 200 cfm of air, which is more than can be forced through the radiator in either a v-mount or normal radiator setup at speeds under 100mph.
Found this on another forum:
"Since air passing through the intercooler is heated before passing through the radiator; it can cause cooling problems.
The idea is to get direct airflow onto both surfaces.
It also requires a bit of creativity to make sure the pressure zones allow for good airflow. Air will not flow through either if the pressuze zone behind each is greater than in front of the core.
This is why you will always typically see a hood extractor used in conjunction with the V-mount setup. Since that area on the front of the hood and a low pressure zone.
The undertray will also have to be modded in such a fashion to create a good low pressure zone post radiator."
this one :
That one. And yeah, its not really a v-mount, more of a way to do a stacked/ high mount intercooler setup. Still would the same kind of benefits as a v-mount I assume.
SO overall, unless its for a competition time attack/ endurance/ rally car, where the car is being pushed for an extended period of time and you want every gain in turbo response and cooling power you can get, its not going to be like a big performance gaining modification. I feel a lot of people that do this, like myself, do it just to make their car look more bad ass, stand out etc. I did it for looks and because I like taking on fab projects like this. It wasn't because I expect to see a drop of 40 degrees in coolant temps as well as lower charge temps. However, if I see such a miraculous improvement, i'll let you guys know!
I would say that v-mounts normally improve turbo spool time (say 200-500rpm quicker).
djelly84 is offline   Reply With Quote
Old 02-04-2012, 12:28 PM   #704
ColesSTi
Member#: 99205
2005 Impreza WRX
I have the ff dymanics extreme triple threat but I am having problems the radiator cap is
below the head light and the coolant cross over pipe is way above so I am getting air in
the system when I drive the car I have a element tuning full brand new long block big
valve heads so it is not the engine. Cross flow cools a lot better but I am having problems.
here is my rad http://www.ffdynamics.com/jeepradextb1.html
I have gt35 with coolant header tank all stock rad caps in correct location and rubber
hoses through out. I need to find a breather tank for the radiator?
Cole
ColesSTi is offline   Reply With Quote
Old 02-04-2012, 09:22 PM   #705
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
Take some pictures and post them lets have a look
shilohb is offline   Reply With Quote
Old 06-03-2012, 05:14 PM   #706
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
amazing ..
Vlad is online now   Reply With Quote
Old 06-10-2012, 09:41 PM   #707
RoidRage
Member#: 272471
2010 WRX FlareObody
Red
Originally Posted by kurion View Post
Finally got my process west v2 V-mount, I modified the kit so that I could run AC on the setup. Had overheating issues with my old APS DR525 with my 35R setup on the roadcourse so time for an upgrade. Special thanks to Andrewtech for the great job on the install. Pics:
vmount radiator with AC condenser fitted, see 1 or 2 transmission coolers
2 or 2 transmission coolers (2 25 row mocal coolers to keep the 4eat cool for the track)
daily driven and track driven twinscroll 35R 4eat now with V-mount and AC
OMG you are my freaking hero!
Now I just need to figure out how to squeeze this into a GR..
RoidRage is offline   Reply With Quote
Old 07-10-2012, 12:04 PM   #708
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 627/484 2015 BRZ
bumping for more 08+ applications.
A Fatal Ode is offline   Reply With Quote
Old 07-17-2012, 12:15 PM   #709
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
finished my v mount... have cold ac, a huge 2 1/2 gallon radiator, and a 980hp rated intercooler...
I let it idle for 30 minutes last week with outside temperatures of 100+ and the ac on the coolant never went over 185 witch is the thermostat rating
Old 07-18-2012, 01:02 PM   #710
RoidRage
Member#: 272471
2010 WRX FlareObody
Red
So awesome! You need to come down to cars and coffee in Plano so I can ogle it.
Old 07-18-2012, 03:06 PM   #711
05subysti
Member#: 268190
2005 STi
Man Shiloh your car is so badass. Eventually imma save up and your ginna do the v mount set up for me
05subysti is offline   Reply With Quote
Old 07-18-2012, 03:40 PM   #712
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
Thanks man... I would enjoy building this kit again
I drove the sti last night for the first time it was great!!
I am thinking about trying to attend the cupcake meet this weekend
Old 07-18-2012, 05:16 PM   #713
05subysti
Member#: 268190
2005 STi
Double post*
Old 07-18-2012, 05:43 PM   #714
05subysti
Member#: 268190
2005 STi
Dude you better go to the cupcake meet so I can drool at your engine/v mount set up lol and I bet it was a blast driving it!
Old 08-01-2012, 07:58 AM   #715
OzWRX
Member#: 15150
2015 WRX
A bit of Process West Vmount/intake manifold/fuel system....time attack spec
"The Hulk" in the build
OzWRX is offline   Reply With Quote
Old 08-01-2012, 08:10 AM   #716
PrecisionCustom
Member#: 207830
2002 Precision Built
OMG!!!!!! Looks like someone pissed it off already :0
PrecisionCustom is offline   Reply With Quote
Old 08-01-2012, 10:56 AM   #717
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Specs on that build!!
Bishop is offline   Reply With Quote
Old 08-01-2012, 08:42 PM   #718
RScoobyy
Member#: 236276
2006 OBP WRX Wagon
Hollllllyyyyyy shiiiiiiit
RScoobyy is offline   Reply With Quote
Old 08-01-2012, 10:01 PM   #719
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Damn, those are some badass strut turrets!
scby rex is offline   Reply With Quote
Old 08-01-2012, 10:22 PM   #720
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Its an actual WRC S9 shell..
tino is offline   Reply With Quote
Old 08-01-2012, 10:49 PM   #721
scby rex
Member#: 104878
02 wrxbastardchild
They put their own cage in?
Old 08-01-2012, 11:16 PM   #722
tino
Top Scoob 019
Member#: 43630
hmm i cant exactly recall but im pretty sure it was a WRC shell with cage. It had rear/front doors but no bumpers, bonnet and front fenders..
Old 08-02-2012, 08:45 AM   #723
OzWRX
Member#: 15150
2015 WRX
quote from Rexnet in Australia...
"The basis for this build is a 2005 S10 WRC chassis which has an interesting history but has never been driven"
I have spent the last week with her and I can tell you this is a special car...folks stand and stare...the desire to build something similar to this is overwhelming
"The Hulk" will make its debut (hopefully) at the World Time Attack challenge in Sydney Australia next week ( http://www.worldtimeattack.com/ )
Old 08-02-2012, 11:35 AM   #724
J3SST3R
Member#: 298926
2007 USDM STI
Satin White Pearl
How does one just get their hands on a S10 WRC body shell??
Money talks I suppose haha
J3SST3R is offline   Reply With Quote
Old 08-02-2012, 12:12 PM   #725
vatorn10
Member#: 124724
Contact Prodrive UK. They sell the chassis and complete vehicles. Last I remember the 22b's and s10 chassis sold for over $80,000.
vatorn10 is offline   Reply With Quote
The Ultimate Auxiliary Lighting and Mount Thread Rapid_Roo Electrical & Lighting 6898 09-18-2016 12:41 AM
Brembo Caliper mounting threads slightly stripped what to do? dogfrndnew Brakes, Steering & Suspension 31 03-31-2013 11:20 AM
FS : CUSCO Engine Mounts xdrian Engine/Power/Exhaust 6 06-20-2010 08:37 PM
Group N transmission mount threads JBravo920 Transmission (AT/MT) & Driveline 5 10-28-2007 10:17 PM
aftermarket seat mounting thread aspera Motorsports 8 12-05-2003 10:27 PM
