Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 01-22-2009, 09:38 PM   #1
Celtic Motorsport
Vendor Sales Rating: (24)
Member#: 200280
Default Free Shipping All Cosworth includes Short & Long Block Engines!
We are offering FREE shipping on all Cosworth items including short and long block engines. Free shipping is for the continuous 48 states. Alaska, Hawaii and International will be discounted shipping rates. For local pick up customers in the Fullerton area we will work out something to help you out with tax.
Click on the description of each item to be redirected to our web page to see specific details about the item or to place an order. When ordering online to get free shipping type "Nasioc Free Shipping" in the comment section of your order and it will be adjusted. You will be emailed your revised order and invoice showing the correct amount. You can also call in your orders to 714-459-5252 or email inquires to [email protected].
Cosworth (2.5L) CNC Ported Big Valve Cylinder Heads w/Cams 04-06 # SB8010
$5578.00
Cosworth (2.5L) CNC Ported Big Valve Cylinder Heads w/Cams 2007+ #20002024
$5578.00
Cosworth EJ25 (STI) CNC Ported Big Valve Cylinder Heads 04-06 NO/Cams #KK3670
$4011.00
Cosworth EJ25 (STI) CNC Ported Big Valve Cylinder Heads 2007 NO/Cams #20001699
$4011.00
Cosworth Air Pump Delete Plate # 20004539
$64.00
Cosworth Cam Angle Sensor Bracket (Billet) # SB0002
$61.00
Cosworth EJ20 (2.0L) High Performance Head Gaskets .78mm # 20000919
$85.00 each
Cosworth EJ20 (2.0L) High Performance Head Gaskets 1.1mm # 20000922
$85.00 each
Cosworth EJ25 (2.5L) High Performance Head Gaskets .78mm # 20000913
$85.00 each
Cosworth EJ25 (2.5L) High Performance Head Gaskets 1.1mm # 20000916
$85.00 each
Cosworth EJ25 (2.5L) High Performance Head Gaskets 1.5mm # 20002145
$95.00 each
Cosworth EJ25 STI Forged Piston Set 99.5mm Bore # 20003674
$950.00
Cosworth EJ25 STI Forged Piston Set 99.75mm Bore # 20003675
$950.00
Cosworth EJ25 STI Forged Piston Set 100mm Bore # 20003676
$950.00
Cosworth EJ25 Forged Stroker Piston Set 2.6L 99.5mm # 20003682
$950.00
Cosworth EJ25 Forged Stroker Piston Set 2.6L 99.75mm # 20003683
$950.00
Cosworth EJ25 Forged Stroker Piston Set 2.6L 100mm # 20003684
$950.00
Cosworth Subaru EJ20 Forged Piston Set 92mm/8.0:1 # 20003677
$950.00
Cosworth Subaru EJ20 Forged Piston Set 92.5mm/8.0:1 # 20003677
$950.00
Cosworth EJ25 (2.5L) Performance Piston Ring Sets 99.5mm # 20001515
$115.00
Cosworth EJ25 (2.5L) Performance Piston Ring Sets 99.75mm # 20001516
$115.00
Cosworth EJ25 (2.5L) Performance Piston Ring Sets 100mm # 20001517
$115.00
Cosworth EJ20 (2.0L) Performance Piston Ring Sets 92mm # 20005160
$115.00
Cosworth EJ20 (2.0L) Performance Piston Ring Sets 92.5mm # 20005161
$115.00
Cosworth EJ20 (2.2L) Stroker Kit Billet Crank # 20002502
$6066.00
Cosworth EJ25 (2.6L) Stroker Kit Crank # 20002500
$6066.00
Cosworth EJ20 Camshaft Set # KK3765
$993.00
Cosworth EJ25 STI Camshaft set- North American Spec 2.5L # KK3766
$1098.00
Cosworth EJ20/25 Oil Pump # KK3928
$285.00
Cosworth EJ20/EJ25 High Volume/Pressure Blueprinted Oil Pump # 20001185
$465.00
Take care,
Brett Moncur
Parts Manager
Celtic Motorsport
www.celticmotorsport.com
[email protected]
[email protected]
Celtic Motorsport is offline
Old 01-22-2009, 09:44 PM   #2
Celtic Motorsport
Member#: 200280
Cosworth EJ20/EJ25 Billet Timing Belt guide # SB0001
$61.00
Cosworth EJ20/EJ25 Forged H Beam Connecting Rod set # 20002587
