Old 01-26-2009, 01:29 AM   #1
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
Default atmospheric pressure n/a ecu
It has recently come to my attention that the stock n/a ecu will not read manifold pressure above atmospheric?
How are you guys getting around this?
watchunglava is offline   Reply With Quote
Old 01-26-2009, 09:07 AM   #2
Odyknuck
Member#: 192866
2006 Impreza
I will be using the Greddy Emanage Ultimate on my Turbo RST with the Greddy Map sensor. Then the OEM MAP will be clamped at a specific voltage and the Greddy MAP will take over above "O".
Odyknuck is offline   Reply With Quote
Old 01-26-2009, 11:50 AM   #3
watchunglava
Member#: 168862
ohh man $650 just so i can have the ecu read manifold psi?
isn't there a way to reprogram the stock ecu to be able to scale that sensor?
Old 01-26-2009, 12:33 PM   #4
Odyknuck
Member#: 192866
2006 Impreza
I will assume you are going to Turbo your RS. There are people who run Turbos without Piggybacks up to 5 PSI of boost. They do tend to use a safeguard device however. Thye are cheap insurance. Also the Greedy does a whole lot more that just read system pressure. Its capable of programming your Ignition and fuel. You can also find them a lot cheaper that 650. I got mine brand new with the wiring harness and a map sensor for 450 off of ebay.
Old 01-26-2009, 12:36 PM   #5
watchunglava
Member#: 168862
i want to supercharge it. i allready tune fuel and timing with romraider for free. even $450 is alot of money just to be able to scale manifold pressure.
Old 01-26-2009, 03:24 PM   #6
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
gotta love the opensorce ecu stuff ! having an old school 98 does have its negatives... but hey I got my EMU with harness for $250
what would it take to swap a WRX ecu into your car ?
IllNastyImpreza is offline   Reply With Quote
Atmospheric Pressure Sensor ElizRN Transmission (AT/MT) & Driveline 12 03-07-2016 07:47 PM
Where is atmospheric pressure sensor located? IndyRacer Engine Management & Tuning 7 02-24-2006 12:38 PM
Sealed box and atmospheric pressure il96 Car Audio, Video & Security 7 09-18-2003 04:16 PM
Atmospheric pressure at altitude and boost compensation? john banks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-04-2002 01:30 PM
MAP & Atmospheric Pressure Sensor Skidd Normally Aspirated with bolt-on Forced Induction Powertrain 4 02-01-2002 12:45 PM
