Old 01-25-2009, 12:20 AM   #1
simonbsays
Member#: 158241
2006 CGM WRX Wagon
XPT Stage II
Default Wagon Trunk Light Mod with LEDs.
Does anyone else think the trunk light in the wagon is way too dim? And placed in a bad spot, therefore easily blocked by bags/gear/etc? Every time I fill up the trunk with gear I get annoyed because I can’t see anything at night, so check out my solution!
Overview:
2 LEDs were added to the top panel across the edge of the headliner, and a 3rd LED on the hatch door. Together, this illuminates a very useful area of the trunk.
Parts used:
- Three 5mm Warm White LEDs from SuperbrightLEDs.com (click to see spec sheet)
- One 330 Ohm resistor
- One 220 Ohm resistor
- One pack of 5mm LED holders (Radioshack, but also available at superbrightleds.com)
- 12-14ft of 18-gauge wire, in black and red (I’d suggest something thinner, like 20 or 22)
- Heatshrink tubing
- Electrical Tape
- 4 Wiretaps
- 2 Twist wire connectors
Tools used:
- Philips screw driver
- Drill with ” bit
- 10-gauge wire (for fishing wires through hatch… hangers are too stiff)
- Soldering arms
- 14mm socket wrench
- Digital Multi-meter
Results:
BEFORE: AFTER:
Process:
  1. Remove top panel: simply use your hand to pull it straight down (it's held on by 4 clips). Be sure to mark where you want to put the LEDs for drilling later.
  2. Remove passenger-side D-pillar: 14mm socket for 1 & 2, philips for 3 & 4.
  3. Use hands to pull panel straight out (towards driver side D-pillar). Use a philips screw driver to remove the trunk light too.
  4. Tape 18-gauge wires to a short length of 10-gauge, and push it through the hose between the hatch and cabin. I popped the hose out first, pushed the wires through it, then proceeded to fish the wire down the hole into the cabin. In my case, I used these wires as the main power wires to tap the LEDs into later.
  5. Once wires are pushed through, tap them into the existing trunk light's wires. On my car, there were 3 wires:
    - Black: +12v
    - Red: Ground <--tap to black wire
    - Green: +12v switched <--tap to red wire
    Yea, wtf Subaru... totally off from standard color conventions!
    In order to have the existing trunk light switch control the new lights, I tapped my positive (red) wire to green. The blue things are the wiretaps.
  6. Main power lines are complete, so let's create the LED circuit. I'll start with the top panel LEDs. I decided to use a series circuit for this...
    +----[>led_1]----[>led_2]---/\/resistor\/\----
    This website was helpful to determine what resistor to use:
    http://led.linear1.org/led.wiz
    I soldered an inline resistor (220 Ohms) to led_2 (soldering arms ftw!).
  7. When finished with the LED circuit, drill 1/4" holes in the top panel for the LEDs. Install the LEDs into the holes along with the LED holders.
  8. Tape the LED circuit against the back of the top panel. Leave a few inches of wire coming out of the passenger side so you can tap it into the power wires later.
continues below.......
simonbsays is offline   Reply With Quote
Old 01-25-2009, 12:26 AM   #2
Handsdown
Member#: 29355
that's ballistic grade boss. very cool.
Handsdown is offline   Reply With Quote
Old 01-25-2009, 12:32 AM   #3
subaru3169
Member#: 55252
* pullup bar *
looks awesome.. good job
subaru3169 is offline   Reply With Quote
Old 01-25-2009, 12:43 AM   #4
simonbsays
Member#: 158241
2006 CGM WRX Wagon
XPT Stage II
...continued from above:
The top panel's just about ready to go... Let's finish the top panel and then move on to the hatch:
  1. Test the circuit to make sure it works, then reinstall top panel and connect the circuit to the main power wires. Again, i used wire taps for this.
  2. Remove hatch panel by popping out all the rivets along the edge, then pull straight out (it's held on by 5 plastic rivets along the window, and 3-4 along the bottom edge)
  3. I tried for about 10 minutes to fish the 18-gauge wires along the side of the hatch door, but found it too hard. Alternatively, I fished the wires towards the middle, through the high-mount brake light assembly, and then stuffed the wires behind the window molding strip (pulls out). This may get a little tricky, so be patient... I found that popping out the black plastic cover (directly below brake light) helped with getting the wires out first.
    Red line indicates how i routed the wires:
  4. Create another LED circuit, this time with one LED. I also soldered an inline resistor for this one.
    +----[>led]---/\/resistor_330ohm\/\----
    My main power wires (red line) stopped a little short, so my LED circuit (blue line) extends towards it. I connected the two with twist connectors.
  5. Pop out that square plastic cover in the middle of the hatch panel, and drill a 1/4" hole through it:
  6. Once this LED is tested and working, reinstall the hatch cover and using another LED holder, snap the LED and plastic cover in place:
  7. Test to make sure new lights work, then reinstall all the remaining panels, trunk light, and seatbelts (torques to 30ft-lbs, fyi).
All done!
The warm white LEDs I used have a greenish tint to them, but in real life it's not bad at all. It's looks worse in the pictures. I still wish they were closer to the incandescent yellow though. One day, I may change all my interior lights to white LEDs and swap my LEDs for white ones.
