Old 07-12-2008, 10:41 PM   #1
Rikshaman
Member#: 90817
Default ej20g code 43?
Done.
Rikshaman is offline   Reply With Quote
Old 07-13-2008, 09:43 PM   #2
suby25
Member#: 52822
2015 WRX
Is your ECU from an automatic and you have a manual car? There's an input on the ECU which needs to be wired for a 0 or 5 volt input. This will tell the ECU the car is not in park. (If this is the right code I'm thinking of). I had this happen on an EJ22T swap and the car would run like absolute crap. It would also only rev up to ~4k and then fuel cut. I realized I would get fuel cut whenever the car hit 0 vacuum.
Code 43 looks to be throttle switch (throttle position sensor?).
I'm not 100% sure all these codes are correct, it's a generic OBD1 CEL list. I believe the costs are the same for all Subaru motors though.
11 Crank angle sensor or circuit
12 Starter switch or circuit
13 Cam position sensor or circuit (TDC sensor on Justy)
14 Fuel injector no. 1 (Legacy, Impreza, Justy, SVX); Fuel injector 1 and 2 (XT, Loyale, GL, DL)
15 Fuel injector no. 2 (Legacy, Impreza, Justy, SVX); Fuel injector 3 and 4 (Loyale, GL, DL); Fuel injector 5 and 6 (XT6)
16 Fuel injector no. 3 (Legacy, Impreza, Justy, SVX); Fuel injector 3 and 4 (XT)
17 Fuel injector no. 4 (Legacy, Impreza, SVX); Fuel injector 1 and 2 (XT6)
18 Fuel injector no. 5 (SVX)
19 Fuel injector no. 6 (SVX)
21 Coolant temperature sensor or circuit
22 Knock sensor or circuit (right side on SVX)
23 Air flow meter or circuit (exc. Justy); Pressure sensor (Justy)
24 Air control valve or circuit (exc. Justy); Idle speed control solenoid valve (Justy)
25 Fuel Injector 3 and 4 (XT6)
26 Air temperature sensor (Justy)
28 Knock sensor no. 2 (SVX, left side)
29 Crank angle sensor (SVX, no. 2)
31 Throttle position sensor or circuit
32 Oxygen sensor or circuit (no. 1, right side on SVX)
33 Vehicle speed sensor (VSS) or circuit
34 EGR solenoid valve
35 Canister purge solenoid or circuit
36 Air suction solenoid valve (Impreza); Igniter circuit (Justy)
37 Oxygen sensor (no. 2, left side , SVX)
38 Engine torque control (SVX)
41 Air/fuel adaptive control
42 Idle switch or circuit
43 Throttle switch (Justy)
44 Wastegate duty solenoid (turbo)
45 Pressure duty solenoid (turbo)/atmospheric pressure sensor circuit (non-turbo)
49 Airflow sensor
51 Neutral switch (manual transmission)/inhibitor switch (automatic transmission)
52 Parking brake switch (exc. Justy)/Clutch switch (Justy)
55 EGR temperature sensor
56 EGR system
61 Parking brake switch (Loyale)/Fuel tank pressure control solenoid valve (Impreza)
62 Fuel temperature sensor (Impreza)/Electric load signal (Justy)
63 Fuel tank pressure sensor (Impreza)/Blower fan switch (Justy)
65 Vacuum pressure sensor
suby25 is offline   Reply With Quote
Old 12-24-2008, 11:41 PM   #3
thad
Member#: 176616
1994 impreza
white
resurrected, because i too am getting a persistent code 43 on my EJ20G swap, there was a wire i was concerned about, so i went back and checked it, but the wiring diagram shows the TPS having 4 wires, power ground, signal and idle switch.
so what is the throttle switch, and what are the symptoms of its malfunction?
thad is online now   Reply With Quote
Old 12-25-2008, 12:29 AM   #4
thad
Member#: 176616
1994 impreza
white
found it on a UK diagram, it shows a G/B wire going to pin 30 (equivalent B96 14) and the other (a B/R) to ground. I assume this is a WOT switch that grounds when the throttle is fully depressed. But what I want to know is why am i getting this code on a 6K ecu?
I was of the impression that those were not UK spec and the Japanese diagram doesn't show anything at b96 14 or a throttle switch accelerator pedal switch etc.
I'm kinda lost now, If anybody has some insight, I'd be very appreciative.
Last edited by thad; 12-25-2008 at 12:40 AM. Reason: might be B96 11, I think Suberdave's UK diagram reads from the front of the connector.
Old 01-14-2009, 02:59 AM   #5
Rikshaman
Member#: 90817
kk figured it out.
adjust ur throttle postion sensor until the idle switch is tripped.
Old 01-23-2009, 04:47 AM   #6
thad
Member#: 176616
1994 impreza
white
U sure? I show a separate pin at the ecu for accelerator pedal switch and idle switch.
I finally got the code to go away when entering Diag and clear mode by pinning a wire into the spot for "throttle switch" and touching it to ground when i depressed the pedal fully.
yeah I know band-aids just cover the wound.
Old 01-24-2009, 12:44 AM   #7
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
it's for the throttle pedal switch found only on JDM models. The code is persistant, but it won't cause a CEL or any drivability issues. I haven't found anyone who knows what it does. If it really bugs you I could modify the running code to never set the code :P
rob is offline   Reply With Quote
Old 01-28-2009, 09:57 AM   #8
Rikshaman
Member#: 90817
yes, 43 is the ghost code that comes up when u reset the ecu the soft way. (green and black + floor accelerator a few seconds, then 50%)
Idle switch is when the throttle is fully closed, an idle switch is closed on the tps sensor. If ur tps sensor is maladjusted u will get the idle switch code. my bad.
ej20g code 45 CEL gc8awdsti Pre-2002 Factory Turbo Powertrain 16 03-29-2009 12:20 PM
EJ20G CEL Code 45 - Pressure Duty Solenoid subaruwrx Pre-2002 Factory Turbo Powertrain 5 10-30-2008 11:12 AM
EJ20G Code 42 question TVA Pre-2002 Factory Turbo Powertrain 1 10-12-2007 03:45 AM
Code 43 gvaf Engine Management & Tuning 2 10-16-2005 05:14 PM
EJ20G codes 14-17... say what? smacksube Subaru Conversions 4 12-30-2003 09:00 PM
