Old 01-27-2009, 02:51 AM   #1
wrxmatt02
Member#: 201313
2002 wrx bugeye
Default Random misfires and clicking injectors help me
My 02 wrx has random misfires and it cuts out if i give it more then quarter throttle or go over 3000 rpms, i checked the coil packs and they all are firing. And the right side of the motor the injectors sound like they are clicking how do i check the injectors or what should i do?
wrxmatt02 is offline   Reply With Quote
Old 01-27-2009, 02:53 AM   #2
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
List of modifications?
007WRX is offline   Reply With Quote
Old 01-27-2009, 02:57 AM   #3
wrxmatt02
Member#: 201313
2002 wrx bugeye
front mount intercooler,vf39 turbo, 660cc injectors, cold air intake, headers, 3in. turbo back exhaust, boost controller.
Old 01-27-2009, 03:06 AM   #4
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
The tick is likely the magnets in your injectors I do believe, mine are painfully loud (820cc). This is normal, you just may not have noticed them before.
What are you using for tuning, ap?
Old 01-27-2009, 03:10 AM   #5
wrxmatt02
Member#: 201313
2002 wrx bugeye
i believe when i bought the car it had the EKUTEK tune
Old 01-27-2009, 03:10 AM   #6
wrxmatt02
Member#: 201313
2002 wrx bugeye
Ecutek
Old 01-27-2009, 03:12 AM   #7
wrxmatt02
Member#: 201313
2002 wrx bugeye
Why do you think it runs good for like ten minutes and then keeps cutting out
Old 01-27-2009, 03:34 AM   #8
wrxmatt02
Member#: 201313
2002 wrx bugeye
Are you still there
Old 01-27-2009, 04:21 AM   #9
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
Originally Posted by wrxmatt02 View Post
Are you still there
lol...
dLo R6 is offline   Reply With Quote
Old 01-27-2009, 05:37 AM   #10
eMoneyyy
Member#: 200680
2002 W R X
Rally Blue
what do you mean by misfire?
the car starts accelerating and then feels like the whole car dies out and stops accelerating?
or like a sound that come from your exhaust ? AKA backfiring?
explain more in detail and tell me if you have a boost gauge, keep an eye on it if you do..
otherwise, we need to get into more detial.
eMoneyyy is offline   Reply With Quote
Old 01-27-2009, 05:44 AM   #11
eMoneyyy
Member#: 200680
2002 W R X
Rally Blue
and considering the setup you are running..
you either..
A) have a 255lph fuel pump and forgot to mention it or..
B) you dont have a 255lph fuel pump and your car is begging for one
since this happens at more than 1/4 throttle.. and/or..
above 3000 RPM.. this makes your fuel pump look suspicious.
was our car running just find with the same setup you are running?
was there any changes to your vehicle after you purchased it? if so what changes or upgrades have u done..
i cant tell u whats wrong unless u are here..
but i can pin point it for you most def.. just be proactive on this thread
Old 01-27-2009, 09:29 AM   #12
Jon W Says
Member#: 94988
2004 Impreza WRX
Midnight Black
eMoneyyy might have somthing there. Could be fuel pump is dying on you with those giant injectors...
Jon W Says is offline   Reply With Quote
Old 01-27-2009, 05:53 PM   #13
wrxmatt02
Member#: 201313
2002 wrx bugeye
Well it is misfiring and also backfiring. I do not know if it has a 255lph fuel pump. The codes it is giving are, boost calibration high, increased exhaust temp, random misfire in cylinder 1-4, throttle actuation potentiometer signal to high and the PCM has determined that the voltage signal from the exhaust gas temp sensor in bank 1 is too low for the current engine operating conditions. Thats all the codes, i will find out what fuel pump i have. What other signs could this be?
Old 01-27-2009, 06:44 PM   #14
BluScubi
Member#: 162726
2009 LGT
QSM
Looks like you have a throttle position sensor code in there. If your TP sensor is acting up this could cause your symptoms. The ECU doesn't know what your right foot is doing. The TP along with MAF and o2 mainly determine how much fuel and timing to run. If the ECU doesn't know you have opened the throttle you're now getting a whole bunch of air entering the engine and not enough extra fuel. This will cause it to bog, misfire, hesitate. What are the code numbers?
