Old 01-23-2009, 06:44 PM   #1
mattmx525
Member#: 118525
2002 wrx. stg 4+
blue
Default 02 wrx missfires on all 4 cylinders
02 wrx 97xxx miles. 20g, ewg, meth, fmic, 750cc inj ect. iv had a rough idle before and cleaning the IAC seemed to fix that. so yet again about a week ago i cleaned it again cuz my idle was gettin bad again, and it was dirty. in the last few days i started noticing a studder at low rpm getting up to speed, which has steadily gotten worse and today the car is blinking the cel and breaking up... no idea whats bad. i cleaned the maf, and IAC and no different. dunno coil, plugs, timing belt.. any ideas?
mattmx525 is offline   Reply With Quote
Old 01-23-2009, 07:44 PM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
ya likely blew it up
check compression
Old 01-23-2009, 08:07 PM   #3
mattmx525
Member#: 118525
2002 wrx. stg 4+
blue
well, it backfires alitle and shutters then gets through...then has no loss in power at all, idles fine. no sighnes of a blown motor such as smoke or power loss. it begun happening after my last gas fillup as well, possibly a fuel related problem. but i guuess thats something to check
Old 01-23-2009, 08:38 PM   #4
meebs
Member#: 3251
2009 WRX Hatch
When was the last time you replaced the fuel filter?
meebs is offline   Reply With Quote
Old 01-25-2009, 03:07 AM   #5
zaxrex
Member#: 9898
Water Injected Blue
The CEL is blinking? Is that from your EM? What codes do you have?
zaxrex is offline   Reply With Quote
Old 01-25-2009, 03:45 AM   #6
StupidFastWagon
Member#: 157526
2013 328i xDrive
M Sport
Let me ask you this, What EM do you have and who tuned your car?
StupidFastWagon is online now   Reply With Quote
Old 01-25-2009, 08:54 PM   #7
mattmx525
Member#: 118525
2002 wrx. stg 4+
blue
i havent changed my fuel filter ever, unless it was changed when i got my 255 fp put it. but i think theres two? my engine management is Ecutek and tuned by extreme motorsports.
Old 01-25-2009, 08:55 PM   #8
mattmx525
Member#: 118525
2002 wrx. stg 4+
blue
and the codes are p301, p302, p303, p304. all cylinder misfires.
Old 01-25-2009, 09:39 PM   #9
psm04wrx
Member#: 134804
97 impreza L wagon
beater black
sounds like possible harness issue
psm04wrx is offline   Reply With Quote
Old 01-25-2009, 10:36 PM   #10
BluScubi
Member#: 162726
2009 LGT
QSM
Check compression, take a look at your plugs while you're in there. If they have never been changed you should change them anyways. It's very unlikely ALL of your coil packs went bad at once. In my experience misfire on all cylinders can be caused by running too rich or too lean as well.
BluScubi is offline   Reply With Quote
Old 01-25-2009, 11:27 PM   #11
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
02 wrx 97xxx miles
Old 01-25-2009, 11:37 PM   #12
Tut4u2
Member#: 40424
Its a boat
on jack stands
Fuel filter needs to be changed every 30k miles I believe.
And like everyone has suggested, check your compression, and while you're at it change your spark plugs as well if you haven't done that recently. Consistent misfire could also mean that your coils are bad, but having all 4 go at the same time seems a long shot.
Tut4u2 is offline   Reply With Quote
Old 01-27-2009, 05:45 PM   #13
mattmx525
Member#: 118525
2002 wrx. stg 4+
blue
changed the fuel filter and no different. now its only misfiring on the 2nd and 4th cylinders. aka p302 pd, p304 pd. so they missfire over and over again. breaking up and alot of shaking when i test drove it. backfiring when coming into boost. havent got around to a comp test the weather here is killin me. iv come up with maybe its a bad injector(s), spark plugs, coils..i guess ill start goin down the line. anyone else had problems like this? where to start?
Old 01-27-2009, 06:53 PM   #14
BluScubi
Member#: 162726
2009 LGT
QSM
Sounds stupid but try reseting the ECU. I had a situation once where I changed plugs and it ran like crap afterwards because the fuel trims had compensated for the bad plugs. Reset the ECU and it ran pefect.
Old 01-27-2009, 07:00 PM   #15
Tut4u2
Member#: 40424
Its a boat
on jack stands
I would check the coils first. Since you're getting misfires now on one side of the engine just switch the coils with the otherside and see if you start misfiring 1 and 3 now; if you do then you need 2 new coils.
