Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 01-22-2009, 09:20 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Nothing But The Best_Prodrive_KW_Ohlins-Brake Packages for All Budgets
Prodrive Coilovers
By HKS
Super rare limited edition Prodrive Coilovers made by HKS.
Spring Rate Front 12.0 Kg / Rear 8.0Kg
It has 30 adjustable levels and the factory sets it at 15
It is also height adjustable with the following:
-57mm to +33mm front suspension
-52mm to +33mm front suspension
97-01 Impreza
$1199 Shipped
02-07 WRX
04 STi
SOLD OUT
KW V3 Coilover
Ultimate Street/ Competition Coilover
During manufacturing of KW Coilover suspensions, the highest quality materials are used to produce individual suspension solutions that enable customers to adjust vehicle height according to their wishes and needs. Within the TÜV-tested adjustment parameters, this can be easily achieved using the purple-colored aluminum spring collars by adjusting the position of the yellow coated springs upwards or downwards via a specially designed exterior thread. In doing so, the vehicle height can be precisely adjusted, and customers receive exactly the result they want and/or need. The stainless steel strut housings are fitted the specific vehicle, and are available in three different damping technologies. With this variety, KW Coilover suspensions can meet the exact requirements of every customer. The complete systems including high-quality yellow springs, purple aluminum components and Elastomer bump stops with integrated dust protection system, provide a unique comprehensive solution for a personalized vehicle suspension system that meets all performance and quality demands.
PM For Best Price Anywhere
OHLINS FLAG
The Ultimate In Suspension
Öhlins Racing AB also manufactures shock absorbers for road going performance cars. Ohlins have developed a shock absorber kit for a variety of sporty cars, including BMW, Audi, Mitsubishi and Porsche, and are in the process of producing shock absorbers for many more.
This product range for street cars dramatically improves traction, handling and at the same time the comfort of the car. The shock absorbers are produced in Sweden and Japan with the specifications, and above all, the development made in Sweden.
All shock absorbers are individually tuned for each model and its specific characteristics. We test ourselves by fitting shock absorbers to each vehicle and conducting thorough tests. As usual, we believe in trying to combine the hard-to-define ‘feeling’ of our experienced drivers with measurement data obtained from our advanced equipment.
Subaru FLAG Series Features
• 25 clicks of rebound adjustment
• 20 clicks of compression adjustment
• Adjustable front camber plates
• Inverted front and rear strut design
• Includes main springs
o Front rate- 450lb/in.
o Rear rate- 335lb/in.
PM For Price
Looking to replace those work struts?
Gruppe-S has your solution.
KYB GR2
OEM Replacement
GR-2 gas shock absorbers, strut cartridges and complete struts are affordably priced, twin tube designs that blend a smooth ride quality with enhanced road control. A low-pressure gas charge and patented check valve minimize foaming and aeration to help make sure the ride stays consistent, even under rough conditions. When you want to blend like-new vehicle ride qualities with a little more control, you want KYB GR-2 gas series shock absorbers, strut cartridges or complete struts.
2002-2003 WRX (Sedan Only)
$295 Shipped
2002-2003 WRX (Wagon Only)
$295 Shipped
*** Due To The Stiffer Spring Rate on the 04-07 WRX Premature Strut Wear Can Occur and Is Not Recomended For 04-07 Applications****
KYB AGX
4 Way Adjustabability
These are the same struts the Subaru ReBrands as SPT. Save $$$ over the dealerships overpriced option.
1- Allow drivers to adjust damping to match specific driving conditions
2- Manually adjustable multistage damping.
3- Adjusts from street to strip to track in seconds.
4- No need to lift vehicle or use special tools.
5-Competition grade engineering and construction.
-Velocity-sensitive valving - Multistage valve compression enables the shock to adjust to driving conditions automatically. Under gentle road conditions, the valving allows the shock to travel freely for maximum ride comfort. As conditions get rougher, the shocks is compressed faster. The valving responds instantly, to make the shock response firmer, maintaining tire contact and vehicle control.
-Sintered iron pistons and guide rods - Sintered metal provides far greater strength than traditional metals, extending shock life and durability.
