Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 01-28-2009, 01:58 AM   #1
JeffrWRX
Member#: 48589
2002 PSM WAGON Stg2
FORTUNE/RPF1-17x9/2354017
Default Lets figure this out...Do I have a real 1995 STI Type-RA
My old thread got deleted but I wanted to start it again since I have more info to share. Matt or other experts please review my pics/info and let me know if you think my car is a REAL STI-RA
Thanks.
The car has:
RA Roof Vent
No ABS Lines at all
DCCD + Cluster etc
OEM Turbo timer
CF Strutbrace *removed
IC Water Sprayer *removed
Heres the VIN:
Tranny Code:
Firewall VIN:
Cross Hatching on block as described by Matt?:
5th Injector:
Block Code?:
EJ20
Is there anything I can take pictures of to put this baby to bed once and for all? I am pulling the engine this weekend to put in new pistons and do a valve job. It has low compression on all 4 cylinders.
-Jeff
JeffrWRX is offline   Reply With Quote
Old 01-28-2009, 02:01 AM   #2
JeffrWRX
Member#: 48589
2002 PSM WAGON Stg2
I found this on Typera.co.uk
MY 95 spec
Impreza WRX STi RA Version I
STi's for the 95 model year were only available as a Type RA
October 1994 to July 1995
Model code: GC8C47D
Engine: closed deck design
Compression: 8.5 to 1
Power output: 275 PS @ 6500 rpm
Torque: 319Nm or 235lbft @4000rpm
Power to weight: 229 PS per tonne
Gearbox: 5 speed close ratio manual
Ratios:
1st 3.454
2nd 2.333
3rd 1.750
4th 1.354
5th 0.972
Final drive: 4.444 to 1
Other features:
wheels: 6 x 16" gold five spoke alloys
No ABS
DCCD
Roof vent
5th injector
intercooler water spray
Carbon Front strut brace
Old 01-28-2009, 03:33 AM   #3
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
You have a v1 STI RA... 272HP...closed deck....roof ventilator...ic spray
The giveaway to STI RA would be that you have dccd... the engine code you have(GC8C47D) is for both the WRX RA and STI RA model year september 94 to August 95, BUT... the WRX RA did not come with DCCD. Your transmission code also confirms what you have and your gear ratio is 3.900
The non RA wrx ej20g has the engine code (GC8C48D)
This site should help you... check model codes then transmission codes.
http://www.northursalia.com/techdocs/techdocs.html
Good luck
blkgm8 is offline   Reply With Quote
Old 01-28-2009, 04:32 AM   #4
Rikshaman
Member#: 90817
OH NOOOS. ur ripping her apart. Again. Like ive seen done to that poor car many times before. That cross haching looks correct, as it does on my block as well. throw in some new acl bearings and headstuds while your in there.
Just wondering what the 5th injector is connected to on the ecu pinout. I read on scoobynet that it hooked up to where edm cars had the precat/02 sensor. Something that indicated overheated catylictic converter. Do you also have the p/s cooler?
I dont trust these older closed deck blocks for some reason, even though i have one,
the open deck motors seam to last longer. Maybe because RA was highstrung from factory? ie pretty nasty aggressive tuning (6k, 7k ecu)
I know that gearbox loves to keep the ej20g revving high. Hows your valvetrain doing?
It should be the bucket shim cam design correct? non hydraulic assemblies on early type ra ej20g. rev limit at 7500 rpm?
Rikshaman is offline   Reply With Quote
Old 01-28-2009, 03:10 PM   #5
JeffrWRX
Member#: 48589
2002 PSM WAGON Stg2
Sweet! There was alot of argument about this car and if it was real or not so I hope I have enough evidence now to support the claim that its "real"
I have to rip it apart...the previous owner ran it on 91 octane stock ECU
I will let you know about the heads when i get it apart.
Old 01-28-2009, 04:46 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
That car is real. If it was just an RA it would be an DW4HJ. The fact that it's DW4PJ means it's STi-RA. And the pictures back that up.
The tranny is a 3.9 FD with the super short 0.97 5th. That's as short as 4th is a USDM WRX.
Old 01-28-2009, 05:40 PM   #7
JeffrWRX
Member#: 48589
2002 PSM WAGON Stg2
Sweet Finally! We have figured it out.
I cant wait to get it running properly...I drove it to and from EDO performance when it was low on compression and the gearing was definitely short but the car had no low end what so ever.
I have a New PowerFC+Commander for a JDM STI Ej20G do I need anything else for a tuner to tune it?
Thanks!
-Jeff
Old 01-28-2009, 06:22 PM   #8
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
What's the stock ECU code?
