Old 01-24-2009, 12:05 AM   #1
afviper
Member#: 89493
2001 330ci
Default 2007 Wrx Vf39
2007 WRX wagon, VF39 turbo, CSS TMIC, Invidia catted DP, STI catback.
Just got back from a tune at Kito Auto Sport on the Mustang dyno with some surprising numbers. It made 265 hp at 5600rpm and 293 trq at 3700rpm. The only thing that worries me is the way the torque peaks early on, and the boost seems way too high at 21.8 psi. Does boost seem right to you, or should that peak not be there?
afviper is offline   Reply With Quote
Old 01-24-2009, 01:12 AM   #2
PikkaGTR
Member#: 179940
2007 Sti
22lbs seems like a lot
when I was stg2 07sti it only peaked to about 18-19
PikkaGTR is offline   Reply With Quote
Old 01-24-2009, 01:22 AM   #3
afviper
Member#: 89493
2001 330ci
I bought the car with the VF39 turbo already installed so I am not sure if the previous owner replaced the wrx restrictor pill. I'll try taking a look at the pill tomorrow and see if it is the small wrx one or if it was already drilled/replaced with the sti one. I'll have to talk to the tuner on Monday and figure this out, hopefully I won't be charged for a full tune if it needs to go back on the dyno.
Old 01-24-2009, 11:13 AM   #4
Bullwinkle1983
Member#: 172332
2006 WRX
21-22 PSI is fine in the midrange with the VF39, as long as it doesn't overboost on the highway. I'd be more concerned about the "boost bump" at peak torque there. Looks like your tune is overshooting boost targets and overcompensating.
Bullwinkle1983 is offline   Reply With Quote
Old 01-24-2009, 11:16 AM   #5
HSBabyFace
Member#: 130204
14 JKUR
I'm guessing this is 91 octane.... and what kind of EM are you using
HSBabyFace is offline   Reply With Quote
Old 01-24-2009, 11:42 AM   #6
afviper
Member#: 89493
2001 330ci
Actually 92 octane, and it was protuned.
Old 01-24-2009, 11:52 AM   #7
sidewayz
Member#: 5810
2001 S366 2.5RS
a little lean???
sidewayz is offline   Reply With Quote
Old 01-24-2009, 01:05 PM   #8
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Im gonna go out on a limb here and say thats a pretty poor tune.
cucamelsmd15 is offline   Reply With Quote
Old 01-24-2009, 03:39 PM   #9
boston_errol
Member#: 179007
2005 Legacy GT Wagon
ABP
Isn't the 2.5" STI catback a bit too small for your goals?
boston_errol is offline   Reply With Quote
Old 01-24-2009, 04:24 PM   #10
afviper
Member#: 89493
2001 330ci
I just wanted something quieter than the SPT catback that was on there when I bought it. I also don't really have goals for big power, my goal is to get it to run safely, 22 psi doesn't sound like a safe boost number to me. I doubt that the difference of .5" in the catback makes much difference in power. From what I read the biggest restriction in the stock exhaust is in the cats in the downpipe.
Old 01-24-2009, 05:37 PM   #11
1sicWRX
Member#: 104631
96 Cobra, TBird SC
88 Mustang 5.0
I would say your on the right track.
1sicWRX is offline   Reply With Quote
Old 01-27-2009, 02:23 PM   #12
afviper
Member#: 89493
2001 330ci
I got a reply from Kito Auto Sport, and it sounds like they will take care of the problem for free! They will put in the STI restrictor pill and get the boost down to the levels I am looking for.
I also have a question on where the AFR should be. I am not sure what is considered to lean or too rich. It seems like AFR dips down too much when boost hits is 10.3 way too rich? Also, should AFR be a bit more rich as the revs rise? Would AFR above 12 cause really high exhaust temps?
If this is getting a bit off topic I can go to the tunning forum, just let me know.
Old 02-02-2009, 05:31 PM   #13
littlewhitewagon
Member#: 103068
11 STI sedan
Yes, lean will cause high exhaust and cylinder temps.
You should try to stabilize the boost gain and keep the AFR from leaning out.
littlewhitewagon is offline   Reply With Quote
Old 02-03-2009, 10:03 AM   #14
captain spaulding
Member#: 104639
'06 WRX Wagon
Red
I'd highly recommend picking up a GM BCS and have that tuned the next time you goto the dyno, that would likely get rid of your boost issues and give you better response from the turbo, it did wonders on my TD04.. you don't need it, and others will probably tell me I'm an idiot and dunno what I'm talking about(isn't that the NASIOC way?), but this is just from personal experience..
captain spaulding is offline   Reply With Quote
Old 02-03-2009, 10:39 AM   #15
Gray Ghost
Member#: 162790
+1 or the ingersoll-rand is even a little better. Nice smooth boost control with no overboost issues. Just need to put it on before your tune so they can work with it. I think Kito used to carry them.
Gray Ghost is offline   Reply With Quote
Old 02-03-2009, 11:15 AM   #16
captain spaulding
Member#: 104639
'06 WRX Wagon
Red
yeah, I actually got the flying performance one, which is the same as the Ingersoll-Rand BCS..
Old 02-03-2009, 11:22 AM   #17
Bullwinkle1983
Member#: 172332
2006 WRX
As long as it's the 3-port design, they're all basically exactly the same (Perrin, GMBCS, etc).
Old 02-03-2009, 01:39 PM   #18
Pink sOck12
Member#: 175988
07 STi
CGM
nice!
Pink sOck12 is offline   Reply With Quote
Old 02-03-2009, 03:23 PM   #19
cmurda
Member#: 141609
nice numbers, curves could be a lot smoother
cmurda is offline   Reply With Quote
Old 02-06-2009, 06:34 PM   #20
afviper
Member#: 89493
2001 330ci
Got the car retuned with the STI restrictor pill installed. Very happy with the results, I asked for a more conservative tune that would work with California 91 gas without knocking. Got just that, boost is now smooth with no peak, the AFR is taken at the tailpipe so it is not accurate on the graph, AFR is where it should be when measured at the front o2 sensor. Spool is earlier than it was, and there is a lot more torque down below 3000rpm. I have nothing but good things to say about Kito Auto Sport, they didn't charge me anything for the second tune, or for the STI restrictor pill that they supplied and installed.
Old 02-06-2009, 07:01 PM   #21
Silver Bullet 2.0
Member#: 89508
2001 RSTi w/PPG
tightness. hella un-flush
those are pretty good numbers for that dyno with a vf39, I got my car tuned there too, and it reads lowww.
Silver Bullet 2.0 is offline   Reply With Quote
Old 02-06-2009, 07:03 PM   #22
afviper
Member#: 89493
2001 330ci
It does read low, they told me a stock STI makes about 230hp on the dyno.
WTB: wrx/sti Radiator ASAP !! 02NWbugeye NWIC Private Classifieds 8 07-08-2010 07:42 PM
2004 WRX sedan, speaker upgrade question wolfcri Car Audio, Video & Security 6 06-05-2010 11:34 AM
04 WRX Interior for 02/03 Interior or WRX TR Interior cartwheels4amile SCIC Private Classifieds 5 06-04-2010 11:53 AM