-Micro-smooth, hard-chromed piston rods - KYB has the smoothest hard-chromed rods in the business for extra-long life and reliability.
-Seamless cylinders and eye rings - Most shock cylinders & eye rings are made from flat metal and welded at the seam. KYB cylinders and eye rings are extruded as seamless cylinders, eliminating weak points created by welded seams.
-Multi-lip seals / self-sealing packing - KYB uses a triple-lip oil seal to keep the oil in and contaminants out.
-Patented check valve - KYB uses a special check valve to minimize foaming caused by the mix of oil and gas inside the shock. This helps maintain reliable performance, even under tough conditions.
-Fast on car adjustment - Convenient external dial or slot at top of rod (depending on model) allows for simple hand adjustment of the damping forces for strip, street, cruising, or high speed driving. Eliminating the need to remove parts or lift the vehicle.
$475 Shipped
*** Due To The Stiffer Spring Rate on the 04-07 WRX and Wagon- Premature Strut Wear Can Occur and Is Not Recomended For 04-07 and Wagon Applications****
Ohlins Fixed Perch Struts
Ohlins Fixed Perch Strut Kit are a great alternative to coilovers. They are 25 way adjustable, for compression and rebound simultaneously.
Great option for those looking to increase performance with out sacrificing ride quality. This is a choice for weekend warriors that still like to enjoy a comfortable ride on the weekdays.
They are used with stock or after market, stock location springs. And with stock style top hats.
Include 2 front and 2 rear struts.
02-07 WRX
04 STi
PM For Price
05-07 STi
PM For Price
Whiteline Display Items On Sale
Save$$$ On New Display Items
22mm Wagon Adjustable Front Bar (bsf12Z)
$165 Shipped
22mm WRX Front Bar (bsf33)
$145 Shipped
24mm WRX Front (bsf33xz)
$165 Shipped
22mm STi Front (bsf36z)
$1465 Shipped
24mm Rear HD Adjustable GC (bsr20xxz)
$165 Shipped
27mm Rear HD Adjustable (bsr33xxz)
$189 Shipped
WRX/ STi ALK Comfort Bushing (kca362)
$189 Shipped
Rear Toe Lock Kit (kca377)
$49 Shipped
Lateral Link Kit (kta109)
$299 Shipped
Gruppe-S STi Stle STB
Real CF
SOLD OUT
__________________
Thanks,
Gruppe-S
[COLOR=black][B]Please Note:[/B]
[I]- All Competitors Prices Beat
- All Items Are Shipped Via FEDEX
- All Orders Are Repackaged To Help Prevent Any Damage Which May Occur During Transit
- Any Order Cancellation Will Result In A 25% Processing Fee
- Local Pick-Ups Available[/I][/COLOR][I]
- [B][COLOR=Red]No Cancellation on JDM Or Special Orders. No Exceptions![/COLOR][/B][/I]
Gruppe-S is offline
Old 01-22-2009, 09:21 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Get ready for the winter season guys! Rain and snow is right around the corner so dont wait untill its too late. Packages are available for all needs from mild street to track performance.
FYI...
***All Prices Posted Are For Front and Rear Unless Specified***
Complete Brake Packages
Stage 1 Brake Package
Basic Street System
- Hawk HPS F&R Brake Pads
- Gruppe-S Brake Lines
- 1L ATE Brake Fluid
02-05 WRX $239 Shipped
06-07 WRX $259 Shipped
04-07 STi
$269 Shipped
Stage 2 Brake Package
Performance Street System
- Peak Performance 1pc F&R Slotted Rotors
02-05 WRX $575 Shipped
04-07 STi $799 Shipped
Stage 3 Brake Package
Mild Race System
- Peak Performance 1pc F&R Slotted Rotors (WRX)
- Performance Friction 2pc Rotors/ Peak Performance 1pc Slotted Rear Rotors (STi)
02-05 WRX $675 Shipped
04-07 STi$1199 Shipped
STi Stage 4 Race System
Full Race System
- Peak HP Pro (ft)/ Hawk HP+(rr)
- 2L Motul RBF600 Brake Fluid
04-08 STi $1299 Shipped
Peak Performance Rotors
Australian Made!!!