If I were to do this again, I might use 2 more LEDs on the top panel, because the driver side rear-most corner's still not illuminated well.
I love the hatch-mounted LED because it lights up the ground/bumper area too when open (very useful!)
-Simon
Old 01-25-2009, 12:51 AM   #5
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
nice! i need to do this!
Bishop is offline   Reply With Quote
Old 01-25-2009, 10:29 AM   #6
DC16A2
Member#: 174357
2002 OBS
Hmmm... Lights from the top... I like =)
DC16A2 is offline   Reply With Quote
Old 01-25-2009, 12:42 PM   #7
mikeyc
Member#: 32338
03 WRX Wagon
In for the pics of where you installed these!
mikeyc is offline   Reply With Quote
Old 01-25-2009, 12:47 PM   #8
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Yep, i did this also. I used two LED's on each D pillar, about level with the cargo cover. I'm switching to four wide angle LED's though, as i just used crappy rat-shack LED's first time around.
sniper1rfa is offline   Reply With Quote
Old 01-25-2009, 04:21 PM   #9
GC9
Member#: 66895
Thumbs up
that looks fantastic~
is it hard to install?
i would like to install it on my car also =)
GC9 is offline   Reply With Quote
Old 01-25-2009, 05:52 PM   #10
ndmx52
Member#: 200802
2006 LGT - sTg 1
BSM
what a difference! Nice job!
ndmx52 is offline   Reply With Quote
Old 01-25-2009, 08:15 PM   #11
simonbsays
Member#: 158241
2006 CGM WRX Wagon
XPT Stage II
Write-up complete
Old 01-25-2009, 08:59 PM   #12
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Sweet - i might have to steal your idea of that hatch mounted light. Would be good for reading labels and such.
My lights in the D pillar get all the corners well - that panel is aimed a bit down and crossways, so there aren't any dark spots.
Old 01-26-2009, 02:32 AM   #13
hella_sti
Member#: 139289
2003 WRX Wagon
all I did was take me two petzel headlamps that were already in my car and wrapped them around the rear headrests pointed towards the hatch. They are adjustable for the angle and put out a ton of light!
hella_sti is offline   Reply With Quote
Old 01-26-2009, 03:45 AM   #14
simonbsays
Member#: 158241
2006 CGM WRX Wagon
XPT Stage II
Good for you... i think i like my way better though
Old 01-28-2009, 05:31 PM   #15
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
some pics of the one i did when i bought the car...
Apologies for the cell-phone quality.
Both sides have identical setups. For whatever reason, one of the LED's on the left side is slightly yellow-ish. :P
Old 01-28-2009, 06:17 PM   #16
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
yep, gonna have to do this in the spring.
i will probably do it under the hood as well.
jdubya301 is offline   Reply With Quote
Old 01-28-2009, 11:44 PM   #17
simonbsays
Member#: 158241
2006 CGM WRX Wagon
XPT Stage II
nice! how about a night shot?
Old 01-29-2009, 07:42 AM   #18
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
tried, phone camera sucks and doesn't really show anything. it's plenty bright and very even.
Old 01-29-2009, 11:07 AM   #19
jasonsp6
Member#: 81927
Great idea with the LED hatch lights simonbsays & sniper1rfa. I plan to do something similar in the spring.
jasonsp6 is offline   Reply With Quote
Old 01-29-2009, 04:31 PM   #20
MethosWagon
Member#: 163907
2002 Wrx Wagon
thats awesome... definitely have to add that to my DIY list of things to do...
MethosWagon is offline   Reply With Quote
Old 01-30-2009, 02:35 AM   #21
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
Nice, I like it.
trueno16v is offline   Reply With Quote
Old 01-31-2009, 10:39 PM   #22
subaru3169
Member#: 55252
* pullup bar *
whoa.. that's pretty nice
Old 02-01-2009, 12:44 PM   #23
k stang
Member#: 199255
2002 wrx wagon blue
1 fast wagon
Looks good man, i was just going to replace the stock light in the hatch with an LED one but you sparked a new idea...
k stang is offline   Reply With Quote
Old 02-03-2009, 06:48 PM   #24
jace2k5
Member#: 107964
2004 WRX Wagon
Platinum Silver Metallic
what is that thin bar going across the lower part?
is that a light? that may be a good idea also.. a CCFL or something..
similar to this:
Rear License Plate Mod
jace2k5 is offline   Reply With Quote
Old 02-03-2009, 07:13 PM   #25
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Uhm, i dunno. A handle or something, no idea what it's for. Maybe for tying stuff down - i've never used it.
It's only screwed into the trim panel, so it's not very strong.
Trunk Light Mod sanremors Interior & Exterior Modification 8 05-15-2005 11:20 PM
2004 WRX Wagon Trunk Light 96 Flat Four Electrical & Lighting 0 05-23-2004 03:05 PM
trunk light mod Webster Electrical & Lighting 2 04-09-2003 01:03 PM
lights (head and fog) & trunk light mod ychan Newbies & FAQs 3 01-26-2002 08:55 PM
Trunk Light Mod BugBomb Mid Atlantic Impreza Club -- MAIC 3 10-05-2000 07:31 AM
