Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 01-25-2009, 06:52 PM   #1
DSM_Outback
Member#: 56345
93 Swapped L
Green
Default Block Heater on an EJ20G
It's winter in Colorado and my alcoholic EJ20G hates firing when the temp is below 45*. I'm guessing one of the best ways to deal with this would be an OEM block heater.
Anybody installed one on an EJ20G?
If so give me the lowdown please.
Thanks.
DSM_Outback is offline   Reply With Quote
Old 01-25-2009, 07:21 PM   #2
DSM_Outback
Member#: 56345
93 Swapped L
Green
Default Googlethat**** FTW
I'm guessing like so...
http://www.subaruparts.com/catalog/s...lockheater.pdf
http://www.scoobymods.com/forums/showthread.php?p=37831
I'll chime back in after I get it and do it. We'll see how it helps cold start on E85.
Last edited by DSM_Outback; 01-25-2009 at 07:27 PM. Reason: I googled the crap out of it
Old 01-26-2009, 12:38 PM   #3
kleinkid
Member#: 27091
2010 STi SE
I put one on my '91 Legacy SS because my Autronic EM is controling boost and not the IAC, it will control one or the other but not both at once. Anyway, I think the block heater works great. Really just takes a few hours, or less depending how cold it is, to get up to a nice temp. to start easily, and the cabin is warmer sooner. That same part number fits all Subaru blocks, and they are not that expensive. The plug you remove from the block to install the heater element, can be real hard to remove, and you don't want to round out the hex hole. I used the correct size socket, with a 1/2" dr. breaker bar, and a cheater pipe on that. My plug had been in for 17 years though.
kleinkid is offline   Reply With Quote
using an 04 STi alternator on an EJ20G? mpaone Pre-2002 Factory Turbo Powertrain 8 12-11-2008 08:56 AM
What turbo was on an ej20g? OCD-Speed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-14-2006 04:27 AM
top feed injectors on an ej20g silvialost Subaru Conversions 1 11-09-2005 09:44 AM
OK to leave a block heater on all night? soldmyboxster Alaskan Impreza Club Forum -- AKIC 5 12-24-2004 07:15 AM
help with the starter on an ej20g swap smacksube Subaru Conversions 5 12-13-2003 10:20 AM
