Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 01-23-2009, 07:37 PM   #1
KC
Member#: 442
16 SS
00 S2000
Default 2009 SCCA Solo Rules on-line
KC is online now   Reply With Quote
Old 01-23-2009, 08:13 PM   #2
Chiketkd
Member#: 71634
In hibernation...
Thanks KC.
P.S. Got the package this afternoon. Merci!
Chiketkd is offline   Reply With Quote
Old 01-23-2009, 08:24 PM   #3
mofugga
Member#: 19540
2000 old skool RS
BRP
did i miss something? sts is now st and st2 is now sts?
mofugga is offline   Reply With Quote
Old 01-23-2009, 09:16 PM   #4
KC
Member#: 442
16 SS
00 S2000
Yes.
Hence: http://forums.nasioc.com/forums/show....php?t=1683689
--KC
Old 01-23-2009, 11:13 PM   #5
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
When did the brake rules change in SP. I guess I was asleep when this happened. I guess I can run at WRX brake on my car in DSP or if I ran on 17's. My 05 LGT brakes I use for the track.
15.6 BRAKES
Vehicles may only exceed the allowances of 13.6 as specified
herein.
A. Any brake line, single or dual master cylinder, vacuum brake
booster, or brake proportioning valves may be used. This does
not allow multiple separate cylinders, but does allow for any
single, dual-circuit cylinder.
B. “Safety brakers” and units such as the “Brake Guard System”
are permitted.
C. ABS braking systems may be disabled, but not removed; brake
boosters may be removed, modified, substituted, or added.
D. Alternate brake rotors are permitted, subject to the following
restrictions:
1. Rotors must be ferrous metal except for standard parts. Aluminum
rotor hats are allowed. Rotor dimensions (diameter
and thickness) must be equal to or greater than standard
parts. Cars originally equipped with solid (non-vented) rotors
may utilize vented rotors.
2. Cross-drilled and/or slotted brake rotors may be used. Slots/
holes are permitted only in the braking area of the rotor.
Rotors featuring a drum-type parking brake in the hat area of
88
the rotor may not be drilled or slotted in the parking brake
area.
E. Drum brakes may be replaced with disc brakes. Disc brake rotors
for such a conversion must be equal to or greater in diameter
than the inside diameter of the standard brake drum. Changes to
backing plates/mounting brackets/brake lines to accommodate
this change are permitted but may serve no other purpose.
Drum-to-disc brake conversions must be bolted, not welded to
the axle/control arm/upright.
F. Air ducts may be fitted to the brakes, provided that no changes
are made in the body/structure for their use. They may serve no
other purpose. Backing plates and dirt shields may be modified
or removed.
G. A functional, redundant emergency (parking) brake must be
present.
H. Brake calipers may be replaced, provided the number of pistons
is equal to or greater than the original number of pistons. Caliper
mounting brackets may be replaced to accommodate this
change, but may serve no other purpose. Alternate caliper
brackets must bolt to the original caliper bracket mounting
location(s).
Patrick L is offline   Reply With Quote
Old 01-24-2009, 06:22 AM   #6
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
approved in July fastrack....^^^^
Old 01-24-2009, 09:03 AM   #7
Mechie3
Member#: 120152
About the motor mounts in SP. It no longer specifies that the amount of metal in a replacement engine mount must not be changed. Are cusco mounts legal now?
Mechie3 is offline   Reply With Quote
Old 01-24-2009, 09:28 AM   #8
KC
Member#: 442
16 SS
00 S2000
Sure does seem that way.
Originally Posted by 2009 Rules
J. Engine mounts may be replaced, but must attach in the factory location(s) without additional modification or changes. Engine position may not be changed. Hydraulic shock type rear engine locators, or bobble struts, may be replaced by manufacturer’s performance part or aftermarket replacement part. This part must retain factory dimensions and attachment points, including factory design. (Example: If factory locator/bobble strut is gas or hydraulic piston type, replacement part must be gas or hydraulic piston type.)
Originally Posted by 2008 Rules
J. Engine mounts may be replaced, but must attach in the factory location(s) without additional modification or changes. Engine position may not be changed. The amount of metal in a replacement mount may not be increased relative to the amount of metal found in a standard mount for the particular application. Solid metal mounts are specifically prohibited. Any non-metallic inserts may be used.
Hydraulic shock type rear engine locators, or bobble struts may be replaced by manufacturer’s performance part, or aftermarket replacement part. This part must retain factory dimensions and attachment points, including factory design. (Example: If factory locator/bobble strut is gas or hydraulic piston type, replacement part must be gas or hydraulic piston type. No solid mounts may be substituted.)
--kC
Old 01-24-2009, 01:26 PM   #9
alltracin
Member#: 100265
1999 powered '90
Miata
Miatas/CRXs can run in STX now, too! Lol
alltracin is offline   Reply With Quote
Old 01-24-2009, 04:16 PM   #10
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
I'm actually really glad about this! Prior to this change for the 94-97 NA with the Torsen rear diff you could only go from CS to CSP with no stop over in the ST classes. Now at least I don't have to prep the wifes car as much for her to compete
subydude is offline   Reply With Quote
Old 01-24-2009, 06:17 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
Yup, as long as they don't change the physical position of the motor or trans.
Jay
Pat, you must've been asleep at a trackday when the brake rule changed!
Old 01-24-2009, 06:23 PM   #12
Chiketkd
Member#: 71634
In hibernation...
That has to be an oversight - you have to have 4 seats to run in STX and STU.
Old 01-24-2009, 09:32 PM   #13
KC
Member#: 442
16 SS
00 S2000
Example Classifications:
All STS
--kC
Old 01-25-2009, 01:35 AM   #14
mofugga
Member#: 19540
2000 old skool RS
BRP
All STS
--kC
morons
Old 01-25-2009, 02:19 PM   #15
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
Is it true that sp no longer has the 20lb seat minimum? I see that st still has the 25lb min., but can't find the sp one? Just wanted to make sure I wasn't blind or anything before I make new seat brackets.
pignoseSTI is offline   Reply With Quote
Old 01-25-2009, 04:50 PM   #16
neilschelly
Member#: 94902
1988 911 Carrera 3.2
That is true. They basically made the "safety" part of the seat rule a separate thing in the new rules that generally applies to all classes (3.3.3.B.2) and just put actual rules in the SP part of things to eliminate the problem they were trying to prevent in the first place, namely the kart seats that were clearly unsuitable for an adult.
It doesn't do a particularly good job of addressing the safety issue of mounting seats, but neither did the weight minimum, so at least this way, it doesn't detract from the class and applies safety in a more global way. Safety doesn't really belong in class rules anyway, since it applies to all classes. And the plans to make a tech standard "licensing" procedure will hopefully net a more helpful and consistent safety check on installation anyway.
-N
neilschelly is offline   Reply With Quote
2009 SCCA Solo/ ProSolo Contingency Sponsors? S1MPSONS Motorsports 52 01-27-2009 08:24 PM
WTB: old SCCA Solo Rule books STFU STi Private 'Wanted' Classifieds 1 07-22-2007 05:36 PM
cf hood and scca solo rules sachilles Motorsports 7 03-23-2007 04:55 PM
WTB: Old SCCA Solo Rule-books. STFU STi Private 'Wanted' Classifieds 0 01-01-2007 07:43 PM
2005 SCCA Solo Rule Book kiefer Motorsports 2 12-22-2004 05:03 PM
