Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 01-25-2009, 12:06 PM   #1
Odyknuck
Member#: 192866
2006 Impreza
Default Turbo Oil Drain line
I know that most guys drain the Turbo oil into the Valve cover however I would prefer not to do that for various reasons. Anyways I am going dry sump and that would leave the stock oil pump not being used. Having said that I woul like to use is as a path into the oil pan. There are two threaded plugs on the bottom and the right one was the pick up tube side. I want to remove that plug and tap for a 1/2" X 10AN male adapter for my return. I will be pluging the pressure side so there will be no cross flow. So here is my question, typically the turbo drain is primarly by gravity, however by using the plugged port the oil would have to upflow about 2 1/2" to dump into the pan. Is this going to be a probem for me or will engine vaccume created by the dry Sump oil system compensate for it and not allow the oil to back up into the drain line.
Odyknuck is offline   Reply With Quote
Old 01-25-2009, 10:15 PM   #2
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Well...
There's one way to find out for sure
My guess is that the system won't suck the oil away fast enough and you'll end up with it seeping past the seal and heading into the intake.
Is it reasonable to have a smaller holding tank for return oil with another pump or line that heads up to the dry sump holding tank?
I've not dealt with dry sump systems enough to intimately know how all of the different ways they can be configured.
PhilSine is offline   Reply With Quote
Old 01-26-2009, 03:25 PM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
dry sump eh ? gonna be a monster ! good luck with having a 12quart oil change...and 1/2 hour warm up time !
IllNastyImpreza is offline   Reply With Quote
WTB: y-pipe for 2006 WRX and turbo oil drain line gasket! jexeffectz Private 'Wanted' Classifieds 1 08-11-2009 10:39 AM
Oil Drain Line Banjo Bolt Size nitsuj Built Motor Discussion 8 02-02-2007 07:26 PM
Turbo oil drain line Thran Newbies & FAQs 5 08-04-2006 10:26 PM
swapping out my td04 for a used vf turbo. Do I need a new oil drain line gasket? garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-30-2005 11:44 AM
questoin about the ISR oil drain line smacksube Normally Aspirated with bolt-on Forced Induction Powertrain 3 12-10-2002 03:25 AM
