Old 01-26-2009, 09:27 PM   #1
IAG Performance
Member#: 158123
Default IAG Performance Dyno Session #4 Tuning by RiftsWRX (Jorge). 8 total 509 WHP GT35R too
January 24th & 25th 2009
Dynojet 424x
Car #1 Daniel G 07 STI
Mod List:
IAG UEL Header and EWG Package with New Tial 38mm V Band
APS TMIC
Stock Turbo
Walbro Pump
DW 850cc
Cobb SF Intake
Cobb SF Airbox
GP Moto Silencer Delete
Cobb V2 AP
Cobb TBE
Car #2 David P 05 STI
Mod List:
Stock Turbo
Cobb SF Intake
Perrin Inlet
Perrin EBCS
TBE
Cobb V2 AP
Car #3 Heather S 03 WRX 4EAT
Mod List:
03 WRX
2.5L Hybrid Engine
VF30 Turbo
Walbro Pump
DW 565cc
Perrin EBCS
Borla Header
Perrin Uppipe
TBE
Perrin TMIC
K&N Intake
Cobb V2 AP
Please note: The 4EAT in this car was slipping and the decision was made to not continue with the tuning in an effort to allow the customer to upgrade on their terms!
Car #4 Adam R 05 STI
Mod List:
IAG UEL Header EWG Package with New Tial 38mm V Band
TD06 20G 7cm2
DW 850cc
Walbro Pump
TBE
Perrin Big MAF Intake
Perrin Inlet
CSS/SSAC FMIC
Snow Alcohol Kit
GM EBCS
Cobb V2 AP
Run # 6 is on Alcohol
Car #5 Mike D 05 STI
Mod List:
Element Tuning GT52 Turbo
APS DR525 FMIC
APS 70mm Intake
APS Inlet
DW 850cc
Walbro Pump
Invidia TBE
Run #12 is on VP MS109 Race Gas
Please Note: The Dyno 02 Sensor failed on this car and are unable to show any plotted AFR's on all cars from here on out. You will note that the AFR will show 18.0 on all dyno runs including and following this car. Don't worry, we were tuning all of the remaining cars using an AEM Wide band kit.
More to follow:
IAG Performance is offline   Reply With Quote
Old 01-26-2009, 09:38 PM   #2
IAG Performance
Member#: 158123
Car #6 Ryan D 06 WRX
Mod List:
UEL Header
TBE
Intake
CSS/SSAC FMIC
Car #7 Jeremy R 07 STI
Mod List:
IAG Custom Rotated Kit with UEL Header
GT35R Turbo with .82 Tial V Band Turbine Housing
Tial 44mm EWG
Turbo XS FMIC
Invidia CBE
Walbro Pump
DW 1100cc
AEM 3.5 Bar MAP Sensor
Cobb MAP Adapter
Cobb V2 AP
Run # 8 is on 93
Run #12 is on VP Q16 Race Gas
Car #8 08 STI
Mod List
GT Spec EL Header
Invidia DP
Perrin Stealth CBE
Cobb V2 AP
Run #9 is Sport Sharp Mode
Run #10 is Sport Mode
Run #11 is Intelligent Mode
>> IAG Performance Subaru Pro Tuning Services in Maryland <<
Old 01-26-2009, 09:59 PM   #3
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
Jorge sucks,...
Just kidding man really nicely done all around.
Did they give you a mean FIT to tool around in as a rental in MD>?
Whats everyones resonse like to the IAG UEL header with 38mm V band?
jmlaser is offline   Reply With Quote
Old 01-26-2009, 10:10 PM   #4
LeeC
Member#: 97843
9.87 Supra:14 Tundra
c6 z06:Blaze Yellow 02!
Good **** as usual, nice to Jeremy's car up and making power!
LeeC is offline   Reply With Quote
Old 01-26-2009, 10:43 PM   #5
ARBoost
Member#: 190876
2005 STI CGM
361hp/370tq Done by Jorge
Mine was car #4 and i had a blast down there. Jorge is a top notch guy and tuner .