100% Australian Made. Not the cheap China rotors you see on ebay.private labeled from a world-famous Australian rotor manufacturer and offer the best value in a high performance rotor system for your car. Manufactured to the same specifications as OEM components in an ISO certified production facility. The rotors are made using high quality casting techniques and precision machined to provide the maximum stopping and cooling efficiency. Rigorously tested on track and street cars these rotors offer long life, reduced brake fade, reduced pad wear, and improved wet / dry weather braking.
2004-2008 STi $599 Shipped
***Dual Drilled For 5x100 & 5x114 Bolt Patterns***
Brembo Cores!!!
100% Brembo Cores. Not the cheap China rotors you see on ebay.Private labeled from a world-famous American rotor manufacturer and offer the best value in a high performance rotor system for your car. Manufactured to the same specifications as OEM components in an ISO certified production facility. The rotors are made using high quality casting techniques and precision machined to provide the maximum stopping and cooling efficiency. Rigorously tested on track and street cars these rotors offer long life, reduced brake fade, reduced pad wear, and improved wet / dry weather braking.
2002-2005 WRX $325 Shipped
Performance Friction Race Rotors
Used In JGTC & NASCAR
Used by some of the top teams in JGTC and NASCAR. Perfromance Friction rotors allow you to retain the Stock STi Brembo Calipers (which are excellent pieces) while reaping all the benefits of a 2-piece rotor. They are 4.4 lbs. lighter per rotor than the stock pieces meaning that unsprung and rotational mass are dramatically decreased. This will create better feedback and improved handling. These rotors are also vaned to improve cooling over the stock pillared units. Finally, dimples ensure that your pads are adequately refreshed while maximizing surface of the rotor and preventing cracking (as compared to crossdrilled rotors).
-5X100 and 5X114.3 fitment!
-2-piece design allows aluminum hat for lightweight rotors.
-Full floating design allows expansion of rotor and hat at different rates to prevent pad coning.
-Lightweight - 17.6 lbs per rotor (stock rotors are 22 lbs.).
-Dimpled to increase surface area of rotor (promotes cooling), refresh pads, and less prone to cracking than cross drilled rotors.
-Vaned to promote cooling.
2004-2008 STi Fronts Only $740 Shipped
Hawk Brake Pads
HPS
Hawk Performance HPS-High Performance Street disc brake pads are designed for sports cars, coupes, sedans and pickup trucks and sport utility vehicles used for high speed driving or that may encounter repetitive heavy braking.
HP+
Hawk Performance's HP Plus disc brake pads are designed for sports cars, coupes and sedans for sport driving in autocross, Solo II and many “track day” applications. .
Warning! Due to the dramatic friction levels produced by this product to achieve "race-level" braking, rotor wear, noise, dust, and pad life may be affected.
For over 15 years, Hawk Performance has dominated the racetrack by providing champions with cutting-edge friction materials. Whether you are looking to improve your braking ability during the next lapping day or looking to make your move on the final lap, Hawk has you covered with a wide array of Motorsport Compound Pads.Recommended Use: Hawk's most popular Motorsport Compound offers excellent modulation and braking power for a wide variety of applications. Strong initial bite combines with exceptional pedal feel to give drivers confidence during road racing and stage rally events. Also popular with experienced lapping day and driver school participants.
HPS 02-05 WRX $156 Shipped
HPS 06-07 WRX $157 Shipped
HPS 04-07 STi $195 Shipped
HP+ 02-05 WRX $205 Shipped
HP+ 06-07 WRX $205 Shipped
HP+ 04-07 STi $235 Shipped
Blue 02-05 WRX $260 Shipped
Blue 06-07 WRX $289 Shipped
Blue 04-07 STi $385 Shipped
***Free Bottle of ATE Fluid with Purchase of F&R Brake Pad Set.***
Peak Performance HP-Pro
Made By Hawk Racing
Now Available at Gruppe-S.Dont confuse these pads with Standard HPS or HP+ Pads in a different box. These pads are a Brand New Special Compound Designed Exclusively for Peak Performance. Peak Performance HP-PRO™ Brake Pads. Using a secret compound blend formulated by Hawk Performance™, HP-PRO™ Brake Pads offer an extremely high coefficient of friction making these a perfect upgrade over stock for high performance streetcars used in Drifting, Autocross, Time Attack or drivers that experience repetitive, heavy braking. Peak Performance secret compound gives you uniquely controllable torque with smooth consistent feel and bite. This compounds allow for later and deeper brake use into the corners while requiring less pedal effort and shorter pedal reaction times. They do not require significant heat up or extensive bedding (break-in), and have exceptional wear characteristics allowing you to get more laps per set with no warm up required. HP-PRO™ provide superior release and torque control characteristics. HP-PRO™optimal temperature range is 95-1,250 degrees Fahrenheit.
