Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 01-26-2009, 07:58 PM   #1
aspenwrx22
Member#: 156911
2005 wrx
Default oil change question:
Hey all,
I recently took my car to have the oil changed. I usually change it myself but being lazy and having just moved to florida I decided to pay to have it changed at the local dealer. Now here is my question: after reviewing the bill from the dealer, I noticed the bill listed the oil I was charged for as 5W20. Is this normal? Perhaps the tech used 5W30? I always use the recommended 5W30 when changing it myself. Possible price mess up?, even the oil cap provides for you that you use 5w30. The dealer is closed now so I was just looking for some thoughts on the matter. I'll call tomorrow,
Thanks
aspenwrx22 is offline   Reply With Quote
Old 01-26-2009, 08:37 PM   #2
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
For Florida? Doesn't make sense. Take it easy driving until you get an answer/change. Unless the temperature just hit -15 F.
5w30 in FL should be a minimum I would think, even in winter. For summer definitely beef it up past that.
surowrxa is offline   Reply With Quote
Old 01-26-2009, 08:46 PM   #3
krzyss
Member#: 8365
2013 Ford Focus SE
What kind of dealer?
5W20 is oil for some Honda, Ford and Chrysler engines. It could be quite good oil but WRX engine is not right application.
Krzys
krzyss is offline   Reply With Quote
Old 01-26-2009, 08:50 PM   #4
aspenwrx22
Member#: 156911
2005 wrx
It was a Subaru dealership. Also, they did have Jeep and Chrysler as well.
Old 01-26-2009, 09:14 PM   #5
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Did you notice that the 2 is next to the 3 on the keyboard? Either way dude, it's not a big deal....have some ice cream and watch an old movie and relax. People put WAY too much brain power into oil questions; it's a car, not the space shuttle.
Old 01-26-2009, 10:46 PM   #6
drylinedays
Member#: 146564
2001 RS
May not be the space shuttle but its still nice to know whats going into it
drylinedays is offline   Reply With Quote
Old 01-26-2009, 11:00 PM   #7
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
Originally Posted by Unabomber View Post
have some ice cream
+1
Not possible
RonJitsu is offline   Reply With Quote
Old 01-26-2009, 11:45 PM   #8
silver-duck
Member#: 130710
5-20 is too light=end of story!
silver-duck is offline   Reply With Quote
Old 01-27-2009, 04:27 AM   #9
plode
Member#: 116910
I run 10W-30 in mine, as per the recommendation of a mechanic for SPT/ESX, who has been working for Subaru for 28 years.
plode is offline   Reply With Quote
Old 01-27-2009, 06:42 PM   #10
madmax718
Member#: 172501
Space shuttle has the computing power of a HP calculator. Its also has a lot of parts replaced every flight. It was never a cost effective material launcher, And thats why we are moving away from the shuttle and back to traditional designs. Lower cost, easier maintainance.
20 weight is way light, unless your running some super tight tolerances. Some auto mfgs recommended 20 because it increases fuel economy, even if its not the best thing for the motor.
Look at what subaru recommends for the same motor in japan. Its somehow thicker than the oem spec oil here.
madmax718 is offline   Reply With Quote
Old 01-27-2009, 07:30 PM   #11
plode
Member#: 116910
WAT?
Old 01-27-2009, 07:48 PM   #12
bluesubie
Member#: 767
04 FXT
For anyone running conventional 5w-30 (and even some synthetic 5w-30's), it's very possible that it would have sheared to a 20 weight anyway.
-Dennis
Old 01-27-2009, 08:22 PM   #13
2.5GTLegacy
Member#: 111219
5w-40 Ftw
2.5GTLegacy is offline   Reply With Quote
Old 01-28-2009, 08:42 AM   #14
madmax718
Member#: 172501
-Dennis
And what do you think a 20 weight sheers to?
Yes, shuttle is still working but it slated to retire in 2010.
From some website:
NASA's Mercury capsules of the early 1960s had no computers at all. For re-entry, retro-rocket timing and attitude information was radioed to the spacecraft from a tapes-and-teletypes computer centre on the ground.
Well, the Shuttles were originally equipped with five parallel redundant IBM AP-101 general purpose computers. Each of those was equipped with a mighty 1,310,720 bits of ferrite core memory (more had to be tacked on to accommodate the elephantine 700 kilobyte size of the Shuttle's control software...), and was good for a neck-snapping 0.48 MIPS and 0.325 MFLOPS.
They did update it though, a whole 3 times faster! And a little more memory. Thats it, havent touched it since 1991.
So the updated one does about 1.5 MIPS. Using modern calculations
Core 2 Duo E6400 at 2.13GHz- 19,773Mips
Core 2 Duo E6400 at 2.88GHz- 25,963Mips
A radiation-hardened 80C85 (the CMOS version of the Intel 8085) did the thinking for the Sojourner rover on Mars. The Pathfinder lander and the later Spirit and Opportunity rovers, though, got a lot more grunt; they all use the popular RAD6000, which is a hardened version of the 25 MIPS IBM POWER chip that came before the PowerPC.
8085 was the precursor to the 8088 if anyone is curious. They used that thing in the original IBM-PC. Some of us are old enough to have had one.
Your HP calculator has48 series)
And up to 4mhz of processor speed.
Old 01-28-2009, 12:09 PM   #15
bluesubie
Member#: 767
04 FXT
Is this a trick question?
Depending on the base oil, the additive pack, and the amount of viscosity index improvers, it will likely stay in grade better than a 5W-30.
Disclaimer: I do not advocate running 20 grade in a Subaru spec'd for a 30 grade. I don't even know why people bother with 5W-30 in FL.
-Dennis
Old 01-28-2009, 12:35 PM   #16
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Heh. Maybe. And a lot of space shuttle info...
OP: What's the word? Did the car explode upon re-entry?
Old 01-28-2009, 01:35 PM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
space shuttles dont spin bearings 'cuz some idiot put the wrong oil in them
Old 01-28-2009, 09:16 PM   #18
aspenwrx22
Member#: 156911
2005 wrx
Update: Called the dealership Tuesday morning and the service department
said that they would check with the tech and give me a ring immediately, it is
now 8:00pm on wednesday and still no response, I changed the oil today on
my own just to play it safe. I'll count this as a live and learn, and i'll change
my own oil from now on. Thanks for the responses.
Old 01-29-2009, 04:43 PM   #19
aspenwrx22
Member#: 156911
2005 wrx
Another update, spoke to the service manager today and he assured me by
saying quote "We called Subaru and they assured us that the motor oil used is
fine for the WRX" . So they did use the 5w20 in it after all. Oh well,
like previously stated, just a lesson learned.
Old 01-30-2009, 12:02 PM   #20
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
Wow, I think I'd stay away from that dealer in the future.
AndyH is offline   Reply With Quote
Gear Oil Change??? wickkerr82 Newbies & FAQs 6 06-04-2010 02:35 PM
Simple Oil Change Question: Need confirmation mr_yellow Normally Aspirated Powertrain 3 01-13-2004 05:33 AM
Oil Change question: Something's not right here? trustWRX Southern California Impreza Club Forum -- SCIC 28 12-02-2003 12:46 AM
