Old 01-26-2009, 05:10 PM   #1
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
Default Car is about a week a way from being started!
Some of you may have seen my thread in the "N/A with Bolt-on Forced Induction" area of the forum. For thos who haven't a quick recap. I have a 2007 2.5i and it has been equiped with a 6 speed and a EJ257 with CP pistons. To top it off, I went with a rotated 35R. Now that the car is close to being done, I figured I would start a new thread to show the power it makes. Anyone want to make guesses at what it will dyno. I have included a few pictures and a complete mod list as well. LEt me knwo what you guys think.
Engine:
- EJ257 block- STI Rods, CP Pistons, ACL bearings
- Legacy GT spec b head and cams
- 2.5i Intake manifold custom welded to WRX top feed TGV’s
- Perrin Equal Length Header
Fuel:
- Walbro 255 Fuel Pump
- 1100cc DW injectors
- Perrin V2 Fuel rails
Turbo Setup:
- Perrin Rotated 35R kit with .63 housing
Intercooler:
- Core is a SS Auto Chrome kit
- Tial BOV
Suspension:
- 2004 Factory STI Inverted shocks
- Tein S-Tech Springs
- EVERY SINGLE BUSHING Kartboy/TIC makes for the car including the complete rear end, trans, and shifter kits
- Whiteline Sub Frame lock down bolts
- Ingalls Camber Bolts in rear
- FHI Carbon/Aluminum Front Strut tower bar
- MR Lower H bar
- Factory STI Rear Sway bar
Brakes:
- AEM Front big brake kit w/ WRX calipers
Drivetrain:
- 2004 STI 6 Speed Swap
- Group-N Engine and Transmission mounts
- Billet Aluminum Pitch Stop mount
- STI pressure plate w/ ACT modified street disc
Interior:
- 04 WRX Seats
- STI Instrument cluster
- Auto Climate control conversion
- STI shift knob
- Airbags disabled/removed
- STI dash harness swap w/ 04 ECU swap (had to be 04 because it does not have the immobilizer)
Exterior:
- STI sideskirts
- Blacked out headlights
- 6000k HID conversion
- Vent for hood (not installed)
- Vortex Generator (not installed)
- BIG ASS SLOWMOTION STICKER (Coming Soon!)
Now for some pictures
2.5iSTI is offline   Reply With Quote
Old 01-26-2009, 09:30 PM   #2
modaddict
Member#: 95840
sold to a good bud
awaiting next car
talk about some proven power......
modaddict is offline   Reply With Quote
Old 01-26-2009, 09:56 PM   #3
hybridpatient95
Scooby Scammer- Do Not Buy From User
Member#: 127606
which tb are you gonna use with this setup? assuming the 2.5i?
hybridpatient95 is offline   Reply With Quote
Old 01-26-2009, 10:47 PM   #4
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
STI, but doesn't really matter given it is the same as the 2.5i. I had both because I thought there was a different, then I put them next to each other and found out otherwise.
Old 01-27-2009, 06:24 AM   #5
Iflysti06
Member#: 156955
2006 STI
UR GT35R w/ mad bolt ons
Wow that thing is sweet, cant wait!
Iflysti06 is offline   Reply With Quote
Old 01-27-2009, 07:56 AM   #6
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
You talked me into taking my car to slowmotion.
What will the 2.5i manifold do power wise?
Larger plenum?
bigolrig is offline   Reply With Quote
Old 01-27-2009, 10:31 AM   #7
nhat
Member#: 140163
03 STi
hellaflunctional
why didn't you buy an sti to start with? although, i'm sure your insurance on the 2.5i is far less than that of an 07 sti
Old 01-27-2009, 11:16 AM   #8
cellgeek101
Member#: 143941
04 STI JBP
07 LIMITED #602/ 06 BUSA
If he's a young guy...maybe that's what he could offord and the 2.5i is a lot cheaper on insurance. Looks good. Can't wait to see the results. I assume this is going to be more of a DD by the .63 hotside?
cellgeek101 is offline   Reply With Quote
Old 01-27-2009, 01:07 PM   #9
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
That should be a really quick car! And FYI, the Spec B legacys had the same heads and cams as the Legacy GT. The whole engine was the same actually, the only drivetrain difference being the years they gave it the STi 6 speed.
96Lconversion is offline   Reply With Quote
Old 01-27-2009, 04:08 PM   #10
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
Larger plenum?
They are great guys up there and very on top of getting things done. Thinking it is going to make a midrange increase over the sti or wrx manifolds.
Well long story short is that is was to be my daily leaving it stock, but then I parted out a built turbo hatch I had and started this project. As of now, I am still under the cost of an STI with the cost of my 2.5i and mods. So I am ahead I think.
Definately going to be a daily.
Old 01-27-2009, 08:40 PM   #11
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
justin have you talked to Wyan today,we saw a few more issues to sort out if you want call me.
john 1badSTI is offline   Reply With Quote
Old 01-27-2009, 10:22 PM   #12
SW00P_G
Member#: 5591
EJ257 Gt35r
FWIW - the magic dyno guess from me.......
pump gas = 360whp, Corey's dyno never gives me the big numbers. But it is very consistent.
I'm a realist, but I've been wrong before! Can't wait to see that graph with the N/A manifold.
SW00P_G is offline   Reply With Quote
Old 01-27-2009, 11:22 PM   #13
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Very nice man!!!
4ST-AIR is offline   Reply With Quote
Old 01-28-2009, 01:03 PM   #14
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
Well it is basically your old setup so you should know lol.
Old 01-28-2009, 01:57 PM   #15
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
f***in sweet setup!
i envy u!
blakkboxer is offline   Reply With Quote
Old 01-28-2009, 02:34 PM   #16
SW00P_G
Member#: 5591
EJ257 Gt35r
I think I made 380whp, just wanted to think that mine was faster!!
Old 01-28-2009, 03:39 PM   #17
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
^^^ what happened to your car?
midnight2.5rs-t is offline   Reply With Quote
Old 01-28-2009, 04:02 PM   #18
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
He just got some new stuff! I will let him bring it to light if he wants though.
Old 01-29-2009, 08:47 AM   #19
SW00P_G
Member#: 5591
EJ257 Gt35r
Yeah, I'm going to update one of my old threads when things get finished. I just don't have all the info together yet since it's not done.
EDIT - I looked at my old graph, it was 390 @ 19psi
Old 02-02-2009, 03:47 PM   #20
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
Not really anything new to report today. I am waiting on my DCCD controller to come in to be able to get that installed. Then it can go on the dyno(pending no suprise wiring issues). Getting really excited though!
Old 02-02-2009, 03:56 PM   #21
Zspectrum
Member#: 152933
CT9A
TB
I think youll have an issue with the ssac core. That things so little.
Zspectrum is offline   Reply With Quote
How many threads about "when Nasioc was down" are going to be started O2-GGA Off-Topic 15 10-21-2010 10:30 PM
Avis Offers One-Way Deals from Florida Starting at $12.95 NYCshopper Non-Subaru News & Rumors 0 03-06-2007 02:06 PM
I think my car is about to **** the bed Twisted STi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 09-09-2006 05:17 PM
How many more threads are gonna be started about the Dragon? DerFahrer South East Region Forum 1 06-02-2004 02:24 PM
ok guys... our 1st event is in 3 weeks... you wanto the be there importbasement.com South East Region Forum 9 11-20-2002 04:14 AM