04-08 STi Fronts Only $149 Shipped
Gruppe-S Steel Braided Brake Lines
Free ATE Fluid
Gruppe-S Stainless Steel Braided Teflon Hoses could very well be the easiest and least expensive way to upgrade your braking system. In any braking system there is flex ? in the pedal, in the caliper, but most of the flex is in the hose.
$99 Shipped
***Free 1 Liter Bottle Of ATE Fluid***
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 01-22-2009, 10:56 PM   #3
Kyle_R
Member Sales Rating: (34)
Member#: 197528
2012 2015 GLA250
2004 WRX-R.I.P
BUMP!, will put a down payment for the HKS prodrives hopefully saturday!
Kyle_R is offline
Old 01-23-2009, 02:33 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Phone sales are not open on weekends.
If you are local stop on by and leave a deposit.
A few sets are left so dont wait too long.
Thanks For the Bump!
Gruppe-S
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 01-23-2009, 08:13 PM   #5
nottofast
Member Sales Rating: (59)
Member#: 89663
1962 Fuji 350
cerelean blue
Default Prodrive HKS coilovers
04 STi
$1199 Shipped
The prodrive coilovers, are there any other spring rates available? Something more streetable? I still have not found what Iam looking for. Thanks, John.
nottofast is offline
Old 01-23-2009, 08:20 PM   #6
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Originally Posted by nottofast View Post
04 STi
$1199 Shipped
Sorry no other rates availbale
These are competition coilovers. If you want something soft for the street. try the KW
The only thing is your not going to find them anywhere near the price..
Come on man you drive an STi! Im sure you didnt buy it for the soft ride and spacious trunk.
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 01-23-2009, 10:58 PM   #7
Kyle_R
Member#: 197528
2012 2015 GLA250
2004 WRX-R.I.P
what are the pricing for the Kw for my 2002 wagon? which suspensions would you think is best for my wagon the HKS prodrives or the KW for a nice stiff ride.
Kyle_R is offline
Old 01-23-2009, 10:59 PM   #8
Kyle_R
Member#: 197528
2012 2015 GLA250
2004 WRX-R.I.P
and would it cost the same if i drop to your shop and picked it up. its only like 30 minutes away from my house in orange county.
Kyle_R is offline
Old 01-24-2009, 03:38 PM   #9
cooldjryan
Member Sales Rating: (-1)
Member#: 68063
2004 Cobb Stg 2 WRX
San Remo Red
price for kw v1's for an 04 WRX and a stage 2 brake package shipped to 92101?
cooldjryan is offline
Old 01-26-2009, 03:05 PM   #10
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Kw would be the softest of the two. If you want a stiff setup I suggest the Prodrive. Price sent for KW
Thanks
Gruppe-S
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 01-26-2009, 03:09 PM   #11
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Price would be the same. Please note that CA residents require sales tax
Thanks
Gruppe-S
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 01-26-2009, 03:13 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Pm Sent
Thanks
Gruppe-S
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 01-26-2009, 03:46 PM   #13
schimsk
Member Sales Rating: (1)
Member#: 78672
Are the PFC direct drives in stock and ready to ship?
schimsk is offline
Old 01-26-2009, 05:16 PM   #14
7aSt129
Member Sales Rating: (5)
Member#: 61683
2004 WRX
aspen white
Could i get a price quote on the ohlins fixed perch struts picked up? Also, what are some recommend coilovers for street and some track (plan to track maybe 2-3 times a year)?