-Rob
rob is offline   Reply With Quote
Old 01-28-2009, 06:25 PM   #9
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
oh and what the heck is the OEM turbo timer?
-Rob
Old 01-28-2009, 06:26 PM   #10
JeffrWRX
Member#: 48589
2002 PSM WAGON Stg2
-Rob
Its under the kickpanel...I will be pulling it out soon to install my PFC. I will post pics.
It should be a special ECU right?
Old 01-28-2009, 06:27 PM   #11
JeffrWRX
Member#: 48589
2002 PSM WAGON Stg2
-Rob
A factory installed Turbo Timer...I have never seen one before. Its a switch with the symbol of a turbo and it switches from 3mins, Off, or 1min. Its next to the DCCD wheel in teh center console.
I will take pics of that too.
Old 01-28-2009, 06:29 PM   #12
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Nice find GL with all that.
medamullet is offline   Reply With Quote
Old 01-28-2009, 06:33 PM   #13
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Right. It should be a 7K ecu.
-Rob
Old 01-28-2009, 07:14 PM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
-Rob
I thought it would be a 6k?
Old 01-28-2009, 07:30 PM   #15
RGates STI
Member#: 81783
2007 STI
Urban Grey Metallic
Did you ever post pics of the exterior? I would love to see!!
RGates STI is offline   Reply With Quote
Old 01-28-2009, 07:43 PM   #16
JeffrWRX
Member#: 48589
2002 PSM WAGON Stg2
I've posted in other threads but here you go...Some Hate it Some love I bought it with this color and widebody...
Yes it was built as a show car...blah blah
More info:
http://forums.nasioc.com/forums/show....php?t=1681533
http://forums.nasioc.com/forums/show....php?t=1639470
Old 01-28-2009, 07:49 PM   #17
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
From what I have in my notes, the 6k would be STi VerII.
Old 01-28-2009, 09:25 PM   #18
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Actually it will be a SB ecu for the v1 STI RA...
Yes... It is a special ecu for that engine and comes chipped from the factory... higher boost, etc... You will notice the chip when you open the case... I think the label is pink as well.
If he did have a v2 STI RA then.... it would be 7K... but his vin and trans codes do not support this.
6k is the STI non RA
Old 01-28-2009, 11:13 PM   #19
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Ooops, you are right.... I thought I saw it was a Ver2 STI-RA. SB would the correct ECU for STi Ver1 RA.
And if it is SB, I would oh so much like to borrow it for few days
-Rob
Old 01-28-2009, 11:40 PM   #20
Matt Monson
Member#: 832
99 2.5RS, '85 911
I wonder what is different between an SB and SA other than 5th injector control.
Old 01-28-2009, 11:59 PM   #21
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Are you sure on that Matt? My info says the Ver1 STI-RA had the same ratios and final as the standard WRX RA. It was the Ver2 STI-RA that moved to 3.9 final.
-Rob
Old 01-29-2009, 12:13 AM   #22
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
No factory ECU controls the 5th injector.
-Rob
Old 01-29-2009, 12:15 AM   #23
Matt Monson
Member#: 832
99 2.5RS, '85 911
It's got a B3EA tranny in it. That's a 3.9 with the super short gears. That was also found in the MY95 RA. The B3DA in the MY94 RA's was the same ratios but with a 4.11 FD.
But then it depends on who you talk to. There are many who consider V2 to span 2 years to include MY95 and MY96, with V1 being MY94. Other people group MY95 into V1 with 1994. It kind of depends on your source whether this car is a V1 or V2. But what I am sure of is the ratios in the tranny listed on the vin plate no matter what you call the car.
Old 01-29-2009, 12:15 AM   #24
Matt Monson
Member#: 832
99 2.5RS, '85 911
-Rob
How's it controlled? Is it constantly firing once the car is turned on?
Old 01-29-2009, 12:16 AM   #25
JeffrWRX
Member#: 48589
2002 PSM WAGON Stg2
Here are more pics....THE ECU IS... SB!
SB ECU
DCCD/STI Cluster
DCCD + OEM Turbo Timer ;p
-Jeff
ej20g IACV..lets figure this one out GripGC8 Pre-2002 Factory Turbo Powertrain 39 09-13-2009 06:34 PM
1995 STi Type RA, Impreza25 Photo shoot Teaser Pic THE-95-STi Member's Car Gallery 63 04-23-2009 04:14 PM
Lets see if OT can figure this out.. pgtkid Off-Topic 19 04-27-2008 11:54 PM
F/S 2 JDM 1995 Subaru STI Type RA Santo Domingo 2.5 RS Private Vehicle 'For Sale' Classifieds 16 05-24-2005 05:03 PM