Old 01-27-2009, 07:15 PM   #16
rafacz2002
Member#: 169957
2002 impreza wrx
black
i had same problem not long ago. try changing the spark plugs. if that doesnt help than you will have to replace your coil on plugs.
rafacz2002 is offline   Reply With Quote
Old 01-27-2009, 07:23 PM   #17
2bad240
Member#: 141168
2003 wrx S-wagon psm
rotated hx35 6mt meth
my car is doing the same thing. happened after i changed my injectors and switched tune.
2bad240 is offline   Reply With Quote
Old 01-27-2009, 08:29 PM   #18
mattmx525
Member#: 118525
2002 wrx. stg 4+
blue
yea i reset my ecu after i did the fuel filter. i guess ill start with the coils then, probably change the plugs while im at it
Old 01-27-2009, 11:57 PM   #19
rafacz2002
Member#: 169957
2002 impreza wrx
black
do plugs first new coils are about 400 bucks. thats where i made my mistake and bought new coils instead of checking plugs. i replaced my coils and it turned out to be the plugs being the problem. so i have a perfect set of used coils sitting in my closet
Old 01-28-2009, 07:05 AM   #20
mattmx525
Member#: 118525
2002 wrx. stg 4+
blue
yea alright. iv got the ngk iriduim one step colder plugs in there now, and there only about 20,000 miles old. so its possible their bad i guess, my car does seem to run rich so maybe that had something to do with it.
Old 01-28-2009, 10:11 AM   #21
Tut4u2
Member#: 40424
Its a boat
on jack stands
try putting in some stock NGKs im there. and check the gap on yourr cirrent p.ugs
Old 01-28-2009, 10:45 AM   #22
sigurd
Member#: 128721
2002 impreza WRX
psm
spark plugs dude. Like ^^he said put stock ones in there and gap them.
sigurd is offline   Reply With Quote
Old 01-28-2009, 10:32 PM   #23
mattmx525
Member#: 118525
2002 wrx. stg 4+
blue
new plugs no difference. brought it to the shop for a full diagnostic to actually see whats wrong. hopefully ill know by tmro
Old 01-29-2009, 04:18 PM   #24
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
Matt, I have a similar setup on an 02 with 105k miles. Every now and then i get misfire codes from all 4 at once too. However, mine is caused by the "just a little too light" flywheel i put put on there (i don't recall the weight, but Dave at Rallispec said it's borderline and "may" cause misfire codes - and it does), which throws the crank and cam sensors out of phase just enough to throw the codes. I'm sure my driving habits contribute to that too though =]
You don't by chance have a lightened flywheel, do you?
I would also check the 'obvious' stuff.. oil covered MAF sensor (did this once to myself by not letting the K&N oil soak in long enough on the filter. Got around the block and it sputtered to a halt). It can be cleaned with a q-tip and rubbing alcohol.
I've also had my MAP sensor o-ring 'spit' and cause weird problems...
It really could be anything. Front O2 sensors can get 'flaky' and cause the engine to be over fueled, yet never throw a O2 sensor code. My front one failed at around 85k. When that happened, it ran like an old chevy with the choke flap jammed shut... black smoke, shuttering, sputtering, backfiring. Damn thing didn't give any warning either.
NitroTrike is offline   Reply With Quote
Old 01-29-2009, 04:23 PM   #25
mattmx525
Member#: 118525
2002 wrx. stg 4+
blue
yea iv got a 9.5 lb prolight findazia flywheel ha. but i cleansed the maf n whatnot, yet the diagnostic i got says iv got a bad TGV asssemmbly? wtf. which is a 600 dollar part and damn i really doubt if that solves any problems. its not throwing that code at all. they said an injector is overloading a cylinder becasue of this, that the tgv interfered with the pulse of the injector. i think hes full of it because this makes no sense to me. What do yal think?
Missfire on all 4 cylinders... Skippy5883 Factory 2.0L Turbo Powertrain 2 03-31-2009 08:31 PM
Missfire on all 4 cylinders califesaver Factory 2.0L Turbo Powertrain 9 09-20-2008 10:12 PM
Help. Missfire on all 4 cylinders. Chaotic Yeti Factory 2.0L Turbo Powertrain 5 04-24-2008 03:07 PM
Missfire on all 4 cyl. 04 sti trbowrx Factory 2.5L Turbo Powertrain 5 01-29-2008 02:19 PM
misfiring on all 4 cylinders tEkkGOD Factory 2.0L Turbo Powertrain 12 09-08-2003 09:26 PM
Message Board Statistics All times are GMT -4. The time now is 11:05 PM.
