#26 |
Member#: 212958
Vehicle:2009 WRX WR Blue Mica |
so the other thing I tried was a leather or alcantara band wrapped around the steel knob:
![]() could you pm me either the link for this knob or the price. Can the stock shift boot clip direclty to this knob?
#27 |
Member#: 181858
Vehicle:04 WRX 2010 Outback |
It looks like from the chart that if i see a Toyota manual knob it should work on my WRX.
This is my second texas summer with my Scoob and that branding iron Momo sphere needs to go. I was coveting a JDM red & black leather knob...until i saw the price ![]() |
#28 | |
Member#: 175549
Vehicle:Buy my SHIFTKNOBS www.LatheWerks.com |
They do share the same thread, but other factors are involved with fitment like clearance and shift boot issues so those would have to be checked out before you spend money on something from a different car, so reasearch first! Good luck. |
#29 |
Member#: 116081
good luck!
#30 |
Member#: 221694
do you have a website or something where these are on sale??
#31 |
Member#: 175549
#32 |
Member#: 219373
Vehicle:2009 Impreza 2.5i Silver |
Is the SS WRX Sphere available with shorter (3/8") collar?
I have a 2009 2.5i Impreza and want to replace the OEM shift knob with your stainless steel one. Does the collar height effect the overall height of the knob or is it the same for both due to the drilled depth? I am trying to get the knob as low as possible ![]() Thanks, Johnny |
#33 | |
Member#: 175549
#34 |
Member#: 219373
Thanks for that info.
I have placed an order for the SS sphere with normal collar height...can't wait to try it out ![]() |
#35 |
Member#: 222943
South East
Vehicle:2000 Audi A4 Santorin Blue |
Do you have any photos of the different colored polyco?
#36 |
Member#: 175549
#37 |
Member#: 276021
I have recently done a swap with my Legacy GT and a friend of mine suggested I post my solution here... I simply modified my stock 5-speed knob I work at a machine shop and got one of my coworkers to align it in a vice on a manual mill and drill out a one inch deep recess at just under .800" diameter (.785-or something i can't remember exactly) in the white plastic core of the knob it left more than enough thread to use the knob securely.
Though I could have gone with about .050" or so less and been fine but any more than i did would have completely removed that section of the core which honestly would not have mattered much except the white plastic allows the lockout to slid better when pulling on the knob causing a slight flex in the rubber at the base. I did pull the leather back from the rubber that makes up the outer body before drilling so as not to shred the material. After the core was drilled out I trimmed about 3/16- 1/4 inch off of the rubber that remained at a rounded edge. Then trimmed off some of the extra leather some then glued it down with a very small amount 3m automotive adhesive. Lastly I pried off the clear plastic piece with the 5-speed shift pattern printed on the back of it scraped and polished the pattern off of the back and I'm going to try to have a small Subaru stars emblem cut from vinyl to replace the shift pattern. |
#38 |
Member#: 62408
South East
Vehicle:2002 wrx w/ STi guts 174k miles on Mobil 1 |
I just can't believe there's a 2 page thread on shifter knobs.
#39 |
Member#: 175549
#40 |
Member#: 284392
NWIC
Vehicle:2011 STI Limited Blue Pearl |
#41 |
Member#: 175549
#42 |
Member#: 230925
Vehicle:04 WRX Wag Stage 4 06 Impreza 2.5I |
I just got a STI aluminum Shifter but i did not get the plastic insert. Do you have these for sale or do you make own version.
Thanks Jim |
#43 |
Member#: 180922
Vehicle:2007 Wrx TR UGM |
i just got a kartboy shifter and blox 490 knob, but it wont thread all the way down. its only threading on about 1/2", 3/4" tops. looked at the threads on the shifter and inside the knob, and both look fine. Yes, it is M12x1.25 (as far as i know. couldve been boxed wrong i guess, but then i doubt it would thread as far as it does.) Any idea what the problem could be, and do you guys have any way to fix it if it's not just something stupid?
#44 | |
Member#: 298743
NESIC
Vehicle:2007 Subaru WRX Wago |
problem solved. I love this thready btw and will be purchasing as soon as i'm done moving ![]() |
#45 |
Member#: 313476
I wish someone would make an unpolished billet knob for our cars.
#46 |
Member#: 22035
SCIC
Vehicle:2008 STI White |
#47 |
Member#: 248431
have you considered copper or nickle? i understand the cost would be more considering the stock value but the weight and look would be pretty cool. good function in my mind.
also i understand that you create most of these products through machining. i noticed that lead was forementioned and the machining that would be involved could be potentially harmful to your health. my question is have you considered forged products? most likely this would be much more costly but this would open a lot of other options for material to be used. |
#48 |
Member#: 328442
I think lead (in regard to machining) is ok as long as it's just the metal. I think it's lead salts (like in paint pigment) that are what your body will absorb harmfully.
I still wouldn't eat it, though. |
#49 |
Member#: 74722
Vehicle:06 Outback XT OBP |
Made anything specifically for an automatic? im looking for something that sits lower than stock.
![]() not my photo but same shifter |
#50 |
Member#: 120057
Vehicle:2004 "Bugeye" WRB |
What about shift knob extenders? I have a wrx oem 5 speed knob, but I like how the sti shifter sits a little bit higher. like maybe raising it un an inch. I like the oem knob but I hate how its damn near threaded all the way up into the shift knob
| Thread Tools | |
| Display Modes | |
| shift knob thread question | Jimpreza | Interior & Exterior Modification | 3 | 09-28-2005 11:48 PM |
| Shift Knob Thread Pitch | nate49509 | Interior & Exterior Modification | 3 | 06-04-2004 10:10 PM |
| Shift Knob Thread size | whittleman | Transmission (AT/MT) & Driveline | 2 | 10-20-2003 06:06 PM |
| Shift knob threads | doobie | Transmission (AT/MT) & Driveline | 3 | 09-01-2003 08:26 PM |
| Shift knob thread size | bahboy20 | Interior & Exterior Modification | 5 | 12-13-2002 01:09 PM |
