Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 01-23-2009, 03:28 PM   #1
jacky599r
Member#: 137631
2006 WRX
Red
Default what to check for irratic idle and stalling?
Hello,
I have this problem quite sometime back but its starting annoy me even more as the day passes. The car idles smoothly at times, just like stock. However, at times (getting more frequently) it will seems like its hunting to get back to the ideal idle rpm, causing the oil press alarm in my defi to go off with it. Ive cleaned my tb and maf sensor. A point to note is i have a cusco super single clutch kit which comes with a lightened flywheel. The thing is the erratic idle problem has already been there but i guess the lightened flywheel just escalated it and made it the engine stall occasionally. I would like to check who has got the same experience and what can i do / check to remedy the situation. Cheers!
jacky599r is online now   Reply With Quote
Old 01-23-2009, 04:23 PM   #2
GrimmSpeed
Member#: 136396
2012 wrx
white
Check your sparkplugs and electric. If everything seems fine there try consulting your tuner or posting logs online.
Mike
GrimmSpeed is online now   Reply With Quote
Old 01-23-2009, 04:54 PM   #3
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Check your grounds too. Do you have aftermarket electronics? Make sure everything is properly grounded. No exposed wires, no miswired stuff. This happens quite often and messes with your idle.
Also, check that you have oil haha. <-- stupid I know, but one time it turned out I had very little oil in the car for some odd reason....
verc is offline   Reply With Quote
Old 01-23-2009, 05:32 PM   #4
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Do you have a wideband or can make some logs?
Sounds like a vacuum leak to me
Old 01-23-2009, 06:13 PM   #5
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Most weird idles problems are due to vacuum leaks in my experience. Check all your vacuum fittings and lines.
Old 01-23-2009, 10:44 PM   #6
saab-on-the-cobb
Member#: 116330
2006 300C 5.7 Hemi
Grandpa Gold.
Yes, and inspect the MAF sensor for dirt/buildup.
sotc
saab-on-the-cobb is offline   Reply With Quote
Old 01-24-2009, 06:19 AM   #7
jacky599r
Member#: 137631
2006 WRX
Red
yo. Thanks. The problem will start to show during e warm up cycle. Its very pronounced during a stop and go situation, like that of parking my car. I must admit e electric system is not the best since i have tie engine pulled twice affecting the groundings. I do have a wide band and will loh and post it
Old 01-24-2009, 04:59 PM   #8
xrallyx
Member#: 184292
maf/map vac lines, replacement of bypass/recirculating valve with bov?
xrallyx is offline   Reply With Quote
Old 01-25-2009, 07:28 AM   #9
Iflysti06
Member#: 156955
2006 STI
UR GT35R w/ mad bolt ons
Had the same problem once and grounding was my issue!
Iflysti06 is offline   Reply With Quote
Old 01-26-2009, 06:58 AM   #10
jacky599r
Member#: 137631
2006 WRX
Red
argh, my new laptop just wouldnt sync with the usb to serial controller! pissed and i cant get any logs out.
Anyway, how do u go about checking that its the grounding thats causing this?
Old 01-26-2009, 09:51 AM   #11
Member#: 51961
2005 STi
2012 WRX
No need to log the wideband as long as you have a gauge on it, just tell us what it's doing.
Old 01-26-2009, 10:20 AM   #12
jacky599r
Member#: 137631
2006 WRX
Red
ok, sure i think ill log down just the activites in idle without the wideband
Old 01-27-2009, 11:34 AM   #13
jacky599r
Member#: 137631
2006 WRX
Red
where can i get the instructions to post datalogs?
i have some logs from my utec
Old 01-27-2009, 12:03 PM   #14
scottD
Member#: 94748
Do you have an after market BOV?
Sounds like you may need a stronger spring in it...
scottD is offline   Reply With Quote
Old 01-27-2009, 01:05 PM   #15
jacky599r
Member#: 137631
2006 WRX
Red
hmmm. i have the forged bpv. it holds boost well as i just got the car tuned.
Irratic Idle and Stalling Scoobie2.0 Newbies & FAQs 26 10-18-2009 01:07 PM
Not achieving full boost what to check for? si12j12 Factory 2.0L Turbo Powertrain 2 11-15-2008 01:53 AM
what to check for when buying used cobb ap v1..? TIA MrMakesitRain Newbies & FAQs 8 06-14-2008 04:05 AM
Going to a car auction what to check for? Riot Type WRX Off-Topic 7 11-27-2006 04:57 PM
Where to go to check for bent chassis and a good alignment shop? View Askew Bay Area Impreza Club Forum -- BAIC 3 03-22-2003 09:47 PM
Message Board Statistics All times are GMT -4. The time now is 12:50 PM.