ARBoost is offline   Reply With Quote
Old 01-26-2009, 10:59 PM   #6
rodder
Member#: 86128
2005 OBP STi 355 whp
RIP :(
wtf wheres my car lol
rodder is offline   Reply With Quote
Old 01-26-2009, 11:06 PM   #7
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
gREAT JOB Jorge !
alfriedesq is offline   Reply With Quote
Old 01-26-2009, 11:39 PM   #8
vinnyd
Member#: 148219
2013 Mazdaspeed 3
Liquid Silver
nice numbers all...jorge +IAG again ftw!!!!
vinnyd is offline   Reply With Quote
Old 01-27-2009, 12:54 AM   #9
wrxman420
Member#: 120007
2003 PPG, STG 3+
Am I in Reverse?
Great Job Jorge! I'll have to throw this vf48 on and come down for another tune.
wrxman420 is offline   Reply With Quote
Old 01-27-2009, 02:45 AM   #10
nhat
Member#: 140163
03 STi
hellaflunctional
what's the deal between the 1st two cars? same max whp but the car with less mods makes 20lb-ft more?
Old 01-27-2009, 04:52 AM   #11
Iflysti06
Member#: 156955
2006 STI
UR GT35R w/ mad bolt ons
Looks likes another set of nicely tuned subies!
Iflysti06 is offline   Reply With Quote
Old 01-27-2009, 07:48 AM   #12
EGY5
Member#: 165206
2006 WRB DPSti
w/ white shoes
That was the first thing I noticed too. Only difference is the TMIC and the EWG + UEL headers. STi TMIC made 20 more tq but made it 500 RPM later, any ideas?
Also, I know its just dyno #'s and its hard to compare, but whats up with Car 4 & 5? Is it just a conservative tune for #5? And I really haven't seen that many 20G plots, but do they really spool that slow?
That GT52 powerband looks money as hell tho
EGY5 is offline   Reply With Quote
Old 01-27-2009, 09:30 AM   #13
nhat
Member#: 140163
03 STi
hellaflunctional
i can't quite figure it out either. the 1st car does have a far stronger tq curve, but i figured with an aps tmic/ewg/headers, it'd make a lot more power than the car with the oem sti tmic/iwg/oem headers.
Old 01-27-2009, 10:30 AM   #14
IAG Performance
Member#: 158123
You will note that car #1 spools much faster and the power is farther to the left. The most compelling thing though is that the power band is also much more linear. Car #2 spikes to a higher torque number later and is not nearly as linear. This is all attributed to both the UEL header (moving power to the left), and the precise boost control (making the power delivery more linear and flat). Car #2 due to it's internal WG, can't control boost fast enough.
Not every car is
This compares Car #1 to Car #2
Hope that helps.
Regards,
JJ
Old 01-27-2009, 10:55 AM   #15
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
All cars are different. Car #1's power band looks better (starting 500rpm's sooner and more flat) I assume because of the headers.
Even though torque dosnt peak as high on car #1 compared to car #2 it's making more torque from 4k-5krpm.
I'm really diggin the GT35R and GT52 power graphs. Nice!
Edit: what he said^
Edit edit: What's boost peaking on the two stock turbo STI's and what does it taper to at redline?
Steve.804 is offline   Reply With Quote
Old 01-27-2009, 02:33 PM   #16
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Honestly.... for me, the most impressive car is #6... That's a stage 2 WRX.. making 260WHP.
On this type of dyno, the average is 220-240WHP for a similar set of mods.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 01-27-2009, 02:51 PM   #17
steverx05
Member#: 128269
Just curious, don't know a lot about the new STi's yet, for the 08 STi you tuned...do you make 3 different maps, 1 for each SI-Drive mode, or is it just one map for all three modes, and when you switch between modes it slightly alters the base map?
steverx05 is offline   Reply With Quote
Old 01-27-2009, 03:05 PM   #18
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
It's not as simple as the latter, but its not the former, either.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 01-27-2009, 03:31 PM   #19
MicMcKee
Member#: 185297
2008 Evo X
RR
Danget I can't wait for the next dyno day, VF52s should be in and I should be one happy camper...
