Old 01-28-2009, 06:08 AM   #1
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Default EJ20G water pump q v2
so i just read my mechanics report again and it said i had a leaky water pump, and i realized it could mean either A.) the Gasket or B.) the Pump
i looked at the pump, and didn't see any cracks or what not, so is it most likely a gasket?
Im ordering the parts to fix my car soon, so i wonder if i can get any input from the peanut gallery. Am i better off just replacing the pump anyways?
JDMFLCL is offline   Reply With Quote
Old 01-28-2009, 08:25 AM   #2
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
replace the pump. just bc you cant see any cracks doesnt mean that the weep hole is messed up.
not worth putting everything back together and then the pump being bad. so just replace it. i got my new referbished pump for $70 bucks from the local autoparts store, and havent had a problem since, comes with the gasket also.
gc8awdsti is offline   Reply With Quote
Old 01-28-2009, 09:11 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
agreed
Old 01-28-2009, 02:14 PM   #4
JDMFLCL
Member#: 180513
Baby Baby C'mon!
hrm, where is this cheaper pump, advanced auto parts? OEM costs about 100 with gasket shipped
Old 01-28-2009, 02:16 PM   #5
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
i got mine from O'Reilly's auto parts. (refurbished) for a little under $70 bucks.
Old 01-28-2009, 02:17 PM   #6
JDMFLCL
Member#: 180513
Baby Baby C'mon!
think its superior to oem?
Old 01-28-2009, 02:20 PM   #7
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
i havent had a single problem with in for over a year
Old 01-28-2009, 02:20 PM   #8
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
also comes with a lifetime warrenty
Old 01-31-2009, 07:19 PM   #9
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
The pump itself is pretty cheap... might as well replace it since it will be off. Most new pumps will supply gasket.
blkgm8 is offline   Reply With Quote
Old 07-07-2010, 09:39 PM   #10
Imprzaboy89
Member#: 241311
95L V6WRXSTI type R
HE?RP DERP
Default jgg
i need an ej20g pump to what do i ask for?
Imprzaboy89 is offline   Reply With Quote
Old 07-08-2010, 12:57 AM   #11
suberdave
Member#: 101865
88 GL-10 STi
if it has the oil cooler, most of them do. then just get one for a WRX or an STI.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 07-08-2010, 05:49 AM   #12
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
i have a Ej water pump for sale, new with gasket.
PM me if u want one. ill sell it for 50, its brand new, not refurb...
azn0boi04 is offline   Reply With Quote
Old 07-08-2010, 01:22 PM   #13
RallyColtTurbo
Member#: 16819
-=Suberdave=-
If it doesn't have the oil cooler, ask for a '92-'94 Legacy turbo pump. (NOT '91).
RallyColtTurbo is offline   Reply With Quote
Old 07-08-2010, 09:23 PM   #14
Brodie69
Member#: 246637
94 JDM WRX
Red
-=Suberdave=-
Just get one for a WRX or STI? does this mean the new age model say 02+ WRX or STI water pump will work?
Brodie69 is offline   Reply With Quote
Old 07-09-2010, 01:41 AM   #15
suberdave
Member#: 101865
88 GL-10 STi
yeah say 2005 STI... or 2002 WRX...
Old 07-09-2010, 11:18 AM   #16
luka
Member#: 194742
1993 Impreza WRX JDM
is there anything maintenance wise (belts, gaskets, pumps, etc) on the USDM EJ205 that *won't* work on the EJ20G?
luka is offline   Reply With Quote
Old 07-09-2010, 11:39 AM   #17
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Yes, head gaskets, valve cover gaskets, intake manifold gaskets, timing belt is all different. Only things you can use are oilpump and waterpump, exhaust manifold and turbo gaskets, front and rear crank seal. All the other bits you can take from a contemporary USDM EJ25D engine (EJ20G with HLA use 1995-1996 EJ25D HLA engine parts like seals, belts etc). There are numerous threads on that topic by the way.
Marnix is offline   Reply With Quote
Old 07-09-2010, 11:52 AM   #18
luka
Member#: 194742
Thanks Marnix, I was hoping there was a quick answer
I'll peruse through the forum see what I need for my my tune-up.
Is this the right water pump, ej20g? kbahus Pre-2002 Factory Turbo Powertrain 8 05-22-2006 05:12 AM
FYI-Ej20g water pump. 99WRXEJ20 Subaru Conversions 10 12-18-2005 11:10 PM
ej20g water pump part no? AsphaltsCry Subaru Conversions 6 11-30-2005 07:00 PM
Ej20G Oil Cooler / legacy turbo water pump / oil pump supermoose Private 'For Sale' Classifieds 2 09-29-2005 12:06 PM
Water pump part # for a EJ20G? 99WRXEJ20 Subaru Conversions 3 01-30-2004 12:16 AM
