Old 01-27-2009, 11:02 AM   #1
Jus Blaze
Member#: 129428
2002 Wrx
Default Are Forester XT manifolds interchangable with 2.0 wrx?
Im about to purchase pnped manifolds, crosspipe and upipe from a 04 forester XT to put into my 02 wrx. Are these interchangeable? Ive noticed on the grimmspeed site that 06-07 wrx / fxt is a different item than 02-05 wrx/sti/lgt. I dont see why they wouldnt be interchangable but I also dont see why grimmspeed would have them separate .
Jus Blaze is offline   Reply With Quote
Old 01-27-2009, 04:21 PM   #2
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
it should work..i think theres a diff in the oil pans on the newer ones
mxpunk is offline   Reply With Quote
Old 01-28-2009, 08:31 AM   #3
T_Racer69
Member#: 188079
2003 Stg 2 Bug Wagon
Sonic Yellow
From Crucial Racing Website:
"These models received narrower manifolds with different bends and they simply do not work as well. If you have one of these models and are interested in P&P&C of your manifolds, please contact us. But do NOT purchase the manifolds below unless you have 02-05 WRX or 04-08 STI ones to return to us. Thanks"
So I believe that you are correct, the difference must be in the oil pan. From reasonable deduction, I would assume that these would work on the 02-05WRX with room to spare. Though, while probably minute, these seem to not flow as well as the early manis. But this is probably splitting hairs.
Cheers,
Travis
T_Racer69 is offline   Reply With Quote
Old 01-28-2009, 08:32 AM   #4
T_Racer69
Member#: 188079
Sonic Yellow
Oops, this reference is referring to the 06-08WRX and any year FXT.
Travis
Will an sti exhaust manifold fit the 2.0 Wrx? plus plus plus Newbies & FAQs 5 07-25-2007 07:17 PM
What are my chances of getting another 2.0 block with piston slap? BlackoutWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 12-16-2006 08:19 PM
Oil line and intake manifolds for 2.0 WRX sfjohnson Private 'For Sale' Classifieds 0 12-09-2005 09:06 PM
what are some advantages of the 2.0 sti motor vs. 2.0 wrx motor??? hangten93 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 09-16-2004 12:33 PM
Are Forester XT gears stronger than WRX gears? driggity Transmission (AT/MT) & Driveline 16 07-06-2003 10:54 PM