Great work once again...
MicMcKee is offline   Reply With Quote
Old 01-27-2009, 03:35 PM   #20
paikman
Member#: 43002
1990 BNR32 GTR &
2015 Evo X Final Edition
yeah i don't get #1 and #2 either...#2 holds a better HP line to redline too..despite #1 have an EWG...pretty crazy stuff
The torque curve is definetely smoother on #1 but yeah..
paikman is offline   Reply With Quote
Old 01-27-2009, 05:18 PM   #21
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
I love these IAG threads. Really helps to get a look at a bunch of cars, with varying mods, on the same dyno, on the same day. Also, if you take the spike out of Car#1 vs. Car#2 they make a lot more sense. While it peaks higher, car #1 tapers less and has more area under the curve
Keep these threads coming. Jorge FTW...
Gfunk720 is offline   Reply With Quote
Old 01-27-2009, 05:33 PM   #22
jordanretro1223
Member#: 143039
2007 STI
Satin White Pearl
Jeremy's car is stock motor right?
Looks like another successful tune day from JJ and Jorge. Awesome work guys!!!
jordanretro1223 is offline   Reply With Quote
Old 01-27-2009, 06:33 PM   #23
IAG Performance
Member#: 158123
Correct. 100% Stock Motor. The car still has TGV's, stock cams, stock intake.....100% stock. Now that being said, I have to be honest, that we are not totally happy with the results of this set up. The Stainless Steel V Band .82 seems too small. We will be changing the turbine housing next month to the 1.06 Tial V Band version. The numbers are good, but we clearly have reached a point of diminishing returns because of the .82 Turbine housing. To take it one step farther, we would not have pushed the car quite this hard if we didn't have plans to put a built motor in immediately following this tune. That being said, I don't really want people to think that we are thrilled with the result. We are thrilled with the V Band Turbo Kit. It did turn out awesome and we are looking forward to a few changes that we would like to make. We actually started work on that car on Thursday January 22 at about 11am and finished it on Friday night about 2am. We have a few minor adjustments to make and then we are good to go. The kit did perform perfectly, but we now know that the Tial V band Stainless Steel turbine housings all run about one size smaller. Next month we will see what the results are with the 1.06.
Regards,
JJ
Old 01-27-2009, 06:46 PM   #24
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Jorge (RiftsWRX)
www.ProjectWRX.com
For me as well, that is seriously stout for those mods. Do you know if the owner has any plans to take it to the strip? I would be very interested to see what it would trap.
OppositeLock is offline   Reply With Quote
Old 01-27-2009, 09:05 PM   #25
nhat
Member#: 140163
03 STi
hellaflunctional
they're already out. give iag a call.
jorge, are both cars running the same amount of boost?
IAG Performance Dyno Session #1 Master Thread! Tuning provided by RiftsWRX (Jorge). IAG Performance Proven Power Bragging 56 08-22-2013 11:34 PM
IAG Performance Dyno Session #4 Tuning by RiftsWRX (Jorge). 5 total 457TQ Dom3 Again IAG Performance Proven Power Bragging 29 03-18-2010 06:02 PM
IAG Performance Dyno Session #6 Tuning by RiftsWRX (Jorge) 10 total 465 WHP GT30R too IAG Performance Proven Power Bragging 47 03-05-2009 11:30 AM
IAG Performance Dyno Session #3 Tuning by RiftsWRX (Jorge). 4 total 457TQ Dom3 Inside IAG Performance Proven Power Bragging 39 10-23-2008 08:04 PM
IAG Performance Dyno Session #2 Tuning by RiftsWRX (Jorge). 5 total 412hp Dom3 Inside IAG Performance Proven Power Bragging 18 09-25-2008 08:40 PM
