#1 |
Member#: 43196
TXIC
Vehicle:1998 2.5 RsT 93GF 95GC 02GD 01SF-T |
Anyone have the specs on the airgap between the pick up on the back of cam sprocket to the nub on the cam sensor. Car has been apart for 3 months and ran fine before I took it apart. Machine shop broke the tab for the cam sensor and was welded back into place. Now I only get two coils firing at a time and the car won't start. Any help would be appreciated.
also when i move the sensor close to the sprocket i only get two coils firing. when i pull it out at about a .25 gap all four will fire but when i assemble everything back the car wont start. Car is a swapped gc8 with a legacy twin turbo motor
#2 |
Member#: 50993
Vehicle:02 WRX Wagon 2.5/Blouch Dom 3/Meth/6sp |
I looked into this once before. Below is info from my Tuner.
"I believe the gap should be around .028" between the sensor and trigger wheel". |
#3 |
Member#: 43196
TXIC
I thought a quater inch was waaaaaaaay off.
#4 |
Member#: 50993
I'm curious how this turns out for you. Let us know if it works better.
#5 |
Member#: 43196
TXIC
I have a feeling the cam sensor is bad or the sensor bracket isn't in line with the cam sprocket pick ups. The car ran fine before I pulled the heads for head gaskets. I also did the clutch, replaced tranny and rear end. All 02 wrx drivetrain, including flywheel.
| Thread Tools | |
| Display Modes | |
| cam position sensor problem | downest | Factory 2.5L Turbo Powertrain | 9 | 04-17-2010 08:32 AM |
| cam sensor problems | backslider | Texas Impreza Club Forum -- TXIC | 0 | 01-23-2009 04:30 PM |
| Cam sensor problems | skate enjoi | Built Motor Discussion | 10 | 04-21-2007 12:25 AM |
| AVCS Cam Sensor Problem with JDM Swap HELP!!! | wrxfactor | Factory 2.0L Turbo Powertrain | 2 | 04-11-2006 07:42 PM |
| ECU for MT 02 WRX that doesn't have the cam position sensor problem | SW00P_G | Private 'Wanted' Classifieds | 3 | 07-30-2003 11:29 AM |