$929.00
Cosworth EJ20/EJ25 High Performance Tri-Metal Main Bearing Set # PR7940
$91.00
Cosworth EJ20/EJ25 High Performance Tri-Metal Rod Bearing Set # PR7889
$71.00
Cosworth EJ20/EJ25 High Performance Cylinder Head Stud Kit 11mm # 20002440
$446.00
Cosworth EJ25 High Performance Short Block Assembly # SB8005 20007702
$5,284.00
Cosworth EJ25 High Performance Short Block Assembly w/ Billet Crank # SB8007 20007703
$8,806.00
Cosworth EJ26 High Performance Stroker Short Block Assembly # 20003486 20007697
$8,806.00
Cosworth EJ25 STI (2.5L) 79mm Stroke Billet Crankshaft # 20002315
$3,800.00
Cosworth Stroker Crankshaft, 81mm Subaru EJ25 # 20002316
$3,800.00
Cosworth Subaru EJ25 (2.5L) Longblock Standard Crank # 20000161 20002504
$11,742.00
Cosworth Subaru EJ25 (2.5L) Longblock Billet Crank # 20000162 20002503
$15,557.00
Cosworth Subaru EJ26 (2.6L) Stroker Longblock Billet Crank # 20003488 20003489
$15,557.00
Cosworth High Performance Valve Spring Set (16) # 20000166
$309.00
Cosworth High Performance Valve Spring Set & Titanium Retainers # KK3839
$756.00
Cosworth High Volume Oil Pan # 20001238
$570.00
Take care,
Brett Moncur
Parts Manager
Celtic Motorsport
[email protected]
[email protected]
Old 01-22-2009, 09:47 PM   #3
Celtic Motorsport
Member#: 200280
Cosworth Oil Control Baffle # 20002499
$285.00
PRE-ORDER Available Late January 2009
Cosworth FMIC 08+ STi # 20005378
$2185.00
PRE-ORDER Available Early February 2009
Cosworth Subaru High Volume Inlet Manifold # 20005378
$950.00
Take care,
Brett Moncur
Parts Manager
Celtic Motorsport
[email protected]
[email protected]
Old 01-26-2009, 07:10 PM   #4
Celtic Motorsport
Member#: 200280
bump...
Old 01-30-2009, 03:26 PM   #5
Celtic Motorsport
Member#: 200280
bump...
Old 02-04-2009, 02:22 PM   #6
Celtic Motorsport
Member#: 200280
bump...
Old 02-11-2009, 05:44 PM   #7
Celtic Motorsport
Member#: 200280
bump...
Old 02-17-2009, 01:40 PM   #8
Celtic Motorsport
Member#: 200280
bump...
Old 02-26-2009, 12:36 AM   #9
dudley123
Member Sales Rating: (7)
Member#: 120831
PIA Purpose Built -
SEMA-FullRace/HRE/Cosw.
pm me.. Do you actually have any in stock? Or is there still the lead time... I am interested in the Longblock stk crank from cosworth..
dudley123 is offline
Old 02-26-2009, 02:09 PM   #10
Celtic Motorsport
Member#: 200280
dudley123 - Sent you a PM. Let me know if you need anything else.
Take care
Brett
Old 03-09-2009, 05:50 PM   #11
Celtic Motorsport
Member#: 200280
bump...
Old 03-23-2009, 06:55 PM   #12
Celtic Motorsport
Member#: 200280
bump...
Old 04-08-2009, 05:44 PM   #13
Celtic Motorsport
Member#: 200280
bump...
Old 04-20-2009, 06:00 PM   #14
Celtic Motorsport
Member#: 200280
bump...
Old 05-04-2009, 03:53 PM   #15
Celtic Motorsport
Member#: 200280
bump...
Closed Thread
Sale on EJ257 Blocks! Free Shipping on Cosworth and Cobb parts +SPT, Perrin, Blitz!!! FlatironsTuning.com Flatirons Tuning 332 01-18-2016 03:33 PM
--> Cobb AccessPort $595 Shipped Free Overnight! All Years including 2010 Instock! Spun Autosports Engine Management 135 05-02-2010 07:24 AM
Free Shipping on Cosworth Heads & Blocks, Cobb Access Ports, and more. FlatironsTuning.com Engine/Power/Exhaust 19 06-27-2008 12:36 PM
STI short or long block 2002ImprezaRS Private 'Wanted' Classifieds 2 07-17-2005 09:29 PM
The difference between short and long blocks as told by one man Aspen_2.5RS South East Region Forum 1 03-15-2003 04:03 PM
