Old 01-26-2009, 12:34 PM   #1
grocerygetter303
Member#: 200203
06 WRX
silver, flat black soon!
Default dose awd drivetrain pull right on hard launch
It's snowing in Denver good times right? So why dose my car want side swipe the car to my right when I drop the clutch just a bit hard! I know this is common for front and rear wheel drivetrain's but i thought awd fixed the whole even power to the pavement thing like pozitrax rear for drag racing. Or dose the torque of the engine just naturally put more torque to right side of drivetrain. Or is my car still out of wack from previous accident!!!
grocerygetter303 is offline   Reply With Quote
Old 01-26-2009, 12:38 PM   #2
smurfwrx
Member#: 151928
09 Triumph S3
I've never noticed my car pulling either direction on launch.
smurfwrx is offline   Reply With Quote
Old 01-26-2009, 12:43 PM   #3
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
i have nevered notice that either^^^^
jeremywrx15554 is offline   Reply With Quote
Old 01-26-2009, 12:48 PM   #4
98imprezaWagon
Member#: 142548
02 BattleWagon
since your driving in snow, the road could be on a tilt to the right. that would make you slide.
98imprezaWagon is offline   Reply With Quote
Old 01-26-2009, 12:53 PM   #5
08EJ25
Member#: 174022
2008 WRX
Lightning Red
Like said your roads may just be uneven with the snow. Never had any issues with my car pulling one way or the other. Oh, and it's "does" not dose.
08EJ25 is offline   Reply With Quote
Old 01-26-2009, 01:03 PM   #6
van_dutch
Member#: 198633
2004 WRX
The whole point of the symmetric design is to eliminate torque steer. Pulling to the right is probably more related to roads as others have pointed out.
van_dutch is offline   Reply With Quote
Old 01-26-2009, 01:11 PM   #7
jbwrx
Member#: 86274
. Andrewtech
Gold Club Member
You're launching it to hard and breaking the tires loose. It has nothing to do with torque steer. You car has an open front diff causing one of the front wheels to spin at the same time the rear wheels are spinning. This will make the car rotate a bit. Try practicing your technique a bit. You can't just rev it up and dump the clutch.
jbwrx is offline   Reply With Quote
Old 01-26-2009, 01:51 PM   #8
ravenlunatic
Member#: 180601
2003 PSM WRX
(>")>==HADOKEN==<(o)
DOES it feel like the rear end of the car is pulling to one side or DOES it feel like the whole car is pulling to one side. i noticed that my car's rear kicks out if i goose it a litle on a slick road, but i think this is because of the uneven balance of the center diff.
ravenlunatic is offline   Reply With Quote
Old 01-26-2009, 02:06 PM   #9
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Id say it could be a few things such as the crown of the road, your cars alignment is messed up, the chassis is bent from a accident, less tire pressure in the passenger side tires, to name a few.
rexworx is offline   Reply With Quote
Old 01-26-2009, 03:15 PM   #10
Reebis
Member#: 126157
'01 2.5RS Coupe
BRP
There's nothing odd about cat-walking on a slippery road. My DSM used to do it and my RS also does it. If it happens it usually means you have to back off the right foot a little.
Reebis is offline   Reply With Quote
Old 01-26-2009, 04:11 PM   #11
rkramer
Member#: 118209
2015 WRX Limitec
crowned roads... of course it is going to pull one direction
Old 01-26-2009, 04:14 PM   #12
Back Road Runner
Member#: 60082
2004 Forester STI
+1 to all.
Old 01-26-2009, 07:31 PM   #13
Oni04project
Member#: 193543
2004 WRX (PSM)
2006 Evo9MR (sold)
i sense wrx in a snow bank!
kidding
+1 to all =)
Oni04project is offline   Reply With Quote
Old 01-26-2009, 08:44 PM   #14
CynicX
Member#: 48199
06 WRX
WRX has LSD rear diff and open front diff. If you launch in the snow you will have 1 wheel with more traction then the rest (spinning = 0 traction). The car will want to rotate into that stationary wheel...
Its very common. Most havent noticed it because...well who tries to launch in the snow and expects to go straight as an arrow with wheels spinning?
It happens with RWD a lot too. The back end will "side step" because the rear wheels are pushing against the front wheels that have more traction. So they spin, you loose all traction, so the go to the side (no traction means they are just as likely to go right or left as forward or backward). Same thing happens in your car except not as bad because one of the wheels are spinning up front....
If the car doesnt pull to the right under any other type of driving other then launching in the snow its just the way the car reacts.......
When I've launched in the snow or on ice (in a parking lot) I can immediately induce a donut. Its good times but I feel like I'm doing more harm to the car then its worth....
CynicX is offline   Reply With Quote
Car pulls right on accel, left on decel wcbjr Brakes, Steering & Suspension 17 05-14-2010 04:24 PM
Car pull to the right when hard braking.. ychanus Brakes, Steering & Suspension 6 03-08-2010 04:53 PM
fixing the CLUNK heard on hard launches? hirevn Alaskan Impreza Club Forum -- AKIC 8 10-07-2004 08:59 PM
Wheel Hop on Hard Launch TurboRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-13-2001 10:59 AM
how acurate would a 4eat rs be with the awd fuse pulled be on a 2 wheel dyno? GregBolby General Forum Archive 4 02-14-2001 07:57 PM