7aSt129 is offline
Old 01-26-2009, 05:34 PM   #15
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Sorry all sold out. ETA from PFC 1-2 weeks
Thanks
Gruppe-S
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 01-27-2009, 02:38 PM   #16
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Tuesday Bump Guys
The Word of the Day for January 27, 2009 is:
obtuse • \ahb-TOOS\ • adjective
1 a : not pointed or acute b : exceeding 90 but less than 180 degrees
*2 : lacking sharpness or quickness of sensibility or intellect
3 : difficult to comprehend : not clear or precise in thought or expression
Example Sentence:
The child was so stubborn in her refusal to understand that I began to suspect she was being deliberately obtuse.
Did you know?
"Obtuse," which comes to us from the Latin word "obtusus," meaning "dull" or "blunt," can describe an angle that is not acute or a person who has a "dull" or insensitive mind. The word has also developed a somewhat controversial third sense of "hard to comprehend," probably as a result of confusion with "abstruse." It is now possible to speak of "obtuse language" and "obtuse explanations," as well as "obtuse angles" and "obtuse readers." This sense of "obtuse" is well established, but it may attract some criticism. If you're hesitant about using new meanings of words, you should probably stick with "abstruse" when you want a word meaning "difficult to understand."
*Indicates the sense illustrated in the example sentence.
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 01-28-2009, 03:21 PM   #17
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Wednesday Bump
The Word of the Day for January 28, 2009 is:
primogeniture • \prye-moh-JENN-uh-chur\ • noun
*1 : the state of being the firstborn of the children of the same parents
2 : an exclusive right of inheritance belonging to the eldest son
Example Sentence:
Brian argued that primogeniture gave him the right to the first piece of cake among his siblings.
Did you know?
In many civilizations, past and present, the state of being the oldest among siblings is a key component of inheritance law. “Primogeniture,” which first appeared in English in the early 17th century, derives from the Late Latin “primogenitura,” a combination of the Latin “primus” (“first”) and “genitura” (“birth”), from the past participle of “gignere” (“to beget”). For those who are youngest in birth order, a similar word applies -- “ultimogeniture” -- but this word is newer (first appearing in English in 1882) and much less common.
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 01-29-2009, 02:44 PM   #18
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Thursday Bump
The Word of the Day for January 29, 2009 is:
indubitable • \in-DOO-buh-tuh-bul\ • adjective
: too evident to be doubted : unquestionable
Example Sentence:
He was regarded as a film director of indubitable insight and talent, and his movies were among the most beloved in the history of cinema.
Did you know?
There's no reason to question the fairly straightforward etymology of "indubitable" -- a word that has remained true to its Latin roots. It arrived in Middle English in the 15th century from Latin "indubitabilis," itself a combination of "in-" ("not") and "dubitabilis" ("open to doubt or question"). "Dubitabilis" is from the verb "dubitare," meaning "to doubt," which also gave us our "doubt." The word "dubitable" also exists in English, and of course means "questionable or doubtable," but it is fairly rare.
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 01-30-2009, 07:27 AM   #19
cid369
Member#: 99477
2016 Ford Focus RS
Nitrous Blue
Price on Ohlins Fixed Perch Struts for 05 STi.
Thanks.
cid369 is offline
Old 02-11-2009, 09:07 PM   #20
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Closing Thread Guys
Click Here For Updated Specials
http://forums.nasioc.com/forums/show...5#post25554365
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Closed Thread
PROJECT MU SPECIAL NOW! Ultimate Brake Packages Sale All WRX/STi Hawk/Stoptech/DBA Gruppe-S Vendor 'General Sale' Forum 46 11-12-2010 05:22 PM
I have nothing but the utmost respect for those deploying to overseas. Mud Pig Off-Topic 58 10-20-2009 05:05 PM
Turbo Timers On Sale!!! Free Harness_Gauge Packages For All Budgets Gruppe-S Gauges & Electronics 9 03-10-2009 10:38 PM
Nothing but the Unichip MyRuRex Engine Management & Tuning 3 02-13-2003 10:18 AM
Boostmonkey vs. MBC: Nothing but the Truth! Blitzer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-24-2002 12:56 PM