Injector's make a clicking sound so that's probably normal.
BluScubi is offline   Reply With Quote
Old 01-27-2009, 07:56 PM   #15
wrxmatt02
Member#: 201313
2002 wrx bugeye
p0545,p0301,p0303,p0302,p0304,p1544,p0545,p1301
Old 01-27-2009, 08:59 PM   #16
wrxmatt02
Member#: 201313
2002 wrx bugeye
also sometimes it will run perfect for a few minutes and then start acting up again
Old 01-27-2009, 09:14 PM   #17
BluScubi
Member#: 162726
2009 LGT
QSM
You're missing some codes:
Well it is misfiring and also backfiring. I do not know if it has a 255lph fuel pump. The codes it is giving are, boost calibration highPO106, PO107, PO108????, increased exhaust temp,P1544, PO1301 random misfire in cylinder 1-4PO301-4, throttle actuation potentiometer signal to high??? and the PCM has determined that the voltage signal from the exhaust gas temp sensor in bank 1 is too low for the current engine operating conditionsPO545. Thats all the codes, i will find out what fuel pump i have. What other signs could this be?
Theses codes ^^^^^ don't include any for boost calibration high, and throttle action potentiometer signal high. Is this all of them?
This is all out of the Service Manual:
PO301-4 Misfires Cylinder 1-4
Possible causes: If codes PO106, PO107, PO108, PO117 PO118, PO125 are present diagnose these first. PO106-8 are related to the pressure sensor. PO117, 118, and 125 are related to the coolant temp sensor.
PO545- Exhaust Gas Temperature Sensor High Input
Possible causes: Bad Connection, Bad EGT, Shorted wire EGT to PCM
Symptoms: Eroneouse idle, Hard start, Poor driving Performance
P1301- Fire due to increase in Exhaust gas Temp
Possible Causes: Repair PO301-4 first
Symptoms: Eroneous idle, Engine Stalls, Poor driving performance
P1544- High exhaust gas temp detected
Possible causes: Repair PO301-4, PO1301, and a bunch of others
I think the codes you have listed without a number are probably the under lying cause. Misfire codes will not cause a TP or pressure sensor code but the TP and Press can cause misfires. The TP sensor and pressure sensor are both located on the throttle body. Look it over for anything obvious.
Old 01-27-2009, 09:43 PM   #18
wrxmatt02
Member#: 201313
2002 wrx bugeye
ok i will go check them out
Old 01-27-2009, 09:58 PM   #19
wrxmatt02
Member#: 201313
2002 wrx bugeye
the 3 sensors look fine i think, what should i be looking for. every time i check the codes there seems to be different codes that pop up just about every time
Old 01-27-2009, 09:59 PM   #20
wrxmatt02
Member#: 201313
2002 wrx bugeye
should i pull the whole sensor out
Old 01-27-2009, 10:27 PM   #21
BluScubi
Member#: 162726
2009 LGT
QSM
I wouldn't pull the sensor out. I would check for chaffed or pinched wires, make sure they're all connected securely. Make sure the throttle plate opens and closes smoothly. Unfortunately the diagnostics subaru gives for the pressure sensor codes require a voltmeter and ideally a subaru scan tool. Check the EGT connector if you still have one.
Are there certain codes that are repeated each time or are they always different? Try using the search button with the code numbers plugged in.
Old 01-28-2009, 03:18 PM   #22
spinningcain
Member#: 176490
2005 STI
Hos your maf ???clean it
spinningcain is offline   Reply With Quote
random misfire and right bank lean after rebuild STiGuy23 Built Motor Discussion 4 09-01-2009 09:27 AM
Random Misfires and Lean MMWRX Factory 2.0L Turbo Powertrain 15 06-27-2008 02:55 PM
Misfires and CEL P0031 Help!! BadWRX1 IL Factory 2.0L Turbo Powertrain 11 11-14-2007 06:37 PM
2004~2005 wrx injectors HELP ME FIND THEM PLZ WRX4eva Factory 2.0L Turbo Powertrain 4 06-18-2007 08:19 PM
Modded injectors - Help me pick which injector to install into which cyl dexterous Factory 2.5L Turbo Powertrain 13 03-21-2006 12:54 PM
Message Board Statistics All times are GMT -4. The time now is 10:02 PM.
